R12/15/16/17 Coolant height in bottle when hot
Results 1 to 21 of 21
Like Tree10Likes
  • 3 Post By Steve K
  • 1 Post By JohnW
  • 1 Post By 21571
  • 1 Post By 21571
  • 4 Post By 21571
Thread: R12/15/16/17 Coolant height in bottle when hot
    Fellow Frogger! 21571's Avatar
    Apr 2013
    Geelong
    216
    Default R12/15/16/17 Coolant height in bottle when hot
    Hi guys,
    Just wondering what heights the coolant get to in your expansion bottles when your engines are hot.
    The spigot in my cap came loose. I've bonded it back on with JB Weld. While doing this I took the cap off the valve and gave everything inside a good clean, riveted it back on and sealed the rivets with more JB weld.
    My coolant has been getting to about 3/4 of the way up the bottle after only 10 minutes or so of driving.
    It's a sealed system, until the pressure opens the valve whenever that is, so the air will compress as the coolant expands. It all goes back in as it cools.
    Assuming I put the valve back together correctly.....
    Cheers, Tim
    3,631
    Hi Tim
    I think you need to bleed the system, the level of coolant in the bottle should not change .
    ps the answer to previous question is 21 psi front 26 psi rear.
    Cheers Andy.
    .2010 Holden Commodore Ute
    1000+ Posts driven's Avatar
    Apr 2005
    1,537
    There is a small change in coolant height as water expand
    or your head gasket is blown if bleeding checks Ok
    Apr 2013
    Geelong
    216
    Nothing strange showing up in the oil, so no water going that way. Whether there's gas going into the coolant, hmmm, not sure about that. Not sure how the coolant level would go back down as it cools if some of its volume in the system has been replaced with gas.
    I'll bleed again shortly, hopefully the kids go down early.
    Oct 2002
    Melbourne Victoria
    12,477
    Hi 21571- The coolant bottle and its valve maintains the pressure level in the system while often there is another heat activated valve or system that limits circulation for fast warm up of the engine. If the system leaks or valves faulty the system doesn't work as designed and if pressure drops in the system, the coolant will boil, most systems have an optimum level of coolant in the bottle when cool and that allows for expansion of the liquid coolant and maintaining the approximate pressure/heat that is best for your engine, summer and winter. Type of coolant mixture may also come into the equation.
    compare yours with another owner, or two, and you should soon be able to see if your setup has a problem.
    Ken
    9,236
    The coolant level goes up because the gas in the system (which shouldn't be there) expands immensely compared to its state at normal (ambient) temperature. That explains why the level goes back down again. At normal temperature you will barely see any difference in coolant level when it has gas in it. Gas is also insoluble in liquid as the temperature goes up, so this adds to the effect. As the coolant drops in temperature, the gas can more readily dissolve so less of it will push the coolant level up.
    Your symptoms are typical of a head gasket failure. Maybe not catastrophic yet, but it's coming. Purge the system of any air/gas/whatever and check again. If the coolant level still goes up (assuming you bled the system correctly and completely), it's the head gasket.
    ACHTUNG ALLES LOOKENPEEPERS
    Apr 2013
    Geelong
    216
    Didn't notice this before I started "winter maintenance" which has only just been completed. Have only driven it maybe 6 times this year, and it hasn't got hot, so a head gasket issue would be an old one that's just starting to surface.
    Boonah Qld
    2,597
    I have had the same result from a almost blocked heater pipe. You could not bleed the air out of the heater but the air would expand and contribute to the bottle. It was almost blocked at the metal pipes as they pass through fire wall. You might be lucky.
    Dec 2010
    Blackburn Victoria
    502
    it is imperative that the cooling system is bled correctly.
    Make sure the coolant bottle seal is intact between the glass and the metal valve assembly and it is also a non - leaker.
    The seal at the filler cap is good.
    Bleed the system with the engine stopped and cold and then with it idling.
    First at the bleed valve on the water pump.
    Then at the radiator as it can trap a lot of air.
    Finally at the heater bleed valve.
    You may need to do this several times.
    Starting the engine cold, have it idling and feel the hose at the thermostat.
    It should remain cold and then heat up relatively quickly as the thermostat opens. ( if it is working correctly)
    Then reach in under the front of the car and you should feel the inlet and outlet of the radiator warm up.
    As you do this and the engine and cooling system are warmed up fully, the coolant level should only rise a little.
    Give the engine several sharp full throttle blips enough to annoy the neighbours.
    If the coolant level rises rapidly, you unfortunately have a failing head gasket.
    Hope this helps.
    21571, bowie and COL like this.
    Apr 2013
    Geelong
    216
    Not too high after the run the run home, bit of traffic too so temp came up. You can actually see on the temp gauge when the thermostat opens and the cold water from the radiator comes into the engine past the sensor.
    I had the heater tap open too. The bleed off the water pump is a bit too close to the pump belt for my likings to do with engine running.
    For no apparent reason the low to mid throttle surge I'd been having went away on the way home too. The D-Jetronic still needs a tune, these things don't tend to fix themselves.
    Sent from my SM-G973F using Tapatalk
    11,186
    My R8 rises maybe 2-3 cm approximately from cold to hot as the coolant expands. Not much. I keep a beady eye on where it sits when the engine is cold as a guide to any losses. Sometimes it uses a medium-sized beer glass of coolant in a year or so.
    If it is rising 5-10+ cm I'd be suspicious.
    The valve, btw, doesn't cause just compression of the air in the bottle, but has a pressure rating so it will let pressure out if necessary. Equally, as the car cools, the valve lets air back in - this valve can jam and cause havoc so check it is opening etc.
    I did once have a small head gasket leak and could see the occasional small bubble coming up to the (removed) radiator cap spigot with the radiator full to the brim and with the engine idling. If your level rises quickly in the bottle on startup, I'd be alarmed because I can only think of one cause....
    Exfrogger likes this.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Apr 2013
    Geelong
    216
    Ok, another system bleed, make sure bottle cap is screwed on tight. 2cm rise up to thermostat opening and another 5 minutes idling after that. Took maybe 10 minutes at idle to come up to that temperature.
    Maybe not bled properly, maybe cap not on tight enough.
    I'll be keeping a close eye on it.
    Now to find the leak with the remote filter block and oil cooler......
    Sent from my SM-G973F using aussiefrogs mobile app
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,281
    The only times I have seen the water level rise in the header tank is when i have had a broken fan belt so there was no water circulating and when the thermostat failed shut.
    The only other thing I can think of to what Steve has mentioned above is to remove the thermostat and check is operation in a saucepan of hot water on the stove and a thermometer.
    Just my worth.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Apr 2013
    Geelong
    216
    Pleased to report that coolant level has stabilized. Now to fix the D-Jetronic......
    COL likes this.
    Member Jabin's Avatar
    Jan 2011
    South Tas
    35
    [QUOTE=JohnW;1645633]My R8 rises maybe 2-3 cm approximately from cold to hot as the coolant expands. Not much. I keep a beady eye on where it sits when the engine is cold as a guide to any losses. Sometimes it uses a medium-sized beer glass of coolant in a year or so.
    Same here in the R10. BTW what is the temperature spec. of the fitted thermostat? (ie 74į or 83į)
    Jabin
    R10 (round eye); Clio series II Privilege 1.6L Manuel
    Apr 2013
    Geelong
    216
    I've got a Tridon TT237-170P fitted, 77 degrees
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,281
    Quote Originally Posted by 21571 View Post
    As long as it works like it should, it should be fine.
    Regards Col
    1973 Alpine A110
    Apr 2013
    Geelong
    216
    It works, you can see the temp gauge drop as the cold water from the radiator comes into the engine past the sensor.
    The data sheet I have for the A310 says a 75 degree thermostat, got as close as I could.
    COL likes this.
    11,186
    [QUOTE=Jabin;1646469]
    I have one of the old brass ones with bellows and just looked at its rating the other day, as it happens. 78 degrees. My temp gauge sits on 78-82 almost all the time except rising to 90 degrees on a long hill on a hot evening - tested this week!!
    11,186
    Forgot to mention (and the edit function has crashed for me) that I tested that old 78-degree thermostat that I've had for years and it works properly - mercury thermometer etc etc.
    Apr 2013
    Geelong
    216
    250km round trip to the RCCV Round Up Sunday and coolant has where it started the day. Happy days.
    Cracker of a show too!
