R12 wipers not returning to rest automatically
Results 1 to 12 of 12
Like Tree3Likes
  • 3 Post By IThompson
Thread: R12 wipers not returning to rest automatically
    Fellow Frogger! IThompson's Avatar
    Sep 2011
    Bendigo / VIC
    226
    Default R12 wipers not returning to rest automatically
    On my R12 the wipers have stopped automatically returning to the rest position.
    i have to carefully time turning them off .
    any thoughts on how to fix it?
    ian
    4,422
    Maybe try checking the connections on the switch (assuming it’s the dash mount type not a stalk), or change the switch itself?
    KB
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,253
    I have never had any problems with R12 wiper motors, but I would look for broken wires or bad connections at the wiper switch and at the motor.
    I would try another wiper switch first and see if that fixes the problem as it is the easiest part to change.
    If all is good there it could be the wiper contacts that are in the gearbox on the end of the motor that could be the problem, these perform the self parking function along with a contact in the wiper switch.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Sep 2011
    Bendigo / VIC
    226
    Thanks i thought it might have something to do with the wipee motor.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,253
    Quote Originally Posted by IThompson View Post
    If you have a spare switch try that first, could save you a lot of work and time.
    Regards Col
    1973 Alpine A110
    Jul 2013
    Southampton Ontario Canada
    58
    In the past any troubles of that sort I found it to be bad grounds and ran a new ground to the frame of the wiper motor to the body ?
    Manic GT
    Sep 2011
    Bendigo / VIC
    226
    Thanks i will look into it.
    moving house soon so it may take a couple of weeks.
    8,454
    Quote Originally Posted by Manic GT View Post
    Manic GT
    This fix sounds familiar, and is easy to try.
    Jo
    9,168
    And that's even easier to try if you have jumper leads.
    ACHTUNG ALLES LOOKENPEEPERS
    Nov 2011
    Norway
    60
    I dont know the wiper mechanism on the R12 but I've had this fault on mk1 R5 and a nineties Fiat Ducato. On both it was down to the wiper(sliding connector) that provides the motor with current until the parked position. On the R5 it needed some bending on the Ducato it was broken off and needed soldering.
    Brisbane/Australia
    2,142
    It's not likely to be a faulty earth or the wiper wouldn't work on any speed.
    It could be the the sliding contact in the motor as ReidarUF mentioned.
    The wiper crankcase has grease inside and this could be fouling the contact or the contact could be work out after 45 or more years of life. If the copper tracks or contacts are work out then replacement is the only solution. Dirty/corroded contacts can be cleaned.
    Or it could be wiring related with either the terminal on the plug making bad contact or corroded or the switch could have a bad connection internally. Try substituting the switch with another one and if that doesn't work measure the voltage on the park wire.
    It should be reading battery voltage until the wipers are in the park position.
    Remember, the rocker wiper switch from the early 12's is different internally from the stalk type switch from the later types so they are not interchangeable. Likewise the wiper motors from the early and late types are nor interchangeable unless you change the terminals.
    RTT
    Sep 2011
    Bendigo / VIC
    226
    Thanks everyone for the advice.
    I finally got around to looking at the wipers not returning automatically. (I moved house and had a baby recently)
    I did the easy thing first and replaced the wiper switch on the steering column.
    The wipers are working fine now.
    thanks. ian
    COL, Sunroof and chodaboy like this.
