R8G front spring insulator/spring rubber/spring top
Results 1 to 24 of 24
Like Tree4Likes
  • 1 Post By R8RX
  • 2 Post By 4cvg
  • 1 Post By alpinesau
Thread: R8G front spring insulator/spring rubber/spring top
    Jun 2018
    Norway
    136
    Default R8G front spring insulator/spring rubber/spring top
    I've tried searching the forum for this, but didn't find anything. I am looking for spring insulators/spring rubber that sits on top of each front spring on a R8 Gordini. Mine are completely broken. I don't want to drive without something between the spring and body. Do anyone have a tip on where I get these or an alternative solution? I've bought two polyurethane spring insulators, but these require a flat top on the spring.
    I haven't manage to find someone who are selling these, only GBS Alpine had some in aluminium, but these where not longer available.
    Boonah Qld
    2,590
    The rear spring has rubber spacers at the top jambed into the crossmember tower. Might they do the job?
    11,104
    Are you sure?
    Both my R8 and R10 factory parts books show a broad rubber washer under the front spring (in the wishbone, that is)and nothing on top of the spring. The rears have a steel annular cup with a shaped rubber pad, also annular, inside it, and these are available I think.
    It'll be hard to find if they never existed, that is for sure.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Jun 2018
    Norway
    136
    The rear ones are too small in diameter to fit on the front spring. I have a set of new rubbers for the rear springs.
    Sunroof likes this.
    Jun 2018
    Norway
    136
    Are you sure?
    I know, my book also shows nothing on top of the spring and a rubber washer at the bottom. But there were some rubber on top of my springs.
    But will the spring sit properly at the top regarding the top of spring is not flat? I don't know if I have original springs either, the rear ones are modified.
    I can fit the polyurethane insulators I bought and see how they fit.
    11,104
    See whether someone here has a pair of springs to photograph..... Mine are in the car but others here have more bits and pieces I expect. I'm thinking the previous owner fitted something on top of the springs for some reason but we do not know what it was!
    Jun 2018
    Norway
    136
    Yes, I see Mecaparts have pictures of their front springs and mine look fairly similar.
    So I think you have the answer regarding the previous owner
    Fellow Frogger! alpinesau's Avatar
    288
    There is nothing on top of the front springs.
    1970 R8 Gordini R1135
    2005 Megane 225 Cup
    2008 Clio X85 Cup Racer
    2014 Megane RS275 Trophy R
    2015 Koleos Expression
    Jun 2018
    Norway
    136
    Ok, thank you very much But it is correct that the top of the front springs are not "flat"? Anyone have a picture of the top on a front spring?
    654
    This is from mecaparts
    654
    Do I note a light taper toward the top? Or is this just an optical illusion?
    Jun 2018
    Norway
    136
    Thanks, I have tried to study that picture before and I have noticed the same as you.
    Dec 2010
    Blackburn Victoria
    501
    I know it is not the correct solution, but here is an alternative to isolate the top
    of the spring from the crossmember.
    This technique was used on R12's
    Clear plastic tubing of the right internal diameter threaded over the first coil
    or two of the spring. make sure the spring is rust free and painted, maybe a little grease
    to help it feed on.
    There will be a minimal increase in the overall spring diameter, but with time it will
    settle in.
    654
    Thatís brilliant Steve! I might also give that a go, as I am about to take the front springs out also and have them reset 25mm higher.)
    Do you think the springs are tapered?
    Feb 2005
    rosevale/tasmania
    2,828
    A mild diversion.
    The alumninium ones ones are not to insulate spring from housing but to increase travel height. (I have used a pair of the thinnest, 13 mm, ones in the 4CVG which was otherwise tending to hit its bump stops on one challengingly bumpy tight corner - lots of weight moved to the front.) They were designed for rally R8G & A110 use.
    As noted, I took the front top to be metal to metal & if a rubber insert was present it might have been an attempt at the same height-lifting task. I would simply remove it.
    cheers! Peter
    Sunroof and JohnW like this.
    Jun 2018
    Norway
    136
    Regarding the rubber I mentioned was on my car, I believe this was used on the side of the spring that did not touch the housing since the top coil of my springs are not "flat". When I took the rubber out I believed it was broken since it only was a "half circle".
    My dad found a set of springs in his garage that he believed was front springs from a R8 and the top coil on these were tapered (if I understand that term correctly, the top coil of the spring were "flat").
    Can someone please confirm the correct shape of the spring. I am going to order new ones if the springs i have is wrong.
    Jun 2018
    Norway
    136
    After studying the springs my father had I have come to the conclusion that the springs I have can't be original ones. So I am going to replace them.
    Do anyone know if the springs Mecaparts are selling is stiffer than original ones?
    11,104
    You know, all I can remember is that on the rare occasions I have had the front springs out (once or twice in 40 years is all that has been needed) they fitted neatly against the cross member, so I guess they are set up more or less flat across the top.
    Mecaparts seem focussed on competition parts, so perhaps you'd expect stiffer springs. They do respond to English language questions, so I'd ask them by email.
    Good luck.
    288
    John W is correct. The R8 front springs are flat on top. They are located rotationally by the bottom wishbone shape. There is a thin (~1.5mm rubber) insulator under the front spring. They are typically torn though.
    See these photos of a couple of my spare front springs.
    JohnW likes this.
    2005 Megane 225 Cup
    Jun 2018
    Norway
    136
    Good luck.
    Thank you, yes, that is what I figured out too.
    Got an e-mail from Mecaparts today. Stiffer ++ was the answer.
    Jun 2018
    Norway
    136
    Quote Originally Posted by alpinesau View Post
    Thank you for your pictures. Looks just like my father's springs. Is the bottom of your springs also flat/nearly flat? Yes, haven't seen the insulator on any of my bottom wishbones.
    11,104
    The bottoms are not quite flat and are located rotationally by the shape of the cup in the wishbones, maybe with a rubber disc a few mm thick if I remember correctly.
    Jun 2018
    Norway
    136
    Thank you!
    Ok, I guess is it hard to see exactly how the top and the bottom is on the pictures on the Mecaparts website. And as you say, the bottom does not look entirely flat. I have ordered a set of the longest springs, so just have to wait and see how they are.
    11,104
    We will be interested to hear the news when you get the new, long springs. Good luck and best wishes.
