Assistance with oil leak on Renault 16TS drive shaft
Results 1 to 8 of 8
    May 2015
    Howlong Australia
    2
    Default Assistance with oil leak on Renault 16TS drive shaft
    I have a manual for my 16TS however it doesnít cover how to remove a drive shaft
    My 16TS has an oil leak where the passenger side drive shaft goes into the gearbox
    i assume there must be an oil seal that needs replacing however I canít find any information on removing the driveshaft and replacing the seal.
    Can someone give me some advice or a link that may help.
    Regards
    Francis
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    4,339
    If you PM me your email I will scan the relevant pages from the Haynes manual I have here and email them to you.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    1000+ Posts driven's Avatar
    Apr 2005
    1,570
    Original Renault workshop manual on Gumtree $20
    https://www.gumtree.com.au/s-ad/nora...ual/1227218229
    or eBay Haynes $18 from UK free postage
    9,324
    Or you can buy the .pdf and get it now.
    ACHTUNG ALLES LOOKENPEEPERS
    May 2015
    Howlong Australia
    2
    Thanks very much
    My email is
    chadwick448@hotmail.com
    Regards
    Frank
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    4,339
    Quote Originally Posted by George4 View Post
    Thanks very much
    My email is
    Regards
    Frank
    Finally got around to sending you an email, apologies for the delay.
    Regards Col
    1973 Alpine A110
    Apr 2014
    kilsyth (lower montrose) vic,
    224
    Hi Frank, Just be wary of inner joint of drive shaft and not to fully extend it otherwise it can dismantle insie boot which would then require removal of boot and reassemble joint then replace boot.the drive shaft roll pin must be fully removed first before attempting to remove drive shaft from gearbox,the oilseal retaining nut also adjusts the diff side bearing pre load and back lash of diff, so before removing nut it must be marked so as it refits in the exact same position it came from (number of turns of nut and nut position in relation to housing)......just a couple of thoughts.......jim+ Reply to Thread
    9,324
    When in there I would also check diff outdrives for lateral play. The oil leak will return if any.
