fuel tank sender unit for an R4
Results 1 to 13 of 13
Like Tree2Likes
Thread: fuel tank sender unit for an R4
    May 2019
    Mount Compass, South Australia
    42
    Default fuel tank sender unit for an R4
    Hi all,
    I have an unexpected problem with the R4 I am restoring. The car has been converted from the original 6volt set up to 12volts - well almost! There are still a few items that have not, such as the wiper motor,the heater fan motor and the tank sender unit. I am having trouble finding any of these items. The sender unit is, for obvious reasons, the most pressing item. I've tracked down a 12 volt unit at Franzose, but the info on them seems to suggest that the tanks are different and a 12 volt unit may not fit the 1963 R4 tank I have. Has anyone else come across the same issue, and is there a 12v sender unit I could use, or a work around? I am facing the complication of setting up an entirely different tank and sender unit, with all the hassle that the fitting of a different tank and supply pipes. HELP!
    Ron
    9,310
    No need to worry.
    If you're somewhat literate with electrics and have a basic multimeter you can convert your existing unit to 12V easily.
    Your sender unit is just a resistor that is using some sort of special wire (easily found in shops) to give a varying signal to the in dash meter.
    Measure that resistor (highest value is what you need). Pull the wire out, measure its length. Divide resistance by length and you have the constant of that wire. You need to go buy a wire with twice that constant (or close to) and replace the wire you pulled out.
    You can buy resistance wire from Jaycar, Altronics, RS components and most likely many others I don't know about. Have a search for nichrome wire.
    You're welcome.
    A nice bottle of red should do it.
    ACHTUNG ALLES LOOKENPEEPERS
    May 2019
    42
    Thanks Schlitzaugen,
    I'll give it go when the end of year dust settles. Much appreciated as I am desperate to get this little car going - after I deal with all its strange issues.
    Ron
    Lavers Hill
    321
    Alternatively you could get a 12v to 6v converter (Jaycar used to sell kits) and feed the fuel sender the 6v it wants.
    If you convert a 6v car to 12v I think you would have to change both the sender and the gauge, wouldn't you??
    If you have already changed the gauge to a 12v one, then yes you will need a 12v sender.
    Sorry I have no knowledge of R4s but do know a bit about electronics.
    9,310
    The dial is most likely an ammeter, so I think it will work fine as is.
    May 2019
    42
    Hi Simca1100,
    A visit to Jaycar has been on my to-do list for a while -this episode will bring it on sooner, but I am holding off as every day brings forth a new electrics issues. I had been lulled into thinking more 12 volt stuff had been done, but not so. On top of the problems I have already mentioned I am also aware most, but not all globes have been replaced- I wonder if the interior light will work?
    Ipswich, Queensland.
    1,958
    I would expect the fuel gauge would be a 6V voltmeter and that at full the sender takes the negative side to ground giving a full scale deflection on the fuel gauge. The resistance builds In the sender as the tank empties dropping more voltage across it, reducing the deflection on the gauge. It may be possible to measure the full resistance of the sender and put a resistor of the same value in series between the gauge and the sender to allow the gauge to work reasonably on 12V. The wattage of the resistor would not have to be huge but might be worth putting a 5 Watt one in.
    I cannot guarantee the outcome will be successful, but the experiment should be easy and inexpensive, and might even work or give you lead on how to progress.
    '56 Renault 4CV (16TS Power)
    '62 Renault Dauphine Gordini
    '82 Renault Fuego GTX
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,331
    You may want to have a read of these links, it may answer some of your questions.
    Making a 6v to 12v Conversion Easy!
    Converting From a 6 to 12 Volt Electrical System
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    9,310
    I thought about that as well and wrote an entire post with the same suggestion, but if that is the case, the resistor solution will mean the meter might lose one end or the other of the scale depending on circuit design and/or where you place the "ballast" resistor in circuit. I deleted these details as I thought it unlikely based on my experience with similar vintage cars (it's more complicated to build for the manufacturer).
    But, if that is the case (gauge is voltmeter) my suggestion would be to leave everything as is and just bring the voltage down to 6V for this circuit using a linear voltage regulator IC, which is cheaper even than the nichrome wire:
    https://au.rs-online.com/web/c/semic...ons=4294574133
    I would wire that in such a way that the ignition switch disconnects the IC otherwise you will have a (small) current drain even with the ignition off (I guess this is simple enough because the fuel level gauge only comes on with the ignition anyway). 2.2A should be plenty for the fuel level circuit. Heck, I reckon you could power the entire dashboard with one of those.
    May 2019
    42
    That's interesting because a friend of mine, who seems to know about these things also, suggested that as a possible answer to keeping my windshield wiper with it's 6 volt motor. He also suggested that another, cheaper, inline regulator, was to splice in a 6volt light globe along the feed line to bring down the voltage . Don't know if I'd be game enough to try it for the fuel line tho'. I did find another , slightly better 6volt sender unit in my box of spares.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,331
    Regards Col
    1973 Alpine A110
    9,310
    Yeah, the 6V inline globe is a pikie sort of solution. That will peg the current draw and you don't want that. An IC regulator as above is practically invisible by the rest of the circuit.
    For the wiper motor however you might need more than 2.2A, I would look at something in the region of 10-15A.
    May 2019
    42
    Thanks Col and Schlitzauger. I'll make a start when the current heatwave pisses off Not much fun outside at the moment. I'll keep you posted when I make a start.
    Ron
