Difference between the 10s & the standard 10 differential
Results 1 to 11 of 11
Like Tree2Likes
  • 1 Post By Manic GT
  • 1 Post By alan moore
Thread: Difference between the 10s & the standard 10 differential
    Member 61 Gordini's Avatar
    May 2012
    Torquay
    77
    Default Difference between the 10s & the standard 10 differential
    Hi guys,
    I am looking for information that would explain the difference between the 10s Differential and standard 10 Diff.
    Can the standard 10 diff assy be put in to the 10 s box.
    Regards
    61 Gordini
    1000+ Posts Frans's Avatar
    Auckland
    1,536
    As far as I know there isn't a difference in the diff itself and can be interchanged. I'm not sure of the very old R8 diffs in the earlier '60s but when the 10s came out all that was the same. On the R8 Gordini is a difference in that it has 4 spider gears instead of the 2 in the standard R8/R10 boxes.
    If you are going to change that you'll have to make sure that you study the manual in detail to get the pre-load correct on the carrier bearings.
    Regards, Frans.
    Old enough to know better
    Young enough to do it anyway.
    May 2012
    Torquay
    77
    Thanks Frans,
    Regards
    Brett
    11,210
    I'd have to check my parts books, but I thought there were stronger sun and planet gears in the 10S or even later R10 transaxles. CW&P and ratios were unchanged and bearings etc the same AFAIK.
    When I got my 10S box, it was recommended (mid-1980s) as the best of the R8/R10 boxes, and I thought it was those diff internals but I could be quite wrong.
    Nice avatar....
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Jul 2013
    Southampton Ontario Canada
    62
    John from memory of the ones I have taken apart the earlier ones had larger 10mm detent balls in the shift rods and heavier splined planetary gears !
    Manic GT
    Nice avatar....
    JohnW likes this.
    11,210
    Thanks Manic.... I didn't know about the detent ball size! But I though there was something in the planetary gear system.
    They are all Type 330 units, and I think mine is a Version 33 or some high number. It was given new energizer springs in the synchro units and a minor reshimming of the crownwheel carrier bearings back in 1985 or thereabouts. Maybe it was 1977. I can't remember but it is still perfect.
    Auckland
    1,536
    Oops, didn't think the 10S was that special. However it will fit.
    Frans.
    11,210
    Frans.
    Pretty much identical externally. For Oz, the 10S was a production run of probably 1200 (that's how many sets of Australian-made VDO gauges they bought). I've no idea whether they deliberately used a slightly upgraded gearbox - I suspect not and that the later R10s just had that gearbox as it was the then-current version that came from France. Whether anyone actually knows nearly 40 years later...…..
    May 2012
    Torquay
    77
    Thanks for the Info everyone. The 10s box I have is in a Motorkana special and the splines coming out of the diff, which the uni's slide onto, are moving up and down and side to side, so when it is altogether the wheels wobble. The scrutineers don't like it.
    I have a standard 10 box and was considering just putting the diff assy in as a quick fix. I only use 1st and reverse, 2nd has been blocked some how.
    Brett
    Ipswich, Queensland.
    1,939
    I would just fit the complete 10 box that you have as I expect your 10S box to be very tired from all the fiddle brake use. You really shouldn’t just put only the main hemisphere from the 10 into your 10S box as the pinion is not matched to it. The 10S was the latest version that we saw of the 330 type box, but I too didn’t think it was that special.
    JohnW likes this.
    '56 Renault 4CV (16TS Power)
    '62 Renault Dauphine Gordini
    '82 Renault Fuego GTX
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,739
    Just found this in my "Tech Info" ......
    Transmission
    R10 Major 1100
    R10 1300
    Driven wheels
    Rear
    Gearbox
    4 speed, all synchromesh
    Gearbox type
    330-00 (good roads)
    330-03 (bad roads)
    330-22 (USA)
    330-23* (good roads)
    330-24* (bad roads)
    330-26* (USA)
    330-27* (Canada)
    * from jan. 1969 onwards
    330-35 (good roads)
    330-36 (bad roads)
    330-38 (USA)
    330-39 (Canada)
    Gear lever
    on floor
    Gear ratio : 1
    First: 3,62
    Second: 2,25
    Third: 1,48
    Fourth: 1,03
    Reverse: 3,08
    First: 3,62
    Second: 2,26
    Third: 1,48
    Fourth: 1,03
    Reverse: 3,08
    Final drive ratio
    4,125
    4,125
    V1000 in 4th gear [km/h]
    26,2
    26,2
    Clutch
    Single dry plate, cable operated
    Clutch type
    170-DB-275
    Automatic gearbox
    T.124
    Ray
    Ray geckoeng
    Think Old, But Run Modern !!
