Scenic oil consumption
Results 1 to 13 of 13
Like Tree4Likes
  • 2 Post By jo proffi
  • 2 Post By COL
Thread: Scenic oil consumption
    don
    don is offline
    Fellow Frogger! don's Avatar
    Mayfield Newcastle
    467
    Default Scenic oil consumption
    Morning all
    Our scenic F4R is now at 200+ kilometres and using a little oil approx 500mls a month depending on use of course.
    There is no apparent blue smoke at start up or after sitting warm that would indicate valve stem and ring wear.
    There are no oil leaks from the F4R and it is running well.
    Is it common for these motors to use oil .?
    If the incorrect lubricant is used could this be the reason?
    Sent from my SM-T385 using aussiefrogs mobile app
    Jul 2013
    Newcastle/ central coast
    2,222
    Pretty common for that motor
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Garage C5 X7 4008
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    18,408
    Using the recommended lubricants in this day and age is imperative. They are tailored to your engine's requirements and if you look at the mileages now commonly attained you would understand that it is the lubricants that help achieve them. Back in the sixties/seventies most four potters would need a valve job and possibly rings by 160k.
    Brisbane/Australia
    2,175
    My Scenic didn't use a drop of oil in the 5 odd years I had the car, never had to top it up.
    Was serviced once a year by a Renault specialist as I was doing about 8K kilometers per year and I believe the workshop was using Elf oils.
    But it only had 130K on the odometer when I sold the thing, nowhere near your 200K.
    Newcastle
    2,760
    Hi Don
    At that milage it would be OK IMHO to step up a grade to a heavier oil if you want to slow down the oil use. Certainly I would not be using the really thin oil designed for the new cars. I have found using Mobile 1 in the past has been good for high oil use. What are you using.
    With a catalyic converter that is working properly any oil that goes through the motor will be burnt off and there will be no smoke to see. It will off course clog up faster if substantial oil is being burnt.
    Cheers Jaahn
    Sans Pond. STALLED's Avatar
    Oct 2003
    2,872
    The F4R in my Clio uses no oil between services. Doesn't exactly get driven lightly and has 153k on the clock.
    Similar motors.
    2005 Renault Clio 182 Cup
    8,466
    Quote Originally Posted by STALLED View Post
    Renault engines seem to go better when mildly flogged.
    I do remember wringing the bejesus out of the 200k km RX4, constantly hitting rev limiter in anger, but I can't remember it using up any of its oil.
    Jo
    vivid and Tom_95 like this.
    11,231
    Half a litre a month isn't much. What I WOULD do is start keeping a good record of consumption and see the rate of increase, if indeed it does increase. Our Peugeot 306 used rather more than that for its last few years before being sold at 250,000 km, and not sold for that reason I'd add.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    don
    don is offline
    Mayfield Newcastle
    467
    Thanks everyone
    I will look at changing to something a little heavier and keep an eye on usage.
    I m really only concerned if the usage is a possible precursor to something more problematic in the future.
    8,466
    Quote Originally Posted by don View Post
    Thanks everyone
    How much future does a +200k Km 15 year old Renault have???
    Jo
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,298
    Jo
    My Laguna 1 had 275,000 Km on the clock and never used any oil between services.
    I used Castrol GTX Modern Engine 15W-40 for the 10 years that I used it as a daily driver.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    don
    don is offline
    Mayfield Newcastle
    467
    As a daily driver the vehicles future is going to be till it suffers a terminal event.
    IE just replaced serpentine, water pump and tensioner pulley. Timing belt due in 70K.
    I would expect to have problems with the driveshafts by 220K + based on previous experiences.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,298
    My experience with drive shafts is as long as the boots are in good condition and not leaking oil or grease the drive shafts will last the life of the car.
    So do regular inspections of the driveshaft boots and replace the boot if it looks suspect.
    Kim Luck and JohnW like this.
    Regards Col
    1973 Alpine A110
