R16 water pump bleed nipple. - Page 2
Page 2 of 2 First 12
Results 26 to 30 of 30
Like Tree11Likes
Thread: R16 water pump bleed nipple.
  1. #26
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    3,953
    The definitive answer for a R16
    https://www.r16site.com/tips/Bleeding.htm
    Doesn't mention what the thread dimensions are, which is what this thread is all about.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
  2. #27
    Member Artificer's Avatar
    Mar 2018
    Robina
    114
    OK these will do the job with no stuffing around just coat with kopr kote grease when fitting:
    https://www.ebay.com.au/itm/2x-M10-x...8AAOSwxuha0IRg
  3. #28
    Moderator vivid's Avatar
    parallel 43 south
    1,878
    Quote Originally Posted by Artificer View Post
    I'm not sure if it was confirmed or not, but newer units may not be compatible with the bleed screws in that there is no seat for the tapered end to slot into and block the tube holes.
    I like Ken's idea, but might be a bit involved for some to be worth it.
    Quote Originally Posted by Kenfuego View Post
    Should be easy to make up an authentic looking brass barrel with a central screw in tapered end, to bottom into a similar taper to shut off the release of air, better to make it like a short plug with only a few turns in the thread from open to shut. The outer barrel thread could be liquid thread sealed permanently or even cold soldered in place if safe to do so.
    Ken
    Powered by high grade French plutonium.
  4. #29
    Mar 2018
    Robina
    114
    Of course it would need a seat....I stand corrected.
    I do not agree with 'any' complicated solution, although it would work.
    10 X 1mm stainless [& if not stainless Kopr Koted bolt] will work fine.
    If one wants to be fancy they can slot the thread with a 3 point file to near the top of the thread as a bleed path.
  5. #30
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    3,953
    The only thing I would be concerned about would be seat angle, but that is easily fixed if you have access to a lathe.
    Regards Col
    1973 Alpine A110
