Renault Scenic drive-shaft boot bearing?
Results 1 to 2 of 2
    Jerangle
    812
    Default Renault Scenic drive-shaft boot bearing?
    Renault Scenic 2 litre 2001, manual, pass side driveshaft.
    There are two driveshaft sizes a 26mm and a 28mm.
    I need the 28mm boot kit and bearing.
    What other Renault has the larger driveshaft?
    Clio or later Scenic?
    So i can get the correct boot kit and bearing.
    I have been sent the wrong boot kit despite requests to check the bearing size, this was ignored.
    Jerangle
    812
    28mm bearing is available in Estonia on eBay.
    Otherwise re-use the old bearing.
