Fuego Gauges
Results 1 to 7 of 7
Thread: Fuego Gauges
    Brisbane/Australia
    2,047
    Default Fuego Gauges
    Does anyone know what the circuit board behind the tacho in the Fuego instrument cluster is for?
    Naturally, it doesn't appear on any wiring diagrams.
    Ren
    Member Jack Daniel's Avatar
    May 2004
    Perth
    102
    Default Instrument circuit diagram
    Havent got one yet, but over the next few months, I will be modifying mine, and I will put a diagram of the original, and of the mods, on the site.
    Shane
    Brisbane/Australia
    2,047
    Quote Originally Posted by Jack Daniel
    Shane
    Shane,
    I'm referring to the circuit board inside the instrument cluster, not the flexible sheet on the outside back. The one inside has electronic components mounted on it and there are a couple of trimpots on one end accessible through a couple of holes drilled in the instrument case.
    If thats the one you're referring to, what does it do?
    Ren
    May 2004
    Perth
    102
    Default Diagram
    Yep, I'll be working through that one as well, to find out what iy does, how it does it, and how I can make it better
    Tynong North Victoria
    14
    Default Circuit board.
    Hi Ren,
    The board appears to be an amplifier for the oil level sensor,it has two connections to the level sensor and one to the oil pressure switch ,the oil pressure connection presumably inhibits the amplifier when the engine starts.
    The trimpots are likely to be factory settings for calibration.It is shown on page 272 of the Haynes manual it appears as an "A" on unit 29.I was intending to draw the circuit of the board but as yet have not found any info. on the IC used in it.
    Cheers John.
    Brisbane/Australia
    2,047
    Thanks John. I don't need the circuit diagram, I only needed to know what the circuit board did. The tacho in my Fuego doesn't work and I was goiing to replace it with a digitial tacho. To do this I would have to remove the circuit board.
    As the motor in my Fuego is not standard and is not fitted with the oil level sender, I can remove the circuit without any problems. My motor has a dipstick so I don't need a oil level guage anyway.
    I'm thinking the oil level guage could be coverted to an oil pressure guage without a huge amount of work.
    Ren
    1000+ Posts Europa's Avatar
    Jan 2002
    2,432
    So how do you propose to make an oil level gauge work better? Just curious...
