R1135 Gordini 1967
    Sep 2017
    newcastle
    45
    Default R1135 Gordini 1967
    Happy Easter out there.
    Please could my assumptions be verified by someone who knows,that I am correct.
    I am servicing my calipers. I noticed that 2 of the 4 had a a nipple sitting in the centre of a square in the casting on the opposite side to the piston. The other 2 just had a nipple with no square. Am I correct in my assumption that the 2 with the square use square o'ring seals, the other round o'rings. With the square seals in the calipers with no square in the casting, the pistons just fell in, no pressure on the seal.
    Ross
    1000+ Posts Shoji's Avatar
    Jan 2012
    Mandurah WA
    1,072
    Hi Ross. There has been a discussion about the very subject here on AF. Do a search using AF search engine on the main page. Good luck
    Sent from my Moto G Play using aussiefrogs mobile app
    Jun 2018
    Norway
    102
    Here is my thread on the same topic. Believe you will find an answer there.
    Brake caliper piston - Renault R8 Gordini
    Jun 2018
    Norway
    102
    But yes, your conclusion seems to be what was said in my thread. Square seal on the caliper with the square in the casting.
