Ye old car wiring (yeah ok 70's and 80's)
Like Tree2Likes
  • 1 Post By bowie
  • 1 Post By Geoff in Gully
Thread: Ye old car wiring (yeah ok 70's and 80's)
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,395
    Default Ye old car wiring (yeah ok 70's and 80's)
    So just thinking ahead to that next rainy day (as if). A recent found love of relays has me all excited.
    Who knew with some fuses how handy these things would be!
    Anyway was just looking over the Haynes to get an idea of how many circuits ye old things have; I think I understand the wiring diagram (I don't understand the wiring diagram) Is this really, pretty much all there is in say a 70's Renault / Peugeot
    LIGHTS
    -Left indicator front
    -Right indicator front
    -Left indicator rear
    -Right indicator rear
    -Hi beam
    -Low Beam
    -Parkers
    -Interior light
    -Boot light
    ACTUALLY USEFUL
    -Fuel pump (rear)
    -Coil
    -Fan (sometimes)
    -Horn
    -Dash (instrument cluster)
    -Radio (sometimes)
    -Starter motor
    -Windscreen spray pump (maybe)
    SENSORS
    -Handbrake sensor
    -Brake sensor
    -Brake fluid (sometimes)
    -Oil temp
    -Water temp
    -Reverse (maybe)
    That seems, well not overly that complicated. What circuits have I omitted?
    Anyway I'm about to wire up the ECU, fan and coil pack properly, (relay's switches and fuses) and I'm going to throw on a few circuits in effort to be prepared for the next stage of tinkering.
    Shoji likes this.
    1000+ Posts Shoji's Avatar
    Jan 2012
    Mandurah WA
    1,101
    Geez. the mind boggles. I'm about to do the same thing Bowie. Add an ECU to ye old R17. But i will do as the directions dictate.
    and adding extra gauges. let me know your thoughts as we can share ideas. I'm looking at a relay box of about 4 relay's. but I don't want it seen under the hood but may have too.
    Fellow Frogger! Geoff in Gully's Avatar
    Ferntree Gully
    662
    LIGHTS
    -Hi beam
    -Low Beam
    -Parkers
    -Interior light
    -Boot light
    ACTUALLY USEFUL
    -Fuel pump (rear)
    -Coil
    -Fan (sometimes)
    -Horn
    -Radio (sometimes)
    -Starter motor
    SENSORS
    -Handbrake sensor
    -Brake sensor
    -Oil temp
    -Water temp
    -Reverse (maybe)
    Wipers
    Rear window demister
    Fuel gauge sensor
    Alternater / charging circuit
    Battery charge indication
    Reversing lights
    Sunroof likes this.
    There is a solution to every problem. There is a problem with every solution.
    • Renault R4L '63 - Descartes
    • Renault R4L '64 - Lucy
    • Renault Megane '07 - too young to have a name...
    4,377
    You can buy relay mounting blocks that slot into each other off eBay, so you can customise how many relays you need.
    I mounted mine in two rows.
    KB
