Clutch cables 807 motor with 395 g/box
Like Tree4Likes
  • 1 Post By Virage Racer
  • 2 Post By COL
Thread: Clutch cables 807 motor with 395 g/box
    Fellow Frogger! Virage Racer's Avatar
    Jun 2002
    Perth Western Australia
    152
    Default Clutch cables 807 motor with 395 g/box
    Hi All
    My memory is failing me. Just extracted a sad-looking clutch cable from my Gordini faker which runs 807 motor and type 395 gearbox. The cable I removed is significantly shorter than a 12 spare I have on hand - it measures 630mm mount-to-mount as opposed to 800mm for the 12 cable.
    Is the 630mm cable from the 18GTS - or is it another model?
    Someone please enlighten me!
    Keith
    bowie likes this.
    Keith
    1976 12 Gordini Faker
    WA's only 12 in regular club comp
    1000+ Posts driven's Avatar
    Apr 2005
    1,516
    Just use the 12 cable matters not what length, could be 16, 18, Fuego
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,252
    You can do this or you can shorten it your self.
    I shortened up an R12 cable by cutting off the inner at the clutch pedal end, removed the inner cable from the outer sheath. Can't remember what end now but managed to remove the sheath fittings from one end and used one of those skinny cut off wheels to shorten the sheath to the required length.
    I done the same for the inner and then put the inner inside the sheath.
    Then went to see a cable making guy to crimp on a swage fitting back on the inner and then re-install.
    Of course if you are not upto all this you can get the cable guy to do the whole job for you.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Jun 2002
    152
    Yes, could make the longer 800mm cable work with some creative re-routing if I had to. However, the 630mm sheath is a nice straight trajectory which slips neatly between alternator and brake master cylinder, also slightly tensioned away from the twin weber throttle cable which is at the right hand side of the setup.
    Shortening the longer cable is definitely an option, but oddly I have now discovered a just-serviceable second 630mm cable among long-forgotten spares salvaged from a similarly set-up car. So the 630mm cable must be a thing - maybe for LHD versions of the 12 rather than the RHD version? Curious.
    Thanks guys
    Keith
    COL likes this.
    Keith
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,252
    Quote Originally Posted by Virage Racer View Post
    Thanks guys
    Keith
    The 630 mm cable is from the R17 and R15 with the 807 engine.
    Sunroof and Virage Racer like this.
    Regards Col
    1973 Alpine A110
