Question: 1.4 -1.3 Flywheel swap?
Results 1 to 11 of 11
    Nov 2005
    Geraldton
    1,574
    Default Question: 1.4 -1.3 Flywheel swap?
    Hi All
    I sold a clutch kit to someone with an R12 1.3 (842-01) and it turns out the clutch kit was for a 1.4 (no idea why I had it).
    Anyway they think among the rubble they may have a 1.4 flywheel and rather than hunt down another clutch they're thinking of swapping flywheels.
    Cant say I have the foggiest notion as to whether its doable. Anyone tried it?
    (Yes I know there's people looking for 1.4 flywheels and clutches but right now I don't own either.)
    All the best
    P
    In the Shed(s):
    In the Past:
    Nov 2011
    Norway
    60
    As I remember the old engines up to the 1,3 have an even bolt pattern while the 1,4 have a slightly uneven bolt pattern to make sure only one position is possible.
    4,379
    Yeah, pretty sure the number of bolts and/or the pattern (as reidaruf mentioned) varies between the two flywheels.
    I alluded to the fact I may know a buyer for the 1.4 kit if it becomes up for sale in your wanted ad.
    KB
    1000+ Posts Frans's Avatar
    Auckland
    1,500
    As far as I can remember, without accurate dimensions for the old 1100s, they had a 5 bolt small center hole about 37mm dia. Then they became around the 1300 era 7 bolt 37mm centers. And the very last ones became 7 bolt 47mm centers.
    So it should be easy to see if they have a 7 bolt small center or 7 bolt large center. In ZA they all took the 180 mm clutch plate, some were heavy and looked like a porridge plate with a heavy ridge on the outer edge but they were the same from the base of the flywheel too the clutch face. (thickness).
    Frans
    Old enough to know better
    Young enough to do it anyway.
    4,379
    1.4 Flywheel (Lightened) vs 1.3 flywheel (visible on Blue engine/Blue rocker cover)
    Attached Thumbnails Attached Thumbnails Question: 1.4 -1.3 Flywheel swap?-dscn1295.jpg   Question: 1.4 -1.3 Flywheel swap?-dscn1817.jpg
    KB
    Mar 2015
    Geelong Australia
    67
    I have a few R12 new pressure plates if you need them [ or one ] $40 ea. 03 52218915
    10,815
    Quote Originally Posted by Toolman View Post
    What diameter please?
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Nov 2005
    Geraldton
    1,574
    According to my research the R10 1108cc is, 160mm, the 1289cc is R12 170mm, and the R12 1.4 is 180mm.
    In the Shed(s):
    In the Past:
    4,379
    I believe that’s correct too BUT, I’ve never confirmed if that is flywheel diameter or clutch driven plate diameter. Mine are all installed in cars, so can’t measure for you.
    KB
    Nov 2011
    Norway
    60
    Pretty sure thats the diameters on the clutch plate.
    10,815
    My question about diameter was actually directed at the pressure plates you have in stock. I should have been clearer!
    Renault 4CV 1951
    Renault R8 1965
