Dauphine Rear Hubs Torque Setting
Like Tree5Likes
  • 1 Post By geodon
  • 3 Post By jaahn
  • 1 Post By JohnW
Thread: Dauphine Rear Hubs Torque Setting
    Jan 2013
    Geelong
    530
    Default Dauphine Rear Hubs Torque Setting
    I'm doing the pre-RWC checks & noticed I haven't pinned the rear hubs.
    Can someone tell me what the setting should be?
    I'm used to "real tight" then back off to the nearest hole for the cotter pin.
    1949 Citroen Big 6
    1955 MGA1500
    1970 Peugeot 404 Utility (Resto project)
    1962 Renault Dauphine Gordini (Resto project)
    1950 Grey Fergie Tractor
    Simon's Avatar
    6,203
    20-25 mkg, or 145-185 lb/ft.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Jan 2013
    Geelong
    530
    Thanks Simon
    That surprises me.
    VW are 217lb/ft but the nut is 36mm up to 42 on Kombi's
    1949 Citroen Big 6
    1955 MGA1500
    Jan 2013
    Geelong
    530
    Actually, those numbers are logical. I forgot the Dauph's hub nut is 30mm
    So! Liquid paper to mark the hole for the cotter pin & a rubber tube to protect the threads on the wheel stud.
    My torque spanner only went up to 120 ft/lbs. I weigh 80kg so I stood on the socket arm a foot out from the pivot point. Then just a tweak more to get the pin in.
    Simon likes this.
    1949 Citroen Big 6
    1955 MGA1500
    Newcastle
    2,669
    Hi
    You should not tighten then back off to the nearest hole. You should just try to get to a split pin hole lineup within the torque range.
    Jaahn
    COL, Sunroof and JohnW like this.
    10,943
    Hi You should not tighten then back off to the nearest hole. You should just try to get to a split pin hole lineup within the torque range. Jaahn
    Yes, I get mine up to the middle-upper part of the range on the big torque wrench and then heave it along to the next split pin hole with a big breaker bar. It's reasonably tight then..... Before that, it was just as tight as I could get it, not a good method judging by loose and worn splines on old 4CVs back in the $100 student car days!
    Shoji likes this.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
