Half shaft roll pin sealing?
Results 1 to 8 of 8
Like Tree8Likes
  • 3 Post By David Cavanagh
  • 1 Post By COL
  • 2 Post By COL
  • 2 Post By don
Thread: Half shaft roll pin sealing?
    Fellow Frogger! Artificer's Avatar
    Mar 2018
    Robina
    125
    Default Half shaft roll pin sealing?
    Fitting up half shafts today & having learned sealant is recommended in this area can some of you guys please recommend the 'best' method/sealant to use & stop oil leaks in this area.
    Have rebuilt a transmission with new bearings & oil seals, 'O' rings & speedi sleeved both shaft ends.
    This was primarily done to stop oil leaks, so any additional 'experienced' help would be much appreciated.
    Many thanks,
    John.
    Feb 2001
    Romsey, Victoria, Australia
    4,822
    I thought it was just normal silicone, silastic sealant you make gaskets from. That's all we've
    ever used.
    COL, Sunroof and driven like this.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,028
    Quote Originally Posted by David Cavanagh View Post
    ever used.
    RTV sealant is all I use
    Sunroof likes this.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    1000+ Posts driven's Avatar
    Apr 2005
    1,425
    Grasshopper if you plan ahead you slip a tight rubber sleeve on shaft before fitting.
    Knock in roll pin and then slide rubber sleeve over roll pins
    No leaks, no mucking around easy
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,028
    Not a lot of room for this idea, I would think just as easy to put a blob of sealant in the holes after the roll pin is fitted.
    Sunroof and David Cavanagh like this.
    Regards Col
    1973 Alpine A110
    8,873
    Roof and gutter silicone is the cheapest option and long lasting. A rubber sleeve would be fine, but you need a rubber that can deal with oil. Silicone will be a bastard to clean up when servicing. Another option is some glue heatshrink, but I haven't tried it myself.
    ACHTUNG ALLES LOOKENPEEPERS
    Mar 2018
    Robina
    125
    Together now.
    With what may be considered expensive....JB Weld Black Ultimate RTV
    https://www.automegastore.com.au/jb-...black-silicone.
    Cheap to me means re-do & that is never an option.
    I used to have paying customers & they don't pay for that come back or the do again option!
    The mechanic/business & other customers have to make up for poor decisions/work done.
    But thanks anyway, John,
    don
    don is offline
    Fellow Frogger! don's Avatar
    Mayfield Newcastle
    436
    All seven times I've done this job with new shafts I'vealways used sickaflex sealant and joining compound
    Never had oil leeks from these fittings
    R12 R16 R20 and R25
    Sent from my SM-T385 using aussiefrogs mobile app
    robmac and Sunroof like this.
