Dauphine Steering & Brake Issues. - Page 2
Page 2 of 2 First 12
Results 26 to 50 of 50
Like Tree11Likes
Thread: Dauphine Steering & Brake Issues.
  1. #26
    Boonah Qld
    2,507
    The steering wheel can point anywhere. It is on a spline and can be moved on the spline to face anyway desired.
  2. #27
    Jan 2013
    Geelong
    511
    Sure!
    But the rack's flexor only has 4 holes. Unless there is an offset, I can't see how toe in/out is affected by which ones are used for column or which the rack.
    Brakes.
    The saga continues. The brake place's "pressure test" consists of putting the cylinder in a vice, filling it with fluid, bleeding it out thru the stop light switch hole & then pushing on the piston with a Phillips head screwdriver. They said it was "rock hard".
    I respectfully pointed out that when I push on the pedal I'm applying about a 10 to 1 leverage effect that has FAR more force/push than a hand held screwdriver.
    Hydraulics ain't rocket surgery; what I'm seeing is explained by either a too small seal or a too big hole.
    Because I'm such a good customer (they have done ALL my work for 20 years), they've very kindly offered to have the car in their workshop to investigate but I have to wait till the steering goes back in.
    1949 Citroen Big 6
    1955 MGA1500
    1970 Peugeot 404 Utility (Resto project)
    1962 Renault Dauphine Gordini (Resto project)
    1950 Grey Fergie Tractor
  3. #28
    Jan 2013
    Geelong
    511
    Steering.
    I rang to get a delivery date (next week) so I can arrange the brake shop visit. I mentioned the excessive toe-out on the drivers side & they told me that they later found the assembly is bent on the driver's side which is the most likely cause of the toe-out and probably the distortion at the flexor.
    Fortunately they can straighten it and get it back to ~98% new all round.
    I might even get the bugger on the road for Bastille Day!
    1949 Citroen Big 6
    1955 MGA1500
  4. #29
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    3,960
    Quote Originally Posted by geodon View Post
    Steering.
    That explains the toe problem and also the stiffness in the rack, your lucky they can straighten the rack.
    Maybe a long term solution is to find another rack.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
  5. #30
    10,705
    Hmm. Good that you are making progress. Which assembly was found to be bent? I can't see how suspension components or the steel rack itself being bent would affect the flexor distortion - I'd still go back to the rack mounts, as the rack has obviously had quite an impact.
    As for the MC, you can only shake your head sometimes.....
    Continued good luck!
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
  6. #31
    Nov 2005
    Geraldton
    1,545
    Can you not just slap an R8 rack in it and go?
    Also, remember that if you can get someone in the northern hemisphere to send you a left hand drive rack, it will be worn on the other side of the rack to where we wear them out down here. Turn the pinion over 180 degrees and you'll think you've got a new car!
    As for the brake issue, if you're getting hissing that would suggest there's air escaping. Are you losing brake fluid? What is the condition of the pipes going into the MC? Are they the right profile for their seat in the MC? Can you get someone to pump on the brakes while You search for the source of the hissing with a length of tubing stuck in your ear?
    P
    In the Shed(s):
    In the Past:
  7. #32
    1000+ Posts Frans's Avatar
    Auckland
    1,478
    Hi,
    Exfrogger, I'm not too sure about that because the pinion goes in at an angle to the right on RH ones and to the left on LH ones. They do not match, therefore all the issues you have to go through when trying to make a quick rack. But maybe I understand you wrong.
    I would like to think I'm right on the R8 rack. If it has been assembled correctly then there is a punch mark on the pinion shaft. That should point straight up when the rack is in the center. Then the coupling has a groove in it that should align with the punchmark, give or take a spline. when you bolt the shaft on, you will have the bottom 2 bolts horisontal and your steering wheel will be very close to straight.
    Have a look at the photos, it might just be there on the Dauphine ones as well.
    The groove in the coupling is not that clear but you can see it in the photo.
    Regards Frans.
    Old enough to know better
    Young enough to do it anyway.
  8. #33
    Auckland
    1,478
    Oh shucks I doubled up on the photo.
    Here is the coupling photo with the mark opposite the hole in the soft coupling.
    Frans.
  9. #34
    Jan 2013
    Geelong
    511
    *** As for the brake issue, if you're getting hissing that would suggest there's air escaping. Are you losing brake fluid? What is the condition of the pipes going into the MC? Are they the right profile for their seat in the MC? Can you get someone to pump on the brakes while You search for the source of the hissing with a length of tubing stuck in your ear?****
    Absolutely no leaks. And I have the flex hoses clamped so it's all about the m/cylinder
    Perhaps "hissing" is not the right word. It's the squish you hear when you push the pedal down (after pumping it up) when someone opens a bleeder valve. It's the sound I associate with the m/cylinder piston pushing brake fluid.
    JohnW I stared at the "ears" that mount the rack for a long time today. They LOOK fine & are parallel. I put a straight edge on them & marked where they would touch the boot underside. The dots were symmetrical. The impact was mostly on the driver's guard & wheel. That would have put a levering force to the rear on the rack and if/when it bent would result in toe-out. When the rack goes back in all will be revealed!
    1949 Citroen Big 6
    1955 MGA1500
  10. #35
    10,705
    All will be revealed as you say. It does sound as if the brackets are OK. Hope so.
    Renault 4CV 1951
    Renault R8 1965
  11. #36
    Jan 2013
    Geelong
    511
    Default The rack came back early
    I installed it but didn't connect the flexor yet as the master cylinder will need to come out AGAIN and it's "easier" without the rack in place. I don't think the words "easy" and "Dauphine master cylinder" should be in the same sentence.
    I estimate 80% of the excess toe-out is gone. The rest may be eliminated during the alignment procedures.
    As an experiment I installed ~5mm of flat washers under the rack on the driver's side thus pivoting the rack forward. I expected to remove more toe-out.
    To my complete surprise I got MORE!
    When you think about it, an impact on the wheel would have levered the rack to the rear and that may have pulled on the drivers side mount thus moving it forward & giving excess toe-out
    Anyway, that makes it very easy to fix; just hit the bugger with a hammer. But, that may be best left to the experts during alignment
    1949 Citroen Big 6
    1955 MGA1500
  12. #37
    10,705
    Interesting. You'll have worked out why you got more toe out by now. Hopefully there's enough adjustment on the tie rod where it threads into the rack to get what you need. Swinging a hammer in there is a challenge too.....
    Some of our number have replaced the MC securing bolts with Allen-head bolts of a slightly larger diameter, which seems a good idea to me. I reckon the MC piston free-play adjustment is the one really nasty thing on a 4CV/Dauphine/R8 etc, followed closely by the steering flexor when it hasn't been touched for 20 years, the banjo union at the end and the MC bolts themselves.
    At least you are making progress, if frustratingly. May it all come good quickly!
    Renault 4CV 1951
    Renault R8 1965
  13. #38
    Jan 2013
    Geelong
    511
    I had the foresight to put a big blob of Araldite on the heads of the bolts for the MC when the car was on a rotisserie. Even Blind Freddy could see they were a nightmare to get at.
    1949 Citroen Big 6
    1955 MGA1500
  14. #39
    10,705
    A set of the old, really nice small Sidchrome ring and open end spanners do quite nicely. Once you have had them off once, and cleaned up the threads, it goes more easily. But you know that...
    Renault 4CV 1951
    Renault R8 1965
  15. #40
    Jan 2013
    Geelong
    511
    Default Dauphine Steering Rack Mounts Adjustment Tool
    You won't find this one in the back of the workshop manual.
    Muscle power was only just enough.
    If the wheels had not been beautifully parallel after I re-installed the rack , my next step try again but with a jack.
    Carefully.
    FIVEDOOR likes this.
    1949 Citroen Big 6
    1955 MGA1500
  16. #41
    Simon's Avatar
    6,139
    Just another stab at something else to check, possibly already done. The steering arm is a tapered and keyed fit into the stub axle carrier, it may be worth checking the relative measurements of the arm to the carrier on each side. Just to see if the impact has tweaked one of the arms.
    JohnW likes this.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
  17. #42
    Ipswich, Queensland.
    1,880
    I find that by using Allen key type bolts to secure the master cylinder, which I upgrade to 8mm rather than the original 6mm, that the bolts are Ok to remove with a longish extension. The new bolts are of course well lubed for future removal. The original bolts I find are usually easier to break off rather than undo them after 40 years of water and brake fluid attacking them.
    COL likes this.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    '08 Renault Megane sedan
  18. #43
    10,705
    Carefully.
    Much better than a hammer. Now for the brakes eh?
    Renault 4CV 1951
    Renault R8 1965
  19. #44
    Jan 2013
    Geelong
    511
    Correctomundo!
    I'm more than a bit pissed TBH
    If not for the MC fiasco, I would have obtained an online unreg vehicle permit from VicRoads & be test driving it.
    AND, I'm none too happy them saying e.g. "OK let's put a bigger cup in & try that". What if the new one is too small? I'm reluctant to do yet another MC out/in dance until I know everything is kosher. In hindsight a new unit from Europe would have been the go. This episode has shaken my faith in SS sleeving which I believed is the preferred option for a vehicle that is only used sporadically.
    Cosmetically, the very last thing to do is install the decorative aluminium strips along the belt line & sills.
    1949 Citroen Big 6
    1955 MGA1500
  20. #45
    10,705
    I've had resleeved MCs for decades in the 4CV and R8. Probably both done by Power Brakes in Adelaide and bronze not SS. The only trouble I've ever had is of my making, when using a cup just slightly too large, and then the piston won't retract properly.
    I've no experience with the new ones you can buy, for example from Argentina, or which internal diameter they have used. They might be just fine.
    Renault 4CV 1951
    Renault R8 1965
  21. #46
    Jan 2013
    Geelong
    511
    Sorry Simon I missed this post.
    When I got the car 5 years ago, I trailered it to a recommended firm that local panel shops send their badly mangled specimens to have their front ends sorted out.
    They charged me $50 and told me the stub axle was bent.
    I got 2 spares with the car so I changed it & it mad zero difference.
    In hindsight THAT was the time to investigate further
    Simon likes this.
    1949 Citroen Big 6
    1955 MGA1500
  22. #47
    Jan 2013
    Geelong
    511
    Default Brakes Sorted
    The new master cylinder arrived and has been installed.
    A rock hard pedal with about 20mm of pedal movement with the stretched pushrod set at the minimum length and all flex hoses clamped
    Now to adjust the pushrod to get the factory 5mm free play.
    IDK where that leaves me re stainless steel sleeves!
    Looking ahead, if the cylinder CAN be replaced I will buy a new one.
    1949 Citroen Big 6
    1955 MGA1500
  23. #48
    It's how I roll...Brisbane
    32,906
    George, did the gear knob arrive..?
  24. #49
    Jan 2013
    Geelong
    511
    Yes thanks Graham.
    It would have been a shame to have had an original, pristine 40,000 mile interior with a gear knob sans the Renault crown emblem!
    1949 Citroen Big 6
    1955 MGA1500
  25. #50
    Jan 2013
    Geelong
    511
    Default Tools to Set M/Cyl Pushrod Length
    Two U-shaped spanners; 1x12mm & 1x14mm
    A thin short 14mm OE spanner to hold the 14mm section of the pushrod while you tighten the 12mm lock nut
    1949 Citroen Big 6
    1955 MGA1500
