Ng3 wanted
Results 1 to 18 of 18
  • 1 Post By schlitzaugen
Thread: Ng3 wanted
    don
    don is offline
    Fellow Frogger! don's Avatar
    Mayfield Newcastle
    427
    Default Ng3 wanted
    Hello to the brains trust
    I am looking for a NG3 gearbox in good working condition
    HAPPY to pay what it takes to get a good condition unit
    Sent from my SM-T385 using aussiefrogs mobile app
    Jul 2013
    Newcastle/ central coast
    1,558
    Yeah right
    Garage C5 X7 3008 XTE
    Fix it right the first time
    8,688
    I have one in bits if you're game to put it back together.
    I assume it was in good working condition judging by the wreck I removed it from.
    vivid likes this.
    ACHTUNG ALLES LOOKENPEEPERS
    Canberra ACT
    661
    Default NG3 gearbox
    Quote Originally Posted by don View Post
    I have a NG3 gearbox out of a Fuego. $300 plus freight. Just sent one to Victoria freight cost $170 so imagine about same to Newcastle. PM me.
    Jerangle
    767
    Got one out of a R18, later type linkages.
    Work perfectly, no need to strip.
    don
    don is offline
    Mayfield Newcastle
    427
    Ok so I have the Box from canberra from a fuego
    and it has occurred to me the bell housing and rear cover / linkages are somewhat different to the that fitted to my 25 GTX.
    Is it going to be a simple matter of changing the bell housing and rear casing and linkages ?
    me thinks a can of worms is imminent
    Comments advice
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,873
    Comments advice
    What gearbox was in your R25 GTX
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    8,359
    Comments advice
    I can't imagine how swapping the bell housing could be complex, or how the rear casing could be easy.
    A quick trip up that learning curve ahead of you.
    Good luck, Jo
    Simon's Avatar
    6,105
    It sounds like what you have got is an NG3-000 or NG3-064 from a Fuego (Or an NG1 from an 18 which looks similar with a different bellhousing). There will have lower final drive, and other, gear ratios than those used in the NG3 used in the 25.
    I can't recall what variation your 25GTX is (B29B or B29E), if it is an auto trans conversion or what – or what gearbox is already in the car. If unknown, the identity tag is located behind one of the rear (selector shaft end) cover bolts to the RHS. This will tell you what is already in there, and if it has been changed over the last 30 years. The Fuego gearbox ratios really won't suit the long legged nature of the 25, and the linkage will require stuffing around with to make it work.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Boonah Qld
    2,473
    Pleased to hear from you again Simon. Missed your knowledgeable input.
    don
    don is offline
    Mayfield Newcastle
    427
    Hi Simon many thanks for your advice
    The replacement transaxle was from a fuego with NG3 064
    the box in the 25 (B29B) is a NG3 but obviously a different variant looks like I jumped in too quick here
    Lesson learned
    8,688
    What is the difference between 000 and 064?
    8,359
    64.
    Simon's Avatar
    6,105
    Lesson learned
    Ratio differences below, compared with the NG3-079 which was originally fitted to the B29B:
    Fuego - NG3-064
    Final Drive – 9 x 34
    1st – 11 x 45
    2nd - 17 x 37
    3rd – 22 x 31
    4th – 34 x 33
    5th – 37 x 29
    Speedo drive 6/20
    25 B29B - NG3-079
    Final Drive – 9 x 32
    1st – 11 x 45
    2nd – 17 x 37
    3rd – 22 x 31
    4th – 33 x 34
    5th – 36 x 31
    Speedo drive 6/18
    On another note I was hoping the numerous 102 etc errors and limited upload issues may have been resolved. Obviously not.
    1963 Renault R4 Van
    1964 Renault R4
    8,688
    64.
    Silly bugger.
    don
    don is offline
    Mayfield Newcastle
    427
    still needs a good home as I have no use
    don
    don is offline
    Mayfield Newcastle
    427
    Bump
    don
    don is offline
    Mayfield Newcastle
    427
    Sold
