R25 Injection
Thread: R25 Injection
    Fellow Frogger! Ren25's Avatar
    Dec 2002
    Perth
    299
    Default R25 Injection
    Hi all
    Having problems (again) with the early Renix injection on my R25, stumbling & farting, it's a right pain, and I am led to believe, may be the lead up to something terminal in the efi. I may have a chance to pick up a later model parts car. The question is, can the later model ('89) injection system be fitted to the earlier model (86) car without a degree in mechanical engineering majoring in efi? Any thoughts would be appreciated.
    Mike
    Member Jack Daniel's Avatar
    May 2004
    Perth
    102
    Default Aftermarket ECU
    Have a look at the Wolf3d V4 ECU. If your not interested in maintaining originality, its a good option.
    Im going to be using one on my Fuego TXi conversion. They are affordable, very flexible and apart from the initial Dyno setup, can be installed and configured by you, using existing sensors.
    http://www.wolfems.com.au/products/e...agement/wolf3d
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,748
    Quote Originally Posted by Ren25
    Hi all
    Mike
    I have an early R25 EFI computer in the bits collection if you want it.
    May 2002
    canberra...
    8,748
    Hi all
    Mike
    This would a BIG job, as virtually everything is different. But if you have the donor car, it shouldnt be hard. Most of the work will pulling all the emmision crap off, changing manifolds and getting the later engine loom to match the cars loom. Should be doable - and well worth the effort IMHO. The later setup is MUCH better.
    5,071
    Hi, suspect you are going to over fix this problem. Try to have someone with experience to look at the problem. I know the early system has a few problems but they can be overcome. A mate has 2 25s and is very familiar with all the systems. He'd probably be happy to talk to you about it before you go to the trouble of changing everything
    JoBo
