what do I have and what can I use?
Page 1 of 4 1234 Last
Results 1 to 25 of 99
Like Tree47Likes
Thread: what do I have and what can I use?
    Jun 2018
    32
    Default what do I have and what can I use?
    First time poster and 'Renault' owner hoping for a little info from those more informed than myself.
    I bought a little open wheeler race car powered by what I have been told is a bog standard Renault 12 engine and box. The engine plate says 810-05. It seems to be in good condition, but from what limited info on the 12 I can find on the net, it inly has 60hp. This will be fun while getting to 'know' the car, but obviously I will want more power down the track.
    First question is, what is this engine exactly and second question is, what other engines ( preferably budget friendly) can i bolt up to this gearbox directly?
    Attached Thumbnails Attached Thumbnails what do I  have and what can I  use?-20180708_074443.jpg   what do I  have and what can I  use?-received_2061159584136127.jpg   what do I  have and what can I  use?-received_2061159607469458.jpg
    nauli, lozenge, bowie and 1 others like this.
    1000+ Posts Shoji's Avatar
    Jan 2012
    Mandurah WA
    1,164
    Welcome Saje
    Yes it's a r12 motor alright. You have a nice bit of kit there. 4 speed box? Twin SU's I think. Could you track down the history of the engine builder maybe? interesting what's been done to it. More photo's please.
    bowie likes this.
    Newcastle
    2,746
    Hi saje
    Good looking bit of kit there. The Renault motors are pretty tough and respond to all the usual ways of getting more power out of them. Perhaps a play in that direction would be a bit of fun if it is standard inside.
    Being a bit lazy now I would consider a supercharger which is an easy way to get an instant increase in the effective size
    good luck Jaahn
    1000+ Posts Frans's Avatar
    Auckland
    1,527
    Welcome, from what I can see is; it looks like a modified Renault bottom wishbone. The rack & pinion steering arm are at huge angles which might make it twitchy with bump steer. A R12 engine and gear box because the engine pulls the drive wheels as in a R12. Definitely twin SU Carbs. Will be nice and noisy. It might have a few mods from looking at the carbs and a little extractor, so you may have an extra horse or two. I can't identify the brakes but it looks good from far away.
    I am curios about the cooling system. A radiator behind the seat and a huge air intake in front. How do you get the air to the radiator?
    You can turn a similar engine, but 1400 or more into a 100hp plus engine reliably with some proven mods. That could scare you with the power to weight ratio.
    Shoji, JohnW and bowie like this.
    Old enough to know better
    Young enough to do it anyway.
    Jun 2018
    32
    Thanks for quick replies!
    This is a true budget job. Very simple and breaks quite a few engineering rules but also some clever stuff done to build a cheap racer using as many R12 bits as possible. Don't think builder knew what triangulation is. Lots of basic mods to bring safety and rigidity up. Already made gearshift linkage with less throw and slop than the previous. Almost finished rewiring the birds nest.
    SU carbs are off as twin 1 3/4 " seems a little over carbing and manifold was a really poor home made effort, completely unmatched with nice puddle collectors at manifold face. I put the weber which came with it on and runs much better.
    Not too worried about suspension geometry YET , though will eventually be fully Rose jointed, lighter A arms and revised geometry etc. Steering rod angle easily reduced by mounting outer end UNDER steering arm though i conditioning hink it was mounted above as arms are fully wound in so no other way to toe in except mount high.
    This will remain a very tight budget car. If this is an R12 am i correct in thinking it's pumping out a whopping 60hp. I'm not able to spend several thousand to get an extra 20hp. I'd rather sell this one ( it's in great condition - what might it be worth as a means of helping pay for the next engine?) bolt on a different bog standard larger cc Renault engine already putting out higher numbers. If that option costs more than $500 then might as well go motorbike engine.
    Brakes are single pot and use original unadjustable master cylinder.
    I think the front opening was an effort at downforce. Second owner added those 'wings' (air brakes :-) Front is a piece of flate composite something and rear is a curved piece of aluminium, not airfoils. Will be making a new nose and wings at some stage.
    Attached Thumbnails Attached Thumbnails what do I  have and what can I  use?-20180810_125720.jpg   what do I  have and what can I  use?-20180810_125709.jpg   what do I  have and what can I  use?-20180810_125544.jpg   what do I  have and what can I  use?-20180810_130158.jpg   what do I  have and what can I  use?-20180810_130148.jpg   what do I  have and what can I  use?-20180810_130141.jpg
    Shoji, bowie and renoamust like this.
    Boonah Qld
    2,590
    What class would it compete in and how did it perform previously?
    bowie likes this.
    Jul 2004
    CLARE SA
    2,324
    onya, saje
    stepping straight into interesting in post 1
    welcome and seems your set for tons of fun, congrats and best of french motoring ...
    ed
    Jan 2012
    Mandurah WA
    1,164
    Look what they've done with the front drive shafts. Please keep the engine Renault, maybe 807 - 84" series for more hp
    Sunroof likes this.
    Boonah Qld
    2,590
    Quote Originally Posted by Shoji View Post
    Agree. Please saje and keep us updated once your competing.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,252
    There must of been a few of these things built around the country, remember seeing it at the Brisbane French Car Display in 2010.
    Here is a pic of it.
    Attached Thumbnails Attached Thumbnails what do I  have and what can I  use?-dscf3991.jpg
    jaahn, Shoji, bowie and 1 others like this.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Jun 2018
    32
    That's the beast!!! Thanks Col.
    It would be eligable for track days, sprints, hillclimbs and lots of laughs from those more well heeled in the paddock.
    jaahn, Sunroof and bowie like this.
    Jun 2018
    32
    Col, did you take any other photos?
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,252
    Quote Originally Posted by saje View Post
    Yer I have about 8 pics of the car, I can put the rest up later.
    Regards Col
    1973 Alpine A110
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,252
    Default Brisbane French Car Display 2010
    The pics that I took in 2010
    Attached Thumbnails Attached Thumbnails what do I  have and what can I  use?-dscf3983.jpg   what do I  have and what can I  use?-dscf3982.jpg   what do I  have and what can I  use?-dscf3984.jpg   what do I  have and what can I  use?-dscf3985.jpg   what do I  have and what can I  use?-dscf3986.jpg   what do I  have and what can I  use?-dscf3987.jpg
    what do I  have and what can I  use?-dscf3988.jpg   what do I  have and what can I  use?-dscf3989.jpg   what do I  have and what can I  use?-dscf3990.jpg   what do I  have and what can I  use?-dscf3991.jpg   what do I  have and what can I  use?-dscf3992.jpg   what do I  have and what can I  use?-dscf3993.jpg
    jaahn, JohnW and bowie like this.
    Regards Col
    1973 Alpine A110
    Jan 2012
    Mandurah WA
    1,164
    Great pics Col. A lot of Renault 12 in there. Thanks for posting
    bowie likes this.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,252
    Yer when I was looking at it and taking pics, I was adding up all the Renault 12 parts that were used
    Regards Col
    1973 Alpine A110
    Jan 2012
    Mandurah WA
    1,164
    They certainly cut up one and needed to borrow from another for all the front end gear that's for sure. Bowes would like this.
    Sent from my Moto G Play using aussiefrogs mobile app
    bowie likes this.
    11,104
    Wow. You know, I'm amazed at the hours that someone must have put into getting that car together. It's easy to say "R12 etc" but that is hundreds of hours.
    Do we know who did it and the history?
    Lovely work.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Citroën CX Pallas 1980 (moved on to new custodian)
    Jun 2018
    32
    Thanks for great pictures Col.
    First owner and i believe, builder, was Bryan Morrow.
    BTW, are there any alternative oil filters to the Z71? If not, where can i purchase ghe Z71 (i live in Blue Mountains NSW).
    9,235
    Give EAI at Thornleigh a ring, and see if they can match it with a Purflux. They are a major source for French car parts in Sydney. Purflux are very high quality and not expensive. Next day courier.
    11,104
    Purflux alternatives are out there, and Mann judging by my stash. If you go Googling you'll find them. I really like Purflux for size and the lovely spanner you can buy to get them off! I had years of belting in a big screwdriver to undo the Z71 filters...
    I have Purflux LS144B and LS169B in use on the R8. They have a 3/4" thread on these Renault applications. I think I bought a stash of them on ebay from Europe a few years ago but there are suppliers in Oz, which someone will no doubt post shortly!
    Nice buy. I still marvel at how much work was done to make it!
    Jun 2018
    32
    Thanks for the Purflux info, will look into it.
    Jun 2018
    32
    Well my search for engine and gearbox weights have not born me any fruits. Does anyone know what a Renault 12 engine and or box weighs please?
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,252
    I use Mann Filters, these are German made. I bought a bulk lot from Sydney Filters ages ago. The part number is W77
    Regards Col
    1973 Alpine A110
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,252
    There is thread on here somewhere that has some of that info in it. Can't remember which thread off the top of my head, but will have a look when I get a spare moment.
    Regards Col
    1973 Alpine A110
