Renault 16TS 1969 CV joint required...anyone have one or know who to get one from?
Results 1 to 16 of 16
Like Tree10Likes
  • 1 Post By COL
  • 1 Post By JohnW
  • 2 Post By driven
  • 1 Post By JohnW
  • 1 Post By Sunroof
  • 2 Post By alan moore
  • 1 Post By COL
  • 1 Post By tresbon2
Thread: Renault 16TS 1969 CV joint required...anyone have one or know who to get one from?
    1000+ Posts dogboy's Avatar
    melbourne,victoria,australia
    1,374
    Default Renault 16TS 1969 CV joint required...anyone have one or know who to get one from?
    my passenger side CV joint (outer at wheel) has shit itself...does anyone have one or point me in the direction of someone who does? should I do both sides? or just the one making the noise
    thanks all
    Rev. Dogboy
    1969 DS21 Pallas BVH with leather
    1970 Renault 16TS
    1967 Honda S800 cabrio
    Citroen 1966 ID Safari (with 23 running gear)
    1975 VW Kombi poptop
    Porsche Boxster S manual
    1988 Vespa PX200E
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,281
    I would just replace the one making the noise, they last for a long time as long as the boot does not have a hole in it and let out the grease inside.
    I would also make sure that the replacement has a good boot on it, otherwise you will be doing it again shortly.
    Sorry don't have any R16 shafts anymore.
    dogboy likes this.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    11,186
    I'd email this guy: Renault 16 club Tilburg - Geert (Tilburg, the Netherlands)
    You could buy the wreck that was making us unhappy a week or so back? It has two!
    dogboy likes this.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    1000+ Posts driven's Avatar
    Apr 2005
    1,537
    Bush Mechanic strikes again
    Put the LHS shaft on the RHS and noise will disappear.
    Always marked LH and RH shafts to always reinstall this way for some extra life
    JohnW and dogboy like this.
    1,374
    well I got a suggestion to clean out then regrease the cv joint and it seems to have done the trick...lack of grease seems to have been the problem...phew for now
    Rev. Dogboy
    1970 Renault 16TS
    1988 Vespa PX200E
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,281
    Quote Originally Posted by dogboy View Post
    Why was there a lack of grease? There us usually plenty of grease in these joints!
    Was there a hole in the boot?
    Regards Col
    1973 Alpine A110
    11,186
    The grease in the "sealed" suspension ball joints can harden up too, leaving the joint poorly lubricated. The symptom is occasional sharp cracks that aren't related to any apparent looseness. I've fitted grease nipples to the R8 ball joints and grease every couple of years and the problem disappeared.
    Must have been a very old driveshaft if the grease hardened up. No holes??? Perhaps it needs more use.
    dogboy likes this.
    Boonah Qld
    2,597
    If drive shafts are worn you can swap them to the other side and you will only notice the wear in reverse. My R17TS has had the worn shafts swapped many years ago and they are still going strong. Sure there is a bit of a clunk in reverse but you don't do many K's backwards.
    dogboy likes this.
    1,374
    there is no rubber boot on the outer driveshaft on my 16...there is on the inner
    Rev. Dogboy
    1970 Renault 16TS
    1988 Vespa PX200E
    1,374
    Rev. Dogboy
    1970 Renault 16TS
    1988 Vespa PX200E
    Ipswich, Queensland.
    1,936
    You have the original correct driveshaft for your early 16. Looks like your brake hose could do with some untwisting.
    dogboy and COL like this.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,281
    I see you have the old style shafts, they have done well to last this long.
    dogboy likes this.
    Regards Col
    1973 Alpine A110
    1,374
    this 16 was owned by one person for most of its life..I have a full history including delivery receipts...when the owner died it was put away for a number of years hence fairly low mileage
    Rev. Dogboy
    1970 Renault 16TS
    1988 Vespa PX200E
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,281
    Sounds like a nice car with all the original documents and service history to go with it.
    Its good that you were able to fix the original driveshaft hence keeping the car original as possible.
    Regards Col
    1973 Alpine A110
    Mar 2003
    369
    thanks all
    Hi. I have 4 of the later driveshafts, but I am not sure if they will fit your early car. I'm sure someone else on this site will know.
    Don
    dogboy likes this.
    Citroen DS21 Pallas 1970 Renault 16TS 1976 Renault 5TS 1981
    1,374
    Quote Originally Posted by tresbon2 View Post
    Don
    at the moment it seems my problem was solved with a liberal application of grease
    Rev. Dogboy
    1970 Renault 16TS
    1988 Vespa PX200E
