R1133 Caravelle Valve Stem Oil Seals
Results 1 to 7 of 7
    Oct 2017
    UK
    15
    Default R1133 Caravelle Valve Stem Oil Seals
    Morning gentlemen,
    I need a set of Oil stem valve seals for my 1965 Caravelle fitted with an R1133 engine, but I can't seem to find a set anywhere.
    The only set I came across was part of a full engine gasket set which I don't need as I already have one minus the seals for said beast.
    So has anyone any suggestions, many thanks in advance.
    Simon's Avatar
    6,161
    The reason you can't find a set of valve stem seals, is because the motor was never originally fitted with any such seals. What is the problem as to why you think you need them?
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,644
    Mickris,
    You are obviously not up to date with the "Sierra" engine, as they do not have valve stem seals. Gasket manufacturers put them in sets unwittingly, and you will not find in "Pieces de Origin". People who have fitted the destroy the valve guides in about 30k km.
    If you really want. Iwill send you a set from my collection, for cost of post fron OZ.
    Ray
    Ray geckoeng
    Think Old, But Run Modern !!
    Oct 2017
    UK
    15
    Ah that would explain why.
    I am getting a puff of blue smoke after she has been ticking over which then clears under normak running. It was often a sign of a bad valve oil seal.
    As I'm wrong on this diagnosis it must be something else.
    10,763
    Quote Originally Posted by mickris View Post
    Yes, no seals were fitted! If it isn't fouling the plugs or attracting undue attention, I'd just monitor oil consumption. What oil grade are you using? Maybe a wee bit of wear here and there and you'll need a rebuild in a decade or two.
    What happens after a long downhill glide on a closed throttle? Good test of worn guides is smoke when you open the throttle.
    We've just been all over France with the Floride Caravelle Club de France and some gave the odd puff but most were clean as a whistle. My R8 has a puff of smoke when started hot sometimes but it hasn't changed in decades.
    Are you in the RCCC?
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Feb 2005
    rosevale/tasmania
    2,745
    My perhaps imperfect understanding of the history of this is that the predecessor to the Sierra engine, the Ventoux, was notorious for poor upper cylinder lubrication (I was always advised to use a lubricant for my 4CVs) & that valve stem seals were omitted in the later engine to allow some beneficial leakage of oil into the cylinders.
    Oct 2017
    UK
    15
    Thanks lads for your invaluable info. Much appreciated,
