1400 virage starter motor and alternator
    Feb 2018
    25
    Default 1400 virage starter motor and alternator
    I am looking for a starter and alternator for a 1400 virage motor. Are they specific to this motor or are there other options. If anyone has anything let me know. I also need a bracket for the alternator
    I have put a wanted advert up
    Brisbane/Australia
    2,051
    The alternator for the Virage is the same as the R12 TS as are the mounting brackets (there is one on the head and one one the timing chain housing).
    The starter motor is the the same as the imported starters for the R12 (Paris-Rhone if memory serves).
    The R12 Bosch starter will fit but as it's physically larger so it's a bit more of a pain to fit.
    Not sure if the starters from other Sierra engines might fit (R10 etc.), the bellhousing might be different
    Feb 2001
    Romsey, Victoria, Australia
    4,822
    Any starter from any sierra engine will fit. R8/10/12 so there's a huge range out there. Any R12 Alternator will fit. I've probably got some at work.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    fren[email protected]
    Simon's Avatar
    6,162
    An Australian Bosch starter in a Virage will require the Australian Bosch engine mount bracket as well. A Virage would have the Euro spec bracket which precludes the fitting of the physically longer Australian Bosch starter. So in a nutshell, just grab a Paris-Rhone, preferably a D9E version, which has a touch extra horsepower - these were available as a replacement part rather than the factory fitted D8E variation.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
