From the sublime to the rediculous
Results 1 to 9 of 9
Like Tree5Likes
  • 1 Post By Stuey
  • 2 Post By Fordman
  • 1 Post By bowie
  • 1 Post By Breitie
Thread: From the sublime to the rediculous
    Manly West, Brisbane
    388
    Default From the sublime to the rediculous
    During the past two weeks I have bored everybody to death with questions about doing a coolant change on my Koloes, which I have finally accomplished. (clapping and cheering all around!)
    I won't tell you how I did it and what I used because you will most likely suffer apoplexy.
    Now, the radiator has a tiny white plastic plug and washer at the bottom for the draining thereof. The workshop manual says: "Remove plug" with an arrow pointing to the plug. Just to be safe I thought I might get a spare plug in case I damage it or lose it as it is tiny and made of soft plastic. As one would with an oil drain plug and washer that are available from Supercheap.
    Now the kicker: Renault does not sell this plug separately! To get a spare plug I will have to buy a whole radiator!
    The forces of making life difficult have finally conquered my ever indomitable spirit. I GIVE UP!
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,252
    Quote Originally Posted by Breitie View Post
    That goes with lots of things that Renault sell.
    I wanted the little silicone pads that optically connect the auto wiper sensor to the windscreen, to get the silicone pads i have to buy the sensor. I didn't ask what the cost of the sensor was.
    The parts salesman then offered me an alternative which i took, I think the part was from a Subaru for about $40.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    6,643
    Errrr; I wasn't serious about Blue Gatorade...
    JohnW likes this.
    2003 PEUGEOT 206 GTi
    1000+ Posts Fordman's Avatar
    May 2004
    Perth/West Australia
    1,470
    At least you had a drain plug fitted. I would have just used it.
    As far as I know, our Scenic doesn't have a drain in the radiator - one has to remove the lower rad hose, which is also fraught with danger, being a plastic radiator outlet, and a difficult to remove hoseclip.
    Most vehicles are similar these days I believe. I consider it a plus if there is a drain plug.
    Keep trying, don't give up, it will mean they have won!
    Cheers.
    Berridale and JohnW like this.
    2004 Scenic I 2.0 auto (Hers)
    2016 Ford Territory (His)
    2004 WRX (Sunday car)
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    18,212
    I suppose that the workshop manual was in fact a Renault one? I have found that the word "carefully" can be added to almost any operation described in anyone's workshop manual............................
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,484
    Oh well, suppose you better make it your race car now
    FIVEDOOR likes this.
    Brisbane/Australia
    2,139
    336_pdfsam_Koleos - Engine and Peripherals.pdf
    According to the manual the drain plug is just a screw-in nylon plug.
    You could probably find a brass bolt with the same thread and length and use that.
    Doesn't look anything high-tec.
    I would expect that Renault buy their radiators from a third-party so it's probably a common size and other Korean cars may be suitable.
    Try looking for a Samsung QM5 rather than Koleos.
    Bleeding looks a bit primitive, you have to disconnect the top heater fitting then reconnect when coolant comes out. No nice brass bleed screws like with the 'real' Renaults of yesteryear.
    RTT
    388
    Love your sense of humour Mr Stuey.
    Actually, here is an interesting fact: Gatorade is exactly the same price as Nulon Long Life Green coolant at $2.50 per litre when mixing 6lit concentrate with 12litres of water - a ratio of 1:2 as specified. (6lit concentrate makes 18lit coolant.)
    That means that Nulon coolant is incredibly cheap or that Gatorade, which is just sugar and water, is inordinately expensive. I think the latter.
    Hmmmm!
    Sunroof likes this.
    11,104
    Gatorade is a ridiculous price, as is bottled water at up to 1000 times the price of what is delivered to the house tap in usually excellent condition. Cons, the pair of them. I could go on and get excited but I'll resist.
    Good you changed the coolant. If you use a 5-7 year one, it might not be done again before the car is scrapped.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
