Wanted: Bits for the Yellow R12.
Results 1 to 18 of 18
Like Tree3Likes
Thread: Wanted: Bits for the Yellow R12.
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,536
    Default Wanted: Bits for the Yellow R12.
    This long weekend has afforded me the luxury of going over the bits left required to put the yellow one back together.
    I won't tell you how I tried to drill out the rear passenger handle instead of just whacking a big screw driver in there...
    Hoping there may be some odds and ends you are willing to part with, I'll even pay caaaaaaaash.
    #EDIT All sorted! 1) Rear left hand light rubber (this is between the frame and the outer lens)
    2) Rear passenger sedan door frame aperture / rear passenger door. (The rustier the better, I just need the window aperture to swap over).
    3) Now the long short.. Interior vinyl ceiling? (I learnt my lesson with this one, should have a) secured it when I was moving it, b) masked it when I was painting. Now it is torn at a tension point between the roof supports and all kinds of splotchy yellow
    Then, along with the new front glass and rubber I can get locally, i think I'll be all our of excuses to finish this thing..
    Dan
    Nov 2005
    Geraldton
    1,635
    Hi Bowie
    I've probably got some bits you want, but this "door frame aperture" has me confused. Is it part of the body shell or is it the hoop that has the bailey channel running around the inside? I can do either but there are total fire bans in place here and using cutting tools outdoors is a bit of a no-no.
    The doors are off, I can cut hoops off in the shed, and the body is being prepared for its Final Journey.
    P
    In the Shed(s):
    In the Past:
    Aug 2002
    3,536
    Ah sorry, yes it's the hoop that houses the bailey channel and window. When I picked this 12 up with all it's panels in boxes, we discovered one of the doors was from a wagon not long after priming it.
    So yes happy to cut my hoop out and have an adult re-weld the correct one if you have one.
    Nov 2005
    Geraldton
    1,635
    I do. I'm assuming you want both I can have them liberated from their doomed other parts afore the sun goes down.
    Posting will be the fun part...
    P
    In the Shed(s):
    In the Past:
    Aug 2002
    3,536
    It could be a fun shape to confuse the postman.
    I do only need the passenger rear, and I suppose you could nearly chop it up a couple of times if necessary..
    Jun 2004
    408
    If you've got the time and patience you could take a trip out to Riverstone and grab a door off one of the wrecks in the yard out there.
    Aug 2002
    3,536
    Tell me more! there is a wrecker out there?
    Nov 2005
    Geraldton
    1,635
    Should your investigations be fruitless I have within arm's reach my American bought, diamond-encrusted angle-grinder cutting blades poised to begin the carnage...
    Lets not confuse Oz Post.
    I await the outcome of your prognostications.
    Ex
    In the Shed(s):
    In the Past:
    Aug 2002
    3,536
    Cheers Peter!
    3006882! Spill the beans. Need anything whilst I'm out there, where ever it is. That's near enough my work to make things easy.
    Apr 2003
    249
    I have a selection of complete left rear lamps, but I am away for a few days yet. Will get back if that is what you are after
    Sent from my SM-J250G using Tapatalk
    Aug 2002
    3,536
    Thank you Melc!
    I'm actually ok! I found a rubber that was serviceable buried in the spares for the bumper bar or all place! Thank you however!
    Aug 2002
    3,536
    Wanna talk about windscreen Rubber?
    Scotts ye old rubber in Victoria can't help me anymore, I've found a chap overseas who can provide front and rear for 30 euro each! The shipping is probably going to be 50 euro however.
    I think this will do unless anyone has had more luck locally?
    1000+ Posts Shoji's Avatar
    Jan 2012
    Mandurah WA
    1,193
    Jun 2004
    408
    Sorry Bowie, I only log on occasionally.
    The company is Autobreakers in Riverstone. I can't remember the blokes name, but his number is 0402100156 (its i the white pages, so I'm not giving out someone's private number). Cnr of Edward and Hamilton St in Riverstone. He only opens on Saturdays though, and its a cash only affair where you offer a fair price, then probably pay a bit more... because where else can you find a DS or a MK1 Escort or a Fiat 850 sitting in a yard to grab that one odd bracket or a stainless light bar off.
    He's got about 4 R12s, 3 or 4 R16s, maybe an R10 and a coupe of 4CVs.
    The cars are all stacked up and sketchy, so take all your own hand tools, steel caps, mechanic/work gloves and long work trousers, because there will be spiders and possibly nope ropes. Maybe even a hankie for the tears you'll shed when you see dozens of classics rotting into the ground.
    Brisbane/Australia
    2,202
    I think you'll find the "hoop" is the same on left or right side, the channel is symmetrical.
    Aug 2002
    3,536
    Thank you RenTinTin, More excellent advice!
    3006882! I had no idea such a treasure trove existed, thanks for the warnings, I'll try my luck on the weekend..
    Aug 2002
    3,536
    Aug 2002
    3,536
    If you need a new laminated Windscreen for your Reno 12..
    AUTO GLASS WAREHOUSE!
    https://www.autoglasswarehouse.com.au/
    I paid $135 and picked it up from their factory in Western Sydney on my lunch break. It arrived in 2 days.
    WIN WIN WIN!
