6V Dauphine Fuses
Results 1 to 13 of 13
Like Tree2Likes
  • 1 Post By geodon
  • 1 Post By Andrew Watkins
Thread: 6V Dauphine Fuses
    Jan 2013
    Geelong
    560
    Default 6V Dauphine Fuses
    It must have some!?
    The wiring diagrams in the w/shop manual only show a fuse box for the 12V versions.
    I can see neither a ref to any fuses in the 6V wiring diagrams nor where they're located
    1949 Citroen Big 6
    1955 MGA1500
    1970 Peugeot 404 Utility
    1962 Renault Dauphine Gordini
    1950 Grey Fergie Tractor (Pending Resto Project)
    11,223
    Someone will know! My 6V 4CV has no fuses but it is 1950.
    No doubt the 12V ones had the same two fuses as the R8, perhaps also in the RH glove box.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Jan 2013
    Geelong
    560
    **My 6V 4CV has no fuses but it is 1950**
    T'would appear then that the French minimalist approach to gears & wheel nuts extends to fuses?
    Or perhaps they think 6 volts is not enough to make sparks?
    JohnW likes this.
    1949 Citroen Big 6
    1955 MGA1500
    11,223
    Quality wiring, I'd have to say. All of mine is pretty good for its age and the insulation is sound. I have retrofitted some fuses and relays mind you. And 6V QI headlamp bulbs with relays are reasonable if the Cibie reflectors are in good shape. The relays protect the Avercod switch too.
    You can get 6V transistorised ignition modules, which takes the current off the distributor points.
    If very excited, you can get 6V alternators from USA and they work well.
    Mine has 5 wheel nuts, being a spider-wheel car. Your Dauphine is post-1956, so three-stud disc wheels.
    Simon's Avatar
    6,203
    If as original, there are no fuses with a 6-volt Dauphine G.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Mar 2013
    olinda victoria australia
    755
    Default Fuses
    My Ď60 4cv had one main fuse. It is 20 amp, as I discovered when I temporarily wired QH lamps in without relays!
    It is shown on the wiring diagram, so was designed in
    It now has rather more
    The French were thrill seekers
    Andrew
    JohnW likes this.
    Apr 2013
    Essendon
    699
    Quote Originally Posted by Andrew Watkins View Post
    My ‘60 4cv had one main fuse. It is 20 amp, as I discovered when I temporarily wired QH lamps in without relays!
    Andrew
    Not sure that it was the QH globes that did it Andrew: 20 amps equates to to 240 Watts. Did you have 100 W globes plus everything else on at the time?
    John
    Mar 2013
    755
    Quote Originally Posted by JAJEA View Post
    John
    20 Amps at 6 volts equals 120 Watts
    2 x 50 Watt QH headlights takes one pretty close
    What ( Watt ) had always puzzled me is whether a 20 Amp fuse blows at a highr current with 6V than 12, based upon my ignorant assumption that it had something to do with energy ( volts times amps ) , given that the fuse gets hot and blows.
    THe events of a month or so ago show me to have been comprehensively wrong, not a new experience
    RElays have solved the issue. I can now see and be seen.
    Best Wishes
    Andrew
    11,223
    Heating is proportional to the current squared times the resistance if I recall correctly. Relays are definitely the way to go.
    Jan 2013
    Geelong
    560
    Default I Found One!
    From the looks of the fittings (with eyelets & bolts) this was done when the vehicle was fairly new.
    1949 Citroen Big 6
    1955 MGA1500
    Boonah Qld
    2,605
    Looks original to me.
    Mar 2013
    755
    Looks like mine - high up on the firewall behind the dash
    Probably 20 mighty Amps
    Andrew
    Feb 2005
    rosevale/tasmania
    2,853
    How I love relays (& separate fuses for separate functions).
    cheers! Peter
