Renault sierra engines
Results 1 to 16 of 16
Like Tree8Likes
  • 5 Post By 59 Floride
  • 1 Post By renault8&10
  • 2 Post By REN TIN TIN
Thread: Renault sierra engines
    Member Gordini61jr's Avatar
    May 2018
    Torquay
    62
    Default Renault sierra engines
    Can anyone tell me which sierra engines match these numbers?
    688-02
    689-01
    688-09
    Boonah Qld
    2,607
    688-02 R10
    689-01 R8 Early 956cc I think, can check tomorrow, if someone else doesn't confirm this in the mean time
    688-09 R10S
    It's how I roll...Brisbane
    33,721
    ...I confirm that he will check tomorrow.
    4,424
    688-02 was also used in the 1100 R8.
    Assuming the guess of early R8 for 689-01 is correct. The pick of those engines would be the 10S engine but the head off the early R8 engine is getting rare and worth keeping too.
    KB
    4,424
    We must wait of course for Rob to confirm tomorrow, but in the meantime here is some light reading:
    https://en.m.wikipedia.org/wiki/Rena...n-Fonte_engine
    Sunroof likes this.
    KB
    Boonah Qld
    2,607
    Great page very comprehensive. Didn't find the 15 TL though, may be I didn't look in the right place.
    May 2018
    Torquay
    62
    The r10s had the 8 port head like a 12 and the 956 i think, so would that mean that 688-09 is a 10s engine?
    1000+ Posts driven's Avatar
    Apr 2005
    1,549
    Now we will have to check Mercedes Benz engine designations in the future
    4,424
    Both the 10S and 956 had 8 port heads but were different. The 956 head is preferable as it raises the compression ratio and was a popular mod back in the day. I believe the 10S head is different to the 8 port 12 as well.
    Boonah Qld
    2,607
    Sorry guys thought about it when I walked past the 956 cc engine but had a friend in tow looking at something else. Will try and remember tomorrow.
    4,424
    Do we need Mr Graham to reconfirm?
    Boonah Qld
    2,607
    Yes you probably did but I did look at my 689 - 01 and it is a 956cc engine from an early R8, one of the very few left as the block usually buckled and were replaced early on in their life by Renault, or by "who ever" later in their life. One of my R1131's is replaced by a 10 block but retains all the other 956cc bits like head, sump and manifolds. The other has a Caravelle block and retains all the 956cc bits but this was probably done by Renault as it has a large number of dobs of coloured paint on various nuts, bolts etc. I have it on good authority that the factory did this with warrenty engine swaps.
    Brisbane/Australia
    2,174
    Code cm3 Bore Stroke HP DIN HP SAE Models Type Year Type Carbs
    689 (A710) 956 65 72 44 5 TL R1222/1392 72-85 k Solex 32 DIS
    689-01 956 65 72 41 R8 R1130 65-67 k Solex 32 DISTA
    689-02 956 65 72 42 Floride S, Caravelle R1131 59-63 k Solex 32 PDIST
    688 (793) 1108 70 72 5 TL/GTL R1247 83- k Solex 32 DIS
    688 (E713) 1108 70 72 45 5 TL/GTL R1227/1397 79- k Solex 32 DIS, Zenith 32 IF7
    688-01 1108 70 72 42 Estafette R2132 62-68 k * Note Various types of Crank, 5,7 and 8 Bolt Depending On Engine No
    688-02 1108 70 72 47 Caravelle R1133 63-65 k Solex 32 DISTA * Note Various types of Crank, 5,7 and 8 Bolt Depending On Engine No
    688-02 1108 70 72 46 R 8 R1131 67-71 k Solex F32 DITA-3 * Note Various types of Crank, 5,7 and 8 Bolt Depending On Engine No
    688-02 1108 70 72 46 R 10 R1190 65-69 kk Solex F32 DITA-343 * Note Various types of Crank, 5,7 and 8 Bolt Depending On Engine No
    688-03 1108 70 72 52 Caravelle 1100S R1133 65-68 kk Weber 32 DIR 4 * Note Various types of Crank, 5,7 and 8 Bolt Depending On Engine No
    688-09 1108 70 72 46 R 8 S R1131 67-71 k Weber 32 DIR 4 * Note Various types of Crank, 5,7 and 8 Bolt Depending On Engine No
    688-10 1108 70 72 47 6 TL R1181 70-79 k Solex 32 DIS, Zenith 32IF, Carter 32 RBS * Note Various types of Crank, 5,7 and 8 Bolt Depending On Engine No
    688-12 1108 70 72 34 4 GTL R1128 79-90 k Zenith 28IF * Note Various types of Crank, 5,7 and 8 Bolt Depending On Engine No
    RTT
    Sunroof and jaahn like this.
    Boonah Qld
    2,607
    Yep well done RTT. Wondered when someone was going to do that. I may have had the list somewhere but have saved all this sort of stuff haphazardly over the years and can never find it when wanted.
    Jul 2013
    Southampton Ontario Canada
    62
    I have a 689 in my Manic GT car and was wondering if the blocks of the 689 had equally spaced bores or if they are the same as the 688 blocks ? I am hoping they are equally spaced like the 810 blocks ??? If they are than the heads would probably have the equal spacing between cylinder's !
    I do not really want to tear another motor apart to just satisfy my curiosity.
    Manic gt
    33,721
    I deny everything
