R17 High Volume Oil Pump
Results 1 to 7 of 7
  • 1 Post By angru
Thread: R17 High Volume Oil Pump
    Jun 2004
    407
    Default R17 High Volume Oil Pump
    Hi brains trust,
    The never ending build continues and I'm now thinking about the larger volume oil pump from the R18, but I've never laid eyes on one to know anything about it.
    I know they are increased depth driver in rotary pump, but am i right in assuming that this would require the R18 pump housing as well to increase the pump output in a standard R17 engine?
    Adam
    1000+ Posts driven's Avatar
    Apr 2005
    1,548
    Bigger pump, bigger HP required
    9,261
    Nope. The extra thickness is taken up by a deeper recess in the block so you need to machine your block or you need to get a block.
    ACHTUNG ALLES LOOKENPEEPERS
    Ipswich, Queensland.
    1,943
    The 6mm deeper pump is taken up by a recess in the pump housing that bolts to the block. You could perhaps deepen the recess in the block to use the standard inlet, but I donít know how much metal there is available in the block casting.
    The R18 GTS and R17G both had the bigger pumps, but different inlets, that both work having the same sump, but not with the R16 sump. The R18 inlet is fully cast aluminium, where the R17G has an aluminium housing with a steel inlet pipe and strainer.
    Jun 2004
    407
    Well that answers that then, just don't create oil restrictions or temp increases
    9,261
    What engine are you building?
    Dec 2010
    467
    Mecaparts sell the 17g/12g pump. You buy it as the 2 parts (shaft and inner and the outer). If using a 16 or 17 block you’ll need to use the housing from a 17G or you can also get a laser cut plate that sandwiches between the block and the housing to make it fit and work with standard 17tl housing. I think Mecaparts sell them. I know alpine affaire had them in stock a while back.
    Shoji likes this.
