807-13 Rebuild
Results 1 to 16 of 16
Like Tree13Likes
  • 1 Post By JohnW
  • 1 Post By COL
  • 1 Post By driven
  • 3 Post By alan moore
  • 1 Post By COL
  • 1 Post By schlitzaugen
  • 1 Post By Bernie
  • 1 Post By Exfrogger
  • 3 Post By schlitzaugen
Thread: 807-13 Rebuild
    Jan 2011
    Canada
    5
    Default 807-13 Rebuild
    HI:I am about to reassemble a 807 and wondered if there was a PDF of a manual showing me the dos and do nots.I have rebuilt other wet sleeve engines but it's what you don't know that can sink you.
    11,214
    Welcome here! Good start too - best to get it right!! There's always something cute you need to know....
    Have you joined the Renault Owners Club of North America? You'll find some companions there too.
    Bernie likes this.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,290
    There is a couple of R17 workshop manuals on Ebay that will have the information that you require
    https://www.ebay.com/itm/1971-1972-1...hbuRSj&vxp=mtr
    https://www.ebay.com/itm/1971-1972-1...pbuQ0j&vxp=mtr
    Bernie likes this.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Jan 2011
    Canada
    5
    HI:Yes those look good but they want 50.00CND shipping costs and Canada is right next door.
    Believe it or not its cheaper to mail stuff from GB or Aus than from a 2 hour drive from Toronto!!!
    Jan 2011
    Canada
    5
    Hi JohnW:Thanks it is now on my to do list.
    I just finished restoring a Sunbeam Tiger and am enjoying the autumn weather before a crazy season comes here to Canada called:winter.(snow, ice etc)
    1000+ Posts driven's Avatar
    Apr 2005
    1,546
    Get it free
    65 Mb download, very detailed
    Renault R-17 Workshop Manual
    Bernie likes this.
    Ipswich, Queensland.
    1,941
    Most important thing when assembling is to get the liner heights right, and I use Loctite No. 3 non hardening sealant at the liner seals, as the blocks generally have some corrosion around the liner bases now.
    COL, JohnW and Bernie like this.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,290
    The next most important is to get the head gasket on in the right place and torqued down in the correct sequence.
    Bernie likes this.
    Regards Col
    1973 Alpine A110
    Apr 2005
    1,546
    Didn't the 807-13 have o-rings on the liners.
    Also check out
    Donor Cars
    11,214
    That's an interesting and pertinent comment, having watched the assembly of Shoji's engine by Geckoeng. Liner seats were indeed a bit dubious but repaired. I'll look into Loctite #3, for which thanks.
    I've just torqued down the head on my Dauphine-Estafette-Gordini engine, to be known as DEG in the future. I ended up with 6 thou to 8 thou proud, as all other copper rings were less than 4 thou. So I went for a bit more rather than a bit less and managed to avoid shimming too-thin copper rings. I imagine Loctite #3 would be good for shimmed liner seals - shimming being common/standard practice among some of the Southern African folk I know!
    9,253
    Some idiot has posted this in the wrong thread:
    I was going to add pretty much the same things.
    Manuals are very good, but they don't warn you of problems that did not exist on the assembly line.
    I would first check the block to make sure it's ready to go. This includes corrosion at the liner base, straightness of the crank tunnel, roundness of bearing blocks, deck height/flatness/straightness. If any machining is necessary better do it before you start to put stuff in.
    This means you will need to do some test assembly with the liners in and checking protrusion height as well as liner seat sealing, block deck height/straightness/flatness.
    How's the crank? All good? Checked?
    Camshaft?
    Rocker arms? These can have side play on the shafts. The shafts may be worn, or the rocker arms, or both. What's the state of the pushing pads on the rocker arms? All good?
    Tappets need to be perfectly flat. Are they? Is the case hardened surface intact?
    And so on.
    The book(s) don't help much with any of this, but if you have experience as you say and a handy engine shop around the corner, shouldn't be a drama.
    Bernie likes this.
    ACHTUNG ALLES LOOKENPEEPERS
    Jan 2011
    Canada
    5
    HI:
    Thanks for the advice and URL's.
    "If any machining is necessary better do it before you start to put stuff in."Its all been ground and plasti-gauged.
    When I did the other wet sleeve I used a dial indicator to make sue of the protrusion height(amount and equal)
    The head gasket has to set just so and I have made threaded dowels to try to make sure of a perfect landing.
    I appreciate it all because any job undertaken is way better done properly the first time.
    Thanks again
    Bernie
    JohnW likes this.
    Nov 2005
    Geraldton
    1,624
    Hi Bernie
    Ditto the above remarks.
    If the liners are not new check for pitting on the liner lands (where the seal sits).
    When checking for corrosion in the block where the liners sit also note if there is any scale build up, This might also be small bits of the previous seal. Pick at this with a suitable tool. I've also run around the lands with a soft brass rotary brush on an electric drill.
    The seals around the rear main seal are fiddly and need careful attention.
    If the crankshaft is out, locate the seal on the journal before installing the cranshaft. Install the CS and locate the the journal cap over the seal and tighten as per the book. The chances of finding the appropriate mandrel - and one on good condition - are remote.
    The precise location of the head on the block and the correct torque settings on these engines seem to be a little more critical than on other engines. Using fine bottle brushes to clean the the threads taking the head studs makes a difference as does wire brushing the studs bolts themselves. An air line, degreaser and acetone are your friends here. A test i like to perform is having cleaned the threads, finger tighten all the bolts without the head on. They should all be equally easy to tihten.
    Dressing the cam follower faces is recommended as is radius grinding the rocker arms. Both these can be done at home if you're patient.
    That said, these motors is pretty straight forward, its a blessing that they are so light too.
    P
    Bernie likes this.
    In the Shed(s):
    In the Past:
    11,214
    The only thing I'd add after many hours recently doing this is to be absolutely certain of the cleanliness of all oil passages, including crankshaft and rocker shaft drillings. I removed the end plugs and put a lot of effort into getting some nasty, abrasive sludge out. It just kept coming..... Nothing to do specifically with wet sleeve motors of course.
    Jan 2011
    Canada
    5
    HI John W:
    I had the block dipped, power-washed and re-dipped and top and bottom trued at an engine re-builder here in town.
    Al blocks can get warped if they over heat somewhere in their past life.
    All hints and watch-out-fors are appreciated.
    Bernie
    9,253
    I would say you still need to take the core plugs out and clean the oil passages. I have had my block dipped as well, but there are small oil passages that do not get cleaned. I used small bottle brushes like those used for guns and a pressure washer for the smaller passages going to the crank bearings and such.
    Or maybe you want to trust your cleaning place.
    Another one I just remembered is the rocker arm shafts. These have core plugs in the ends as well. You need to remove those and clean inside. There are copious amounts of muck that collects inside until the rocker shaft is blocked and you have no oiling of the bearing surfaces of the rocker arms.
    JohnW, Sunroof and Bernie like this.
