instrument cluster
    Member Duffster's Avatar
    Jun 2014
    South East Melbourne (Keysborough)
    49
    Default instrument cluster
    Can anyone tell me how to remove the instrument unit ( cluster ) from a 20TS? The w/shop manual
    doesn't say much.
    Canberra ACT
    721
    Probably the same as a Fuego. There are two Phillips head screws at the bottom of each corner and you remove them. You carefully lift up the whole instrument panel and remove the connections to the instrument panel and then the connections switches for hazard warning lights, fog lights, rear wiper, driving lights etc. Then remove the connections to the instruments - tacho, fuel/oil level gauges and the cable from the speedo (very carefully as prone to break). I might have the order of removal wrong but you should be able to work it out.
    Simon's Avatar
    6,203
    Which dashboard? Early or late?
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Jun 2014
    49
    Quote Originally Posted by bazzamac View Post
    Thanks for that, will have a look.
    Jun 2014
    49
    Not sure, but it is an'83 1272
    Jun 2014
    49
    It's out thanks. Someone has been there before....what a mess.
