R16TL four speed gearbox to build a R8 "big box"
Results 1 to 25 of 28
Like Tree10Likes
Thread: R16TL four speed gearbox to build a R8 "big box"
    Aug 2011
    BÝmlo, Norway
    67
    Default R16TL four speed gearbox to build a R8 "big box"
    I have allready a R5 Alpine five speed gearbox(similar to the R16TX box but bellhousing fits Sierra engine) that I plan to use to build a five speed "big box" for my R8 but Im afraid its a bit to complicated.
    A R16TL four speed gearbox have turned up for sale. As I understand building a four speed "big box" is a lot easier. Simply switching the new internals into a 330 case and making up some diff bearing carrier spacers?
    Will any R16 four speed be suitable?
    1000+ Posts Frans's Avatar
    Auckland
    1,534
    Hi Reidar,
    Seems nobody can answer this. When you say 16TL is up for sale, do they have the crossflow engine in?
    Remember the R16 was a 1455 non-crossflow engine with possibly a different block and bell housing.
    I would chance an answer to your question. If it is a crossflow engine with either Solex or Weber Carburettor son then it should fit.
    Regards, Frans.
    PS. This link is to my method of big-box modification with equal spacers on either side of the box, all others do it differently with one thick spacer and the then the offset of the wheelbase is rectified by mounting the motor and gearbox assembly 6mm to the opposite side so that the wheels are back to the centre. R16 internals in R8 Casing
    Old enough to know better
    Young enough to do it anyway.
    9,233
    Does it matter what engine size it was to the internals of the g'box? That's all he needs.
    ACHTUNG ALLES LOOKENPEEPERS
    Jun 2019
    Brisbane (north)
    27
    I think the 'crossflow' part is what Franz is getting across. A 16TS box is needed, rather than 'TL' box that likely NOT strong enuff to take power from a 807 with twin webbers.
    Frans likes this.
    9,233
    I see.
    That said, ratios would be different too, I imagine.
    Auckland
    1,534
    I am not sure if the 1455 non-crossflow gearbox casing and internals are the same as the 1565 TS versions. I've never seen a R16 with open bonnet yet. In ZA they were very rare. I.ve seen the engine on a distance, different looking rocker cover I think.
    Frans.
    Aug 2011
    BÝmlo, Norway
    67
    Thanks for the link Frans. That thread answers most of my questions. Simon is wery clear that the box in the R16TL is more or less the same as in the TS so the box up for sale is suitable.
    I have also been a bit confused by the 2x6mm or 1x12mm spacer subject as it alters the fosition of the diff/crownwheel but you cover that perfectly in that word document.
    Jun 2018
    Norway
    137
    Just a little question regarding this subject.
    Is there an easy way to see the difference between the 330 and 336 internals? Are the diff bearing carrier spacer visible in any way?
    Trying to find out what has been done to my 330-box and doesn't have anything to compare it with.
    11,186
    I am not sure if the 1455 non-crossflow gearbox casing and internals are the same as the 1565 TS versions. I've never seen a R16 with open bonnet yet. In ZA they were very rare. I.ve seen the engine on a distance, different looking rocker cover I think. Frans.
    Non-crossflow head Frans so very different appearance. If I recall, the 16TS outsold the TL in Oz once it had been released and both were available. Of course the TS was more expensive.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Oct 2014
    Windsor 2756 NSW Australia
    638
    Frans.
    Frans, the non crossflow engine is the standard base engine in a Lotus Europa. It was very common back in the day.
    I have the original engine for my Europa from back in 1973. It had the single 40DCOE available in Australia as an upgrade from the Geoghegan dealership. The pic below is not mine but is a pretty good example of how they looked in a Europa. Block is identical to 16TS, pistons are different shape to match head and bore is less then TS, crank is shorter stroke but loves big revs.
    Shoji likes this.
    11,186
    I always was amused that Renault would have been one of the few organisations to pull a fast one on Colin Chapman. Sell a batch of tweaked standard 16 engines, then release the cross-flow 16TS. He must have been spitting.
    Jun 2019
    Brisbane (north)
    27
    I suspect some cross channel rivalry. Alpine vs Lotus. Jean Redele likely to have more influence than CC. Anyway, Lotus had their twincam and by then had worked out how to fit it into the engine room/chassis. Alternator driven by an extended camshaft. I suspect there was a fan belt driving the water pump at the inner firewall end, can't have been nice to replace!!
    Thats the big advantage of the 16 engine in mid engine config.
    I read in a period road test of the 1470cc Europa, the Renault engine deal with Lotus meant the Europa could have the engine seviced and tuned by any Renault dealer in Europe.
    Regards
    Stew.
    JohnW likes this.
    Auckland
    1,534
    Quote Originally Posted by R8RX View Post
    The only way to see that will be when the gearbox is open and you count the teeth on the pinion and crown gear. It should give you a 3.7:1 ratio. or there will be the spacer that is visible from outside.
    Jun 2018
    Norway
    137
    Thank you Frans
    9,233
    I think you can find details like these in the relevant Renault workshop manuals. Those would be useful just in case you nwant to choose a particular ratio and the manual can at least let you know if it was ever made or not. Now finding these manuals is possible but I can't say how hard it can be. Ebay france throws up a lot of good surprises all the time. Good luck.
    11,186
    Yes, look under "Renault manuals" and "worldwide" on www.ebay.fr, but do the www.ebay.com and www.ebay.com.au too. There's a surprising number of manuals out there.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,281
    Hi Reidar
    This link may be of help:
    BOITES de VITESSES
    Reidar and JohnW like this.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Aug 2011
    BÝmlo, Norway
    67
    Ray and others have varned me that the diff in the TL box is weaker than the one in the TS.
    So two days ago i picked up this:
    The seller was restoring a R16TX witch has a 385 five speed so he offered to sell me this 336 from his TS parts car. He lives a 10hours drive from me but as we were visiting my wifes family for the weekend witch brought me closer. Still had to get up 5:30am to be back for supper...
    COL likes this.
    9,233
    Result!
    Aussiefrogs strikes again.
    Simon's Avatar
    6,203
    Quote Originally Posted by Reidar View Post
    What is the index number on the TL gearbox? As a majority of the 9 x 34 crown wheel and pinions are identical between the TL and TS 'boxes.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Tadpole Lotus 47's Avatar
    Sep 2019
    South Melbourne
    17
    I've built a couple of 5 speeds for A110's using 385 donour internals, R10S case and bellhousing, Mecaparts endhousings and a myriad of R8 and hand made selector bits. All with the careful guidance of my friend Rob Sealey.
    A simpler conversion is to put R16 internals into an R8/10 case. Both conversions require a 11/12mm spacer on one side of box. Both conversions require modified U/J's to suit the beefier output shafts. I've probably made 20+ sets of U/J's, and am in the process of making a batch.
    The bigger R16 crown wheel needs to be skimmed around the perimeter to clear something (it's been awhile and I can't remember) and the box housing needs some gentle gouging as well.
    I have many photos of the 5 speed build. Happy to share
    Richard Mann
    Reidar likes this.
    657
    Richard, sharing your photos of the 5 Speed Build would be fantastic.
    And yes, Rob is a very talented guy and a great friend! He is helping me to build a Quaife lsd for my R8.
    Angelo
    Aug 2011
    BÝmlo, Norway
    67
    Hi Richard. I’m on the oposite side of the globe from you but I’m interrested in a pair or two of your U/J’s.
    Five speed pictures would also be nice
    11,186
    Hi Reidar This link may be of help: BOITES de VITESSES
    Wow. And wow again.... Thanks Col.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,281
    Hi Reidar
    BOITES de VITESSES
    Yer some amazing engineering there, way beyond my my skills.
    Regards Col
    1973 Alpine A110
