4CV widies
Results 1 to 25 of 29
Like Tree16Likes
Thread: 4CV widies
    1000+ Posts J-man's Avatar
    Littlehampton, S.A.
    23,614
    Default 4CV widies
    While I've had some time off this month, I had a bit of a tinker with Brian the 4CV.
    What I don't understand is why my R10 widies stick out the front guards so far, when some 4CV's seem to have widies within the front guards?
    Obviously my rims have significant dish, which doesn't help, but even standard R10 rims are right out to the edge of the front guards on my car. It has a R10 front end in it, but that's nothing unusual.
    They're 175/65R14 on 5" rims.
    cheers,
    John
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,770
    John's 4CV has king pin front end with R10S discs and calipers.(All round)
    Ray
    Ray geckoeng
    Think Old, But Run Modern !!
    Littlehampton, S.A.
    23,614
    Thanks Ray, so guessing that means the R10 front end is wider?
    Ray
    cheers,
    John
    Ipswich, Queensland.
    1,959
    The R10 front end is certainly wider. I have 15 x 6” wheels on my 4cv on a king pin front end, but I shortened the arm about 8mm that the tie rod connects to so that it was inside the rim allowing the wheel to be inset further. My car has 4 wheel R10 discs also.
    The 4 cv has a tapered section on this arm where it connects into the hub assembly, so I just ran this back on the lathe. There is a key to locate this arm. I run 195/50/15 tyres that run well inside the guards. If getting the wheels made again I would probably offset mine another 8 mm outward. I can give you my wheel info but it won’t be right for your car with the R10 front.
    '56 Renault 4CV (16TS Power)
    '62 Renault Dauphine Gordini
    '82 Renault Fuego GTX
    Littlehampton, S.A.
    23,614
    Thanks Alan, much appreciated. My car is a long way off seeing the road with my situation but planning is something I can do plenty of.
    I was hoping to end up with your tyre/rim size combination in the end but putting the widies off Clive the R10 highlighted the track issue.
    cheers,
    John
    Oct 2019
    Bridgetown W.A.
    16
    Hi J-man, the wheels on our car (pictured in your initial post) are 5.5 outers on 16 centers. Inside offset is the same as 10s rims with the extra inch on the outside of the rim. Tyres are 175/70 14 Continentals. Everything clears and the car feels really good on the road.
    Hope this is helpful.
    Regards Clint
    Littlehampton, S.A.
    23,614
    Hi Clint,
    Thank you for that. Your car is fabulous by the way
    cheers,
    John
    11,295
    Quote Originally Posted by J-man View Post
    Hi Clint, Thank you for that. Your car is fabulous by the way
    It is indeed! Very nicely done. I didn't realise how Alan had shortened his tie-rod arms - clever approach and very sound. I'd like some of those skills...
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Feb 2005
    rosevale/tasmania
    2,870
    My beastie has an R10 front end (R10 crossmember with 4CV longitudinal chassis rails cut, shut & reinforced to receive it) & 4.5x14 front wheels. Wheels are standard offset, so .25" in & .25" out. plus a couple of mms extra offset in virtue of a reinforcing ring for the cut-down R10 centres. Tyres are 165/70 PC2 Contis.
    So, compared to some others here, a very conservative front end. The vehicle itself was sufficiently modified to require departmental approval, engineer's certificate & so on.
    The engineer baulked at the protrusion of even such a conservative wheel/tyre modification beyond the 4CV guards & they ended up flared (which I at least rather prefer to the original).
    cheers! Peter
    Littlehampton, S.A.
    23,614
    Your 4CV was one of the cars I was trying to find a picture of to see how yours looked with its widies Peter. I think you put photos of your 4CV in the 4CV thread from memory but I hadn't spent much time looking for it.
    cheers,
    John
    Feb 2005
    rosevale/tasmania
    2,870
    Yeah; we'll see if my attachment attempt works below.
    Attachment 117461
    11,295
    Nice photo Peter. Such a pain trying to post here... If I click on the photo it opens. If I click on the text hyperlink I get an "invalid attachment message".
    Anway, it's up, regardless of the contradiction!
    Littlehampton, S.A.
    23,614
    Thanks Peter.
    Did you add metal to your front guards or are they just the original guards reworked, and very well I might add.
    There's a lot of different interpretations of 4CV front guard flaring. Yours looks nice and subtle.
    Are the rear guards touched?
    cheers,
    John
    Feb 2005
    rosevale/tasmania
    2,870
    Thanks Peter.
    New metal (+ smoothing bog) at front. Rears had a widening strip inserted (rear wheels are 5.5 with 185/60 & rather more offset - I favour a size difference of around 20 mm front/rear).
    The work was done by the engineer who signed off on it (as was the roll hoop cum half-cage, front fuel tank & rear bracing bars).
    Feb 2005
    rosevale/tasmania
    2,870
    Luckily it's an old photo which was already in AF's store so I only had to drag it down to the insertion row. I have no idea how to work around the new protocols (there was a discussion thread on this but . . . ).
    Still, mustn't grumble. AF is a nice institution & I am grateful to whoever has organised &/or funded it.
    Littlehampton, S.A.
    23,614
    Have any of you successfully reduced the front positive camber or even provided negative camber on the R10 front ends? Using the spirit level vertically against my front wheel, I could bring the top of the wheel in a good 10mm and only giving it slight negative camber in the process, which would reduce the guard flaring necessity slightly, plus a reduction in tyre width on the front tyres would bring it in another 5mm.
    I can't see an easy way of bringing the top arm in though. I assume the cross-member has a tube insert for the upper control arm inner mounting bolts? which would make re-drilling the mounting further inboard a problem I've also read about relocating the ball joint inboard, but looking at it, doesn't look like a simple process either. Cut and shut of the arm would be a peace of cake, however illegal and not recommended.
    cheers,
    John
    1,959
    From what I remember of the R10 front end, you can slot the lower wishbone mounting points on the cross member outwards , or weld them up completely and re-drill the holes. An 8mm slot would probably give you maybe a degree of negative camber.
    Littlehampton, S.A.
    23,614
    Thanks Alan, part of the reasoning for the exercise though is to reduce the size of the wheel arch flare I'd need to keep the Gendarme at bay and I'm not so keen on large wheel arch flares.
    cheers,
    John
    1,959
    Pushing the lower arm out 8mm, may well give you 16mm inward at the top of the tyre. I have around 2 degrees negative camber on the front, and possibly the same on the rear of my 4CV.
    Littlehampton, S.A.
    23,614
    That sounds like a plan Alan
    No issues with achieving correct toe after your mods? Actually, with the tie rod end sitting around midway on the stub, I'm guessing that might not be an issue.
    I might have a tinker with the lower arm mounts and take some measurements before and aft.
    cheers,
    John
    1,959
    I have some aftermarket adjustable tierods that have a ball joint inner that are made to fit A110s on my 4CV. I did shorten it a little, but can’t remember how much. It is like a modern tierod and adjusts in the middle.
    11,295
    They are also available for the 4CV these days. Look good but I have spare near-new ones and new ones on the car, so they'll last way longer than I do!
    I have a pair of the easily-adjustable R8 ones too, in a box. So much better than having to pop the ball joint to adjust toe-in, although I guess popping the ball joint tapers more often does help reduce seizure!
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,333
    I have some aftermarket adjustable tierods that have a ball joint inner that are made to fit A110s on my 4CV. I did shorten it a little, but canít remember how much. It is like a modern tierod and adjusts in the middle.
    I think the ones that Alan & John have are from the R5 but may pay to check before purchase because I have been known to be wrong before.
    They are also available from the usual European suppliers.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    11,295
    I think the ones that Alan & John have are from the R5 but may pay to check before purchase because I have been known to be wrong before. They are also available from the usual European suppliers.
    http://bretagneautoretro.fr/crbst_79.html for early 4CVs and similar ones with larger tapered pins for the later cars
    http://bretagneautoretro.fr/crbst_175.html for R8.
    I presume they aren't R5 but I've not seen an R5 front end up close and personal!
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,333
    Hi John
    Your second link is what I have in my Alpine A110
    https://www.ebay.ie/itm/Renault-5-MK...-/223485147917
    https://www.ebay.ie/itm/Track-Tie-Ro...-/142403970270
    Looks like the 4CV is slightly different, like I said have known to be wrong.
    Regards Col
    1973 Alpine A110
