Scenic RX4 window mechanisms
Results 1 to 8 of 8
    Jul 2011
    Castlemaine VIC
    367
    Default Scenic RX4 window mechanisms
    It is a 2002 model that needs the rear window winder mechanisms replaced. Bought the car for "not much money" so hopefully these can be located somewhere and the car can be put back on the road.
    How would I go about getting a workshop manual ?
    Help would be appreciated as this "modern" car is very differant to what we're used to.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,293
    Try Ebay and see if any of these look like yours.
    https://www.ebay.com/sch/i.html?_fro...anism&_sacat=0
    Here for a manual maybe
    https://www.ebay.com/sch/i.html?_fro...orkshop+manual
    Someone may have an electronic version they can email you.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Fellow Frogger! Trading Estate's Avatar
    586
    You tube has full videos of this process (unfortunately a common occurrence on Renaults). It may only need the electronic thing that each window has. Generics available on Ebay. if it needs the regulator ( ie frame and cables) its not an easy job but doable following the videos but regulator assembly could be exccy. Ring French Connection?
    '04 Megane
    Gone but not forgotten
    '71 16 TS, '72 16 TL, '74 15TS,'82 20TS Series 2, '85 25 GTX. '49 L15,
    Nov 2002
    Yarrabilba, Queensland
    2,759
    Contact Powerwin in Banyo, Brisbane.
    James was a member of the RCCQ for a few years and his company have parts to fix all window mechanisms.
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    18,381
    Quote Originally Posted by IDear View Post
    What usually kills the Scenic electric windows is not a failure of the motor or winding mechanism, but the disintegration of a small plastic part which is responsible for transmitting the up-down motion to the glass. I researched the part in Europe and they cost around 4-5 Euros each. I traded the RX4 on the Koleos thus fixing the problem..........
    Brisbane/Australia
    2,170
    Ditto what Kim Luck said, the plastic clips that attach the mechanism to the glass break often but are cheap and readily available through Ebay etc. The rest of the window winder mechanism is pretty reliable as they don't use cables that break and are simple electronically.
    The 4WD and 2WD window mechanisms are the same and, for a Renault, aren't too hard to remove.
    I have a MR313 manual that shows the window removal procedure if you want to send me a PM with your email I can forward it to you.
    The quality isn't fantastic but it's legible.
    RTT
    tweed heads
    1,524
    I have a bunch of parts for 2000 scenic including 4 winder mechs 'glad to see them go to a good home , no charge ,send me a pm ,pugs tweed heads
    Jul 2011
    Castlemaine VIC
    367
    Thankyou for the great feedback and Pugwash, I might take you up on your offer. My mate is taking the mechanisms out so I'll see where he is at. Be great if we can get them working.
    Michael
