Help no blinkers
    Member DragoN's Avatar
    46
    Icon9 Help no blinkers
    Hello since i just go the new(secondhand) engine put in my Fuego 85" GTX i have notice that when i have any of my lights on, eg brake, driving, and normal lights. My blinkers do not work or are really, really slooooooow. Does any one know the cause of this, or am i going to have to go through my whole car looking for the fault.
    My fuses are all ok, i just checked
    Wireing that i can get to looks fine, no melting plastic smell either
    Any suggestions will be greatly received
    Brisbane/Australia
    2,051
    Sounds like a problem with an earth connection/s somewhere in the circuit.
    The most likely culprits would be the rear lights. Try cleaning up the earth connections and try the lights again.
    Ren
    46
    I ll try that and get back to u
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,752
    It is an earth connection for the front loom - it is down in front of the battery under the right headlight below the fan relay. Odds on that the mechanic undid if he moved the loom out of the way when taking out the rad and its fans. Look for the 10mm bolt that holding a couple of black wires to the bodywork that needs tightening.
    I did the same thing to one of my Fuegos that took me ages to find - I had simply forgotton to tighten it
    Sense Pug307's Avatar
    Australia
    4,355
    Now I know where Peugeot did its COM2000 prototype work
    Peugeot 307 XS 1.6
    Rendezvous Adelaide 2005
    46
    Thanks people, The problem turned out to be that the connecters between the rear light groups were dirty allowing current to pass between them so my blinkers and brake lights ended up linked, wich proved to be to much draw for the blinker relay to handel so it stopped working, cleaned it all up and it now works
    Thanks for the surgestions, they started me in the right direction
