R 16 Clutch/input/ spigot shaft oil seal
Results 1 to 24 of 24
Like Tree8Likes
  • 3 Post By geckoeng
  • 1 Post By geckoeng
  • 1 Post By bowie
  • 1 Post By robmac
  • 1 Post By R8RX
Thread: R 16 Clutch/input/ spigot shaft oil seal
    Fellow Frogger! Artificer's Avatar
    Mar 2018
    Robina
    148
    Default R 16 Clutch/input/ spigot shaft oil seal
    Need to obtain new oil seal 24 x 38.5 x 10 oil seal prefer with springed lip.
    Any contact for local source/s appreciated,
    Thanks John
    Fellow Frogger! Melc's Avatar
    Apr 2003
    246
    Try Brisbane Bearing Co in Hemmant. They have delivery at cost and sell all sorts
    Sent from my SM-J250G using Tapatalk
    4's 16's and Caravelle
    19,211
    I'd try a SKF or Bearing Service Trade outlet.
    I suspect the seal may be an imperial type.
    Mar 2018
    Robina
    148
    Tried both suggestions....not imperial & is available from NZ from one source I tried before posting to rack others brains. Thx JG
    1000+ Posts driven's Avatar
    Apr 2005
    1,550
    Mar 2018
    Robina
    148
    Thanks but 38.5mm not 38mm
    9,262
    Do you have a CBC (Consolidated Bearings) or BSC Motion Technology outlet somewhere near you? If you give them sizes, they'll post out. Be sure you mention it needs to be Viton.
    ACHTUNG ALLES LOOKENPEEPERS
    Mar 2018
    Robina
    148
    I'm trade, tried all bearing supply type companies forum suggestions & 38.5 was the not available aspect!
    Seal Innovations in Brisbane will have 9 seals left after they get 10 from their NZ store, shipped today, if anyone else needs this R16 front transmission cover to clutch shaft.
    Seal dimensions are 24mm x 38.5mm x 10mm.
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,743
    The 38.5 is a unique Renault size.
    I knock the sleeve out of the bell housing, put it in the lathe and machine to fit a 40mm seal in. Refit all.
    Ray
    COL, Artificer and JohnW like this.
    Ray geckoeng
    Think Old, But Run Modern !!
    Mar 2018
    Robina
    148
    Good info, why we rely on experience & thanks, JG
    19,211
    Ray
    A very practical approach. However it's kind of "laying a trap" for the future.
    And personally, I prefer to keep consumable items as the manufacturer designed them.
    Perth, WA
    1,743
    "robmac"
    They are very difficult to get in Europe, so !!!!
    And anybody who takes it out in future will check the numbers on the seal and get one from their bearing place ?????
    Ray
    cjl likes this.
    Ray geckoeng
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,515
    Nah they'll post here and all will get confused and we'll invent a super rare series 1.5 where the bearing size changed because of a grand prix win in a formula 2 class.
    geckoeng likes this.
    9,262
    What's the setup on R16?
    Doesn't sound like R17. There you would need to machine the bellhousing itself to fit anything larger. Or did I get it wrong and you do machine the bellhousing?
    19,211
    "robmac"
    Ray
    I have my doubts : I wouldn't be so fast to judge everyone by your own standards.
    It had a similar discussion with the fellow who installed our solar system a couple of months ago.He inadvertently installed the current transformers backward on the supply circuit. His immediate response was to reverse the wiring at the controller.
    I insisted he correct his mistake and do the wiring as specified by the manufacturer.
    Just like DMC's approach: do it once do it properly.
    Having said this, I completely understand your reasoning and parts being unobtanium is a fair reason to modify.
    Ceenine likes this.
    Newcastle
    2,760
    Hi
    Renault's use of non standard seal sizes is not new. When I had the R20 I replaced a seal in the rack ends and had to make a very thin sleeve in al to make the difference on the OD. I was in the trade and could not get a better size match. The original seal was not available as a seperate part. Usually you could match the OD or the ID but not both ???? WHY ? Who knows.
    So a skinny sleeve might be a solution.
    Jaahn
    Jun 2018
    Norway
    139
    I've just bought one of these seals from Mecaparts. Can check for any numbers on the seal when I get home from work.
    JohnW likes this.
    Jun 2018
    Norway
    139
    Checked my new seal from Mecaparts. It says NAK SC 24 38.5 10.
    Can see if I find my old one. But if I remember correctly that one ended up in the bin with a big hole in it.
    Perth, WA
    1,743
    Yes But "R8RX", we need to pay Euro20.00 to post to OZ, whereas the seals are about $6.00 in OZ for the 40mm.
    Ray
    jaahn likes this.
    Ray geckoeng
    Mar 2018
    Robina
    148
    Thanks all....the ID part number on the old hard & brittle part, on my desk is similar to R8RX's & marked 'PAUL PRA 24 38.5 10'.
    With difficult/unobtainable parts I would do exactly the same as Ray & most 'real' mechanics to keep/get the vehicle back on the road.
    The sleeve in this case is freeze fitted I would imagine after careful inspection & there is no way to remove it easily without damaging the aluminum, unless I dremel through the steel sleeve then split & remove same.
    No seal from NZ soon & that is exactly what I'll be doing.
    19,211
    Paulstra perhaps ?
    A French manufacturer of seals, engine mounts and anti vibration products.
    https://www.paulstra-industry.com/societe-en.html
    Mar 2018
    Robina
    148
    Have successfully sourced & will be delivered tomorrow morning from Seal Innovations in Brisbane.
    They now have 9 additional in stock for anyone doing a tranny rebuild....phone 07 3711 4004
    Jun 2018
    Norway
    139
    Ray
    That I am fully aware of
    Thought it maybe would be easier for the next person if they saw a manufacturer name of these seals.
    Mar 2018
    Robina
    148
    Thanks for contributing.
    Some are not after thread counts, but knowledge we can ALL learn from & Ray helped with this as well.
    Keep on with what you are doing. It is appreciated. JG.
