what do I have and what can I use? - Page 4
Page 4 of 4 First 1234
Results 76 to 99 of 99
Like Tree47Likes
Thread: what do I have and what can I use?
  1. #76
    Jun 2018
    32
    Spending most the last few weeks (when i get the chance) replacing floor, bracing chassis and fabbing new gearshift mechanism.
    I know there are 40mm weber manifolds for this engine, but just wondering if there are 45mm manifolds? I ask this as i could possibly adapt the 1 3/4" SU carbs to that instead of trying to fix manifold that i have, which will never be a great result , though better than what i have now.
    Attached Thumbnails Attached Thumbnails what do I  have and what can I  use?-20180831_165141.jpg
    bowie likes this.
  2. #77
    Jun 2018
    32
    Or maybe i should just run this carb. Any ideas on jet/tube sizes?
    Attached Thumbnails Attached Thumbnails what do I  have and what can I  use?-20180911_025319.jpg
  3. #78
    Fellow Frogger! nauli's Avatar
    Oct 2017
    Perth, WA
    285
    I will have a 40 DCOE Weber (Italian & recently rebuilt) and associated manifold from the V85 engine in my A110 available for sale in the next 4 weeks or so if you're interested....would bolt straight onto your engine.
    1969 Alpine A110
  4. #79
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,315
    That attached carb looks likes a 38/38 DGV?
    That should go alright, As for calculating jet size... You have some reading (because I'm not sure). Perhaps as a starting point.
    https://www.classicrallyclub.com.au/..._DVAndrews.pdf
    And general gossip about the DGV's
    Tech Wiki - Weber 32/36 Carburetor : Datsun 1200 Club
  5. #80
    Jun 2018
    32
    what do I  have and what can I  use?-20180911_123533.jpgHaving intermittent ignition probs at the moment making tuning impossible. Got a spare old coil will try later. Also will need a low pressure fuel reg as electric fuel pump runs at 7psi and max seems should be 3 if i recall.
    Bowie, thanks for link. I chipped away the epoxy on carb body and found the carby to be a 34 DMS. It is progressive and not synchronous and is apparently an upgrade for some fiat spiders. Running very rich in my beastie though.
    I bought some JB Weld to build up the SU manifold porting (thanks US drag tuners for that tip)and will try to shape it more favourably for entry to head ports.
    bowie likes this.
  6. #81
    Dec 2004
    747
    Saje Brian morrow was in Kempsey sporting car club so you may be able to contact him through them, where abouts in the blue. Mountains are you as I'm working at Lithgow and would like to have a look
  7. #82
    Jun 2018
    32
    Hi Peter, I'm in Winmalee.
  8. #83
    Jun 2018
    32
    Well it wasn't the coil. Looks like the aftermarket electronic ignition module is either playing up or goneski. Would go the cheapest way possible and put points back in but unfortunately the points cam was removed to fit magnetic trigger.
  9. #84
    Aug 2002
    3,315
    Ah, well surely someone has a dizzy floating around you can just test with?
    If not, I'll have a dizzy you can borrow in a week or so.
  10. #85
    Jun 2018
    32
    Just talked to builder of the car and he says engine is bog standard, didn't fit new cam etc.
    Going back to points in dizzy. Where can i find theee in Australia?
    Mostly disappointed to miss out twice on superchargers for under $100. Gotta be quick.
  11. #86
    Jun 2018
    32
    Bit of a nightmare fixing ignition issues. Turns out was electronic ignition module, and side sparking spark plus. Running rich but pretty good now. Just need to strengthen harness mounts and ready to go. And missed on another supercharger.
    Sunroof and bowie like this.
  12. #87
    8,762
    I think I might have a bog stock R12GL dizzy somewhere if Bowie didn't take it. Let me know and I'll have a look. I'm in WA.
    ACHTUNG ALLES LOOKENPEEPERS
  13. #88
    Aug 2002
    3,315
    You did send me a dizzy when you looked after me with those manifolds and zee Weber (sorry Saje).
    But if you still are having any drams, I'm about to replace my dizzy with an ecu, you could have an extended loan of the dizzy if you needed
  14. #89
    Oct 2017
    Perth, WA
    285
    I will have a Ducellier distributor available in a week or two from my V85 engine
    1969 Alpine A110
  15. #90
    Jun 2018
    32
    Thanks heaps for the offers but got the dizzy running well with a little work. Running sweet now.
    bowie and nauli like this.
  16. #91
    Jun 2018
    32
    All ready to go-or so i thought. Turns out one front brake hose is cactus. Anyone got a renault 12 front brake hose before i order a new one?
  17. #92
    Aug 2002
    3,315
    The flexible hose from the caliper?
    Sorry.
    I reckon it wouldn't be that exotic, take it off and walk up into a brake place?
  18. #93
    8,762
    Yeah, but avoid any of the national franchises (you know who they are). They think metric fittings are exotic and have asked me once for 400$ to replace the hosery on my 12. Got new hoses off ebay at a fraction of the price and fitted them myself.
  19. #94
    10,666
    Metric? All my Lockheed brake fittings on the Renaults are imperial and the brake places can make up a new hose with new material to Australian standards. They have had the correct end fittings in stock every time I've needed hoses. $50 per hose last time I think, not bad when you consider Audi service places charge, I'm told, over $200 per hour.... I've given up buying hoses of indeterminate age from OS.
    Maybe R12s are metric, but R8/10 are certainly not.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
  20. #95
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,907
    R12's are imperial on all the brake fittings.
    The Virage is where things changed, the wheel cylinders and calipers are imperial but the master cylinder is metric.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
  21. #96
    8,762
    I don't know what the guy was on about and I didn't check because I didn't need to have new hoses made. But that's what he said. Maybe he was trying to pull my leg. For 400$ it was worth a shot.
    Now considering your brakes are Lockheed, (perhaps Aussie content?) maybe that explains why they are imperial. Not sure what the brakes on my R12 were.
    Overseas, I would be surprised if anything was not metric. After all the french invented the metric system.
  22. #97
    10,666
    The imperial threads were used in France on Lockheed brakes, nothing to do with local content. I was quite surprised when I discovered this a few years ago. Very surprised actually!!
    My 4cv has huge connectors, used on trucks the brake place said. I can't recall the size but it was something like 11/16" and the fine threaded ones on the later 4cv/Dauphine/R8 etc also are some funny imperial thread, 3/8" or something. Early small ones used a copper washer and later ones sealed on an internal taper maybe? Again, can't recall exactly but they are all imperial.
    I reckon being able to get brand new hoses made down the road is terrific. You can therefore get braided stainless hoses and improve things even more.
    Renault 4CV 1951
    Renault R8 1965
  23. #98
    8,762
    The french caving in to imperialism! Sacre bleu! Zet iz umpossibl!
    There you go, nobody's berfect.
    jaahn likes this.
  24. #99
    Jun 2018
    32
    Thanks for the help. Found new ones on Ebay from the U.S. All countries used 3/8" 24 t.p.i. All up shipped here cost $41 for a pair. Nice.
