Ball Joint Separator Tool - R8/10
Results 1 to 25 of 28
Like Tree10Likes
Thread: Ball Joint Separator Tool - R8/10
    671
    Default Ball Joint Separator Tool - R8/10
    Hi Everyone
    I recall some years back buying a ball joint separator from Supercheap to separate the ball joints in my R8.
    I was made of a cast material, but so weak I ended up breaking it.
    I ended up cutting and bashing them out (not ideal of course) as they appeared to have been the orginals - some 50 years in place.
    Anyway I need to do the job again on a R10 where again they appear to be the original fitment (+50 years old).
    I purchase a tapered folk tool, which I was told would do the job (where you slide it in between the boot and the stub assy and hit the end. That was useless also and even with copious amounts of WD40!
    I would like to buy a decent tool, and there are a range for sale at Repco, Autobarn, Bursons etc but don't know which on to get.
    Can anyone recommend a decent ball joint separator tool that will work first time without breaking anything?
    Angelo
    Fellow Frogger! Jensen's Avatar
    388
    I’m in the market for one too.
    Was the one you broke like this?
    https://www.totaltools.com.au/128061...BoCpKQQAvD_BwE
    2002 Monaco Blue Renaultsport Clio 172
    1975 R1317 Renault 17 Gordini
    Mar 2012
    65
    I had some success using Loctite "Freeze and Release" https://www.autobarn.com.au/loctite-...rosol-310g-far
    It is a combination of a penetrating agent like WD40 and butane to cool and shrink the part and break any corrosion binding. Was the only thing that let me drift out a wishbone pin that had been in place for 50+years without resorting to oxy or a jackhammer.
    Then just judiciously apply the two hammer technique and smile as the joint pops apart... :-)
    1000+ Posts pgti6's Avatar
    May 2001
    1,654
    Not familiar with the R8/10 arm but I use one of these on my 405.
    https://www.kincrome.com.au/tie-rod-end-pitman-arm-pull
    405 Mi16 2.2 litre race car up for sale soon. For details contact me on 0438 106 430.
    Lap times- Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205 Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    1000+ Posts Frans's Avatar
    Auckland
    1,557
    Hi All,
    I use a piece of threaded rod M10 if I can remember correctly (lubricated) and a tube were the ID can go over the rod. Apply as per drawing and turn the nut with a spanner. If it doesn't crack by it self, there is so much tension on it that it releases quick and easy with a knock from the hammer. The other side can be done with another piece of tubing a little longer to take the place of the released ball joint.
    Work out the lengths your self as mine is packed away for the move.
    Frans.
    COL, Dano, bob and 1 others like this.
    Old enough to know better
    Young enough to do it anyway.
    671
    Yes its was, although can't recall the brand, but it was this style.
    11,310
    Hi All, I use a piece of threaded rod M10 if I can remember correctly (lubricated) and a tube were the ID can go over the rod. Apply as per drawing and turn the nut with a spanner. If it doesn't crack by it self, there is so much tension on it that it releases quick and easy with a knock from the hammer. The other side can be done with another piece of tubing a little longer to take the place of the released ball joint. Work out the lengths your self as mine is packed away for the move. Frans.
    I think that is the form of the original factory tool Frans. The beauty is that the tool works in compression against the strength of the forged stub axle assembly.
    I have a quality "Litchfield" ball joint tool. It's fine for the tie rod ends but not up to the suspension ball joints when well frozen. At least, I'm not prepared to tighten it ridiculously until something breaks. It's probably the same style as the cheapo one that broke, but with better quality materials.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    4,427
    I’ve often just hit them with a hammer each side at the same time with the nut loosened, in order to break the taper.
    JoBo, Kenfuego and driven like this.
    KB
    11,310
    Mine have only been replaced once, I guess at about 35 years. I guess that is why it can be trying, if it is only every few decades....
    Apr 2013
    Essendon
    701
    Angelo, please PM your location and contact details.
    John
    Simon's Avatar
    6,203
    The Renault tool needed is T.AV.55a
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    671
    Thanks Simon.
    I have a picture, but I need it in the flesh!
    Feb 2001
    Romsey, Victoria, Australia
    4,904
    We've just used the splitter fork thing. Just a large fork on a tapper that you just bash with a hammer. Being on a tapper the balljoint has no choice but the separate. You will damage the rubber but if your replacing it that doesn't matter.
    driven likes this.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    frenchconnect@bigpond.com
    671
    Quote Originally Posted by David Cavanagh View Post
    Thanks Dave
    I purchased one a few weeks ago from Repco, and tried it, but it was too long and to get the right angle to take a decent swing at it was impossible (from under the guard). Hitting it from the side was also impossible at the pointy ends of the fork was striking the rails in the body. I might try cutting the ends off (to shorten it) and give it another try tonight on my R10.
    Just thought there must be a 'better way' of doing it.
    I am probably going to make up something as I will need to use it for a 'future project'
    Angelo
    5,509
    That's what i do and it always worked. A heavy hammer on one side and hit it with a big hammer on the other side - easy.
    "The enemy of knowledge is not ignorance, it's the illusion of knowledge"
    Stephen Hawking
    671
    Quote Originally Posted by JoBo View Post
    I did an R8 a few years ago and now the R10 and both have been 'pigs' to get loose!!
    11,310
    I received this description today of the actual factory tool, pretty much the same principle as Frans' one:
    I quote, " a similar tool can be made using a large bolt and nut with suitable recesses drilled in their ends. The recesses are 4 mm deep x 10 mm diameter, the large nut is 42 mm long & the bolt is 38.5 mm overall. When both are screwed together the overall length of the tool is 52.5 mm. The tool was made by Wilmonda and the number stamped on it while very faint looks like RPR1671."
    Frans, you are MOVING? Phew. Good luck with it and I hope you get a bigger cave! Best wishes as ever.
    Frans likes this.
    9,343
    The fork is a caveman tool, yes it can do the job but it will take out everything it can in the process. The original Renault tool is what works (I have used one once on my R10 in the dark deep past) and it's the best. For tie rod ends you can just use the clamp one like above, shouldn't need too much force (I use that one to pull R12 hub balljoints, so it's up to the task).
    That original R10 tool is easy to make, but you need a strong (grade 12 or so) bolt, with fine pitch thread. I would go for M10x1mm. I think that was the original. Theirs I think is also some really strong steel, perhaps M2 or such, because the threads on it looked perfect after years of use (I had borrowed it from a mechanic). Grade 12 is not that tough, but it will do.
    ACHTUNG ALLES LOOKENPEEPERS
    Dec 2010
    471
    Best and safest way to not damage anything is a hammer. With another solid object behind it. It’s a tapered fit so just a decent knock to shock it out.
    9,343
    The hub carrier on these cars is cast steel. I doubt banging it has no adverse effect. Mind you, I don't like to hammer my cars.
    1000+ Posts driven's Avatar
    Apr 2005
    1,574
    Bush Mechanic returns.
    So easy, just undo the nut a turn or so on the ball joint
    DO NOT REMOVE NUT unless you want to DIE
    Now just take the car for a run over a rutted road.
    Actually any road in Melbourne will do
    Ball joint should have separated
    Auckland
    1,557
    Yes John, I cannot believe it myself. It is a nightmare here at the moment and this is my last weekend. The truck arrives here on Tuesday to load. The bigger cave will come when I have my extra shed built. Not much bigger but at least it will be level, not like this area I have now where you can't put a screwdriver down or a socket and it runs away into a drain, and the trestles must be spaced with blocks of wood to get the car stable in the air.
    Frans.
    11,310
    Yes John, I cannot believe it myself. It is a nightmare here at the moment and this is my last weekend. The truck arrives here on Tuesday to load. The bigger cave will come when I have my extra shed built. Not much bigger but at least it will be level, not like this area I have now where you can't put a screwdriver down or a socket and it runs away into a drain, and the trestles must be spaced with blocks of wood to get the car stable in the air. Frans.
    Good luck is all I can say! Moving is hard work!
    Kenfuego likes this.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,353
    Quote Originally Posted by R8 Dream View Post
    Thanks Simon.
    I have just found mine in a job lot that I bought from the good ol US os A.
    I have managed to identify about 50% of the tools in that job lot, just identified another thanks
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    9,343
    Can you let us know what size the thread it is, Col? Just for curiosity sake. And I would also ask if you could try a file on it see if it bites to check if it is indeed tool steel.
