Caravelle R1133 year 1965
Like Tree4Likes
  • 2 Post By Frans
  • 2 Post By dacia4x4
Thread: Caravelle R1133 year 1965
    Jan 2011
    49
    Default Caravelle R1133 year 1965
    After accelerating in first gear and suddenly taking foot off accelerator, it jumps into neutral.
    This has been an issue since buying the car a few years ago.
    Appreciate any assistance!
    (PS having it resprayed at the moment)
    dvr
    dvr is offline
    741
    Gearbox detent mechanism possibly worn.
    1000+ Posts Frans's Avatar
    Auckland
    1,536
    Easy fix if the gearbox is out. The selector shaft has little indents where a ballbearing is pushed into by a strongish little spring. That spring has most probably broken.
    When the gearbox is stripped and the selector shafts removed it can be changed. I have gone to a gearbox shop with the sample and the guy allowed me to scratch in their bin and I replaced mine successfully with similar springs out of a who knows what car.
    Regards, Frans.
    COL and JohnW like this.
    Old enough to know better
    Young enough to do it anyway.
    Apr 2014
    kilsyth (lower montrose) vic,
    222
    hi Arak,i would first check for excessive play in gearshift linkage, especially at gearbox end, then engine and gearbox mounts(centre top gearbox also) for possible for and aft movement in drive line on acceleration and braking. just a couple of thoughts...... jim
    Sunroof and COL like this.
    11,213
    I'm not being facetious, but I'd just drive carefully in first. If it is that detent spring, which seems likely, you won't damage the gearbox. I suspect mine is going the same way, but I'd need a much bigger reason for pulling the car apart so thoroughly.
    Just a thought....
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
