fuego springs needed urgent
Results 1 to 9 of 9
    8,397
    Default fuego springs needed urgent
    Does anyone have any fuego lowered front sus springs lying about ,or know where I can get some? I Have everything else on order to fix up the front end but cant proceed until I've sourced the bloody springs.
    Member Jack Daniel's Avatar
    May 2004
    Perth
    102
    Default Lowered Fuego springs
    Jo,
    I havenít found anyone in Aust with lowered Fuego springs available as a standard item Ė yet, but I believe you can get them custom made.
    How the maker would get the heights and tensions right without specs available is beyond me though.
    You can also have your standard springs ďresetĒ, but I donít know how thatís done either.
    The only listing I have found anywhere for Fuego springs (from a reputable manufacturer) is SPAX in the UK.
    Spax springs
    Manufacturer : Spax
    Category : Spax Springs
    Sub-category : Spax Springs - Renault
    Application : Fuego ; 80-85 ; -35mm
    Product Code: SPX-S031025
    Details : See note 1
    Price: £134.99
    Delivery: £14.10
    Now, ₤134.99 ($338AUST) seems pretty pricey for one spring (or even 2), so Iím guessing that this is for a full set, 35mm lower than standard. Still waiting for confirmation from SPAX.
    If you find anything else, let me know please Ė Iím after some aswell.
    Shane (Jack) Daniel
    Never attribute to malice that which is adequatly explained by stupidity.
    Aug 2002
    1,290
    King springs will make just about anything you need supply them the spec and they do the rest.
    Neil
    '94 405 SRBT
    '82 CX 2400 Pallas 5spd
    '76 CX Super
    '05 WL Statesman
    '92 HZJ80 Landcruiser
    May 2004
    Perth
    102
    Default Specs
    King springs would be great - if you have the specs.
    I phoned them, and they didnt seem real interested in doing anything out of the ordinary - especially as I dont have specs.
    Physical size is easy, but what is the spring rate needed for a Fuego?
    If anyone has the specs, I would love to get them and try again.
    Jack
    8,397
    Have ordered 4 springs . standard less 40 mm.from k-mak springs in sydney. the guy assured me they have the specs and can supply in 24 hours. ordered the set. will wait and tell you how they are.
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Don't go any firmer than the standard spring rate.
    FWIW I would just get a set of standard springs reset.
    Many spring works can do this for a fairly piddly amount of money.
    It's not exact but basically just use a 2-1 ratio.
    i.e - If you want the front to be lowered by 1 inch, get the spring reset 2 inches shorter....
    I wouldn't recommend going anymore than 1.5 inches below the standard specs (as quoted by the factory) as you will start running out of compression travel...not great
    Also, what dampers are you using?
    8,397
    not sure of brand dampers,but they are french and cost about $120. and come from caravelle in melb.
    Simon's Avatar
    6,162
    Quote Originally Posted by jo proffi
    Are they suitable for the lowered springs? Or is the spring base adjustable?
    8,397
    ahh dunno.Will find out on monday when it all works or doesn't work.
