Renault R12/15/17 Lowering Front End
Page 1 of 4 1234 Last
Results 1 to 25 of 81
Like Tree22Likes
Thread: Renault R12/15/17 Lowering Front End
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,285
    Default Renault R12/15/17 Lowering Front End
    Have been thinking about a cheap easy way that I can lower the front end of my R12, that is also reversible.
    After much thought I have come up with this.
    I'm lucky enough to have Bilstein shocks in the front of my R12 which already have 4 ride heights built in, but even on the lowest setting this is not quite low enough.
    This is the Bilstein shocks that I have with the Bilstein spring perch to which the standard spring perch sits
    Bilstein spring perch removed you can see the four grooves in which the top one has a circlip.
    Coilover sleeves and adjusting nut
    The coilover sleeve that has one guide machines down and a landing machined in to sit on the circlip in the same way as the Bilstein spring perch does.
    Adaptor to go from the adjuster nut to the standard R12/15/17 spring perch
    Bilstein shock with coilover sleeve and adjuster nut
    Bilstein shock with coilover sleeve; adjuster nut and spring perch adaptor
    Bilstein shock with coilover sleeve; adjuster nut; spring perch adaptor and standard R12/15/17
    I have not yet installed these on the car. When i do I will take some more pics and post them on this thread
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Nov 2005
    Geraldton
    1,624
    Bloody schmick job Col.
    I would like to do the same with some Konis I have.
    In the Shed(s):
    In the Past:
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,285
    As long as they have that criclip that should not be a problem, from my reading its the Bilstein's and Koni's that you can do this to.
    It works out a lot cheaper than real coilovers.
    Regards Col
    1973 Alpine A110
    Fellow Frogger! Jensen's Avatar
    386
    I’ll check tonight but I’m pretty sure the 12/17 Koni shocks have the perch welded on rather than a circlip arrangement. I’ve seen non- Renault applications where the perch has been cut off and a threaded collar welded on (carefully!).
    COL, your set up looks good. Will be interesting to see once fitted if there is any binding of the standard springs at low settings given how many coils there are on standard springs.
    What’s the plan for the rear?
    2002 Monaco Blue Renaultsport Clio 172
    1975 R1317 Renault 17 Gordini
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,285
    Quote Originally Posted by Jensen View Post
    There should be no binding of the coil spring as I will be using the standard spring that is already in the car. The only negative that I can see is that the shock travel will be reduced as I effectively lower the spring perch down.
    As far as the rear goes, don't have a plane to do anything there at present. I was thinking about lowering the front about 50 mm basically bringing front guard down to the top of the tyre.
    Originally I was going to cut some more grooves into the Bilstein shock, even ground up a parting off tool to suit for cutting the grooves. I have been hanging off doing that from fear of stuffing the shock.
    Regards Col
    1973 Alpine A110
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,285
    All Star Performance parts list.
    https://allstarperformance.com/content/872.pdf
    I used:
    2 @ 5" sleeve ALL64162
    2 @ Adjuster nut ALL64180
    These are to fit 50mm bodied shocks
    bowie likes this.
    Regards Col
    1973 Alpine A110
    Nov 2005
    Geraldton
    1,624
    Okay Col, now the hard question: what about the rears?
    In the Shed(s):
    In the Past:
    9,247
    I am worried about that adaptor for the OEM spring. Seems to be aluminium and doesn't have the step for the coil end. Might cause issues. I think you could just use the original spring perch, they come off the shocks. Might still need an adaptor if the bore doesn't match.
    The rear end is more problematic because of the passive steering effect inbuilt by Renault. I imagine a shorter spring with a higher elasticity constant to compensate would be enough to lower the car, but the effect mentioned above will change.
    ACHTUNG ALLES LOOKENPEEPERS
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,510
    Just buy a second set of shorter springs and swap them in, and then out again when you want to reverse it?
    But no I appreciate your engineered solution and endless tweaking to ensure height is perfecto.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,285
    I don't follow what you mean
    All the parts are aluminium to keep weight to a minimum.
    I'm using the oem spring perch so the spring will sit as it does now.
    I can't use the original Bilstein spring perch because the internal diameter is to small and I do not want to modify it.
    The adjuster nut is designed to accept 2.5" coil over springs and the spring on my car is 160 mm so need an adaptor.
    Regards Col
    1973 Alpine A110
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,285
    Not sure yet, haven't come up with a cheap simple solution, but open to ideas
    Exfrogger likes this.
    Regards Col
    1973 Alpine A110
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,285
    I could machine up a piece of aluminium or purchase a top for the shock and then buy coil over springs as another option.
    I drive the car on the road and occasionally compete in motorkhanas with the car, so its all a compromise.
    Regards Col
    1973 Alpine A110
    Simon's Avatar
    6,203
    Those Bilsteins look a neat bit of kit, with the flexibility to adjust like they do.
    Just adding a pic of the “usual” 12/15/17 Konis. As Jensen says, they have a welded spring perch support, so can’t be adjusted.
    Just watch with lowering the rear, as when the trailing arm is parallel to the floor at rest (so the axle trailing arm mount is the same height as the body trailing arm mount) it does funny things to the handling as the axle moves above and below the body pivot point when cornering.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Feb 2005
    rosevale/tasmania
    2,852
    My understanding of the rear was that Renault built in some passive roll oversteer (or oversteerish) by way of bush distortion to produce toe-out on the outside wheel (& toe-in on the inside given the beam axle).
    How that would be affected by a lower rear I know not but surmise that, as body roll is the big variable, it might not matter. My two Virage wagons with saggy rears handled in a sanitary way (helped by R17 anti roll bars which I assume that Col has fitted).
    cheers! Peter
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,285
    I'm not sure why Bilstein made the shocks the way they did, maybe it was to compensate for different spring rates available.
    Its just a shame that they never put another half a dozen more grooves below those four.
    Regards Col
    1973 Alpine A110
    Aug 2002
    3,510
    #unrelated!
    https://www.racingaspirations.com/ap...ry-calculator/
    Oh nerd toys everyone!
    COL likes this.
    386
    Just measured the front Konis. The diameter of the shock body is 55mm.
    Top Performance seem to have sleeves and other hardware to suit.
    http://www.toperformance.com.au/app/...e-Products.pdf
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,285
    I like that site, this is probably more useful as the R12 is double wish bone suspension.
    Regards Col
    1973 Alpine A110
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,285
    cheers! Peter
    Yes I'm running R17TL anti roll bars.
    I also have a set of R17TS (Gordini anti roll bars here as well)
    The more roll that is taken out the less effect roll over steer is going to have. Still not sure what to do about the rear.
    Regards Col
    1973 Alpine A110
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,285
    I remember coming across that site, but dismissed using there stuff because it was either the wrong size or did not have the landing necessary to sit on the circlip.
    Regards Col
    1973 Alpine A110
    9,247
    My mistake, I did not see the last picture.
    COL likes this.
    Feb 2001
    Romsey, Victoria, Australia
    4,895
    You guys overthink things.
    I've been building hot 12's for 40 years and you know what we did.
    Cut 2 coils off with an angle grinder.
    R12's have such long travel and so many coils it can afford to loose a couple. Each coil equals 1 inch (25mm) so we usually cut 2 and lower it 50mm
    With good shockers, thick sway bars and reverse the top ball joints and you have something that turns in pretty well.
    We tried 3 coils once, front and rear and when the car went over a jump the rear springs well out.....don't do that.
    JohnW, COL, bowie and 2 others like this.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    Aug 2002
    3,510
    Better get some limiting straps on the beam then before I take my nugget back to Awaba then....
    8,466
    My distant memory tells me the r12 front end is similar to the fuego (which I still remember)
    Check out jounce bumpers.
    It gets ugly when the shock suddenly runs out of travel.
    Jo
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,285
    Jo
    I have those in the rear Jo, might get a set for the front.
    Regards Col
    1973 Alpine A110
