Retractable seat belts R17
Results 1 to 17 of 17
Like Tree7Likes
  • 2 Post By COL
  • 1 Post By driven
  • 2 Post By 4cvg
  • 1 Post By Sunroof
  • 1 Post By Jensen
Thread: Retractable seat belts R17
    Fellow Frogger! Jensen's Avatar
    377
    Default Retractable seat belts R17
    Where does the retractable mechanism part of the front seat belt attach to in a R17?
    I canít find any useful photos on the interweb (most show the earlier non retractable belts). The parts manual doesnít really show it.
    Iím guessing it shares the same threaded hole with the lower end of the rear seat belt? That way it would go close to vertical to the anchor point high up on the C pillar and the other end bolts to the hole near the front seat (on the lower sill).
    Can anyone confirm?
    2002 Monaco Blue Renaultsport Clio 172
    1975 R1317 Renault 17 Gordini
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,057
    Hi Jensen
    PM me your email address and I will scan the appropriate pages out of the parts book
    Shoji and Exfrogger like this.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    1000+ Posts Shoji's Avatar
    Jan 2012
    Mandurah WA
    1,101
    Hi Jensen
    Hi Col.
    That would be interesting. would you mind sending it to me as well?
    ďListen very carefully, I shall say this only once.Ē Cheers. John
    Fellow Frogger! G4ME's Avatar
    Feb 2003
    810
    Hi mate. I can send you a photo of mine when I get home. Itís on the pillar just above the floor.
    There is a law against doing more than 100kmh...there's no law on how fast you get to 100kmh!!!
    Nov 2005
    Geraldton
    1,572
    This thread is most timely. Just yesterday I was checking out the web for people doing licensed rewebbing in Perth. My R17 belts need some love too.
    I too wondered if there was an inertia reel belt suitable for these cars. I remember a while back a thread, debate really, on the relative safety of inertia real belts, i think the jist of the anti side was that there was so much give in the belt that the occupant would hit something before the belt stopped taking up the slack/stretching. Given the R17 belt is already quite long this might be an issue to consider.
    That said, Col, could you please include me in the mailout.
    Peter
    In the Shed(s):
    In the Past:
    Fellow Frogger! nauli's Avatar
    Oct 2017
    Perth, WA
    339
    Peter
    My A110 has retractable belts which were done by somebody in Kewdale. Colin Bonney could tell you who....
    1969 Alpine A110
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,057
    Emails sent fellas
    Regards Col
    1973 Alpine A110
    Nov 2005
    Geraldton
    1,572
    Thanks Col
    In the Shed(s):
    In the Past:
    Nov 2005
    Geraldton
    1,572
    Quote Originally Posted by nauli View Post
    Thanks Nauli
    In the Shed(s):
    In the Past:
    1000+ Posts driven's Avatar
    Apr 2005
    1,432
    Make certain all is good with an Engineer on theses mods.
    You only have one life
    Shoji likes this.
    Jan 2012
    Mandurah WA
    1,101
    Yes I had mine done with a mob in Perth but can't remember who it was. $450 later. Lap sash gone.
    No damage to any upholstery. I was very adamant about that.
    Feb 2005
    rosevale/tasmania
    2,754
    Peter
    I was the author of the "anti" case in those threads. If there is any technically feasible way of fitting a manually adjustable 3 point belt to the R17, then I'd recommend doing so & avoiding the more dangerous inertia-reel alternative - rationale available on request.
    cheer! Peter
    Nov 2005
    Geraldton
    1,572
    Rather than hijack this thread would you be so kind as to bump the original thread.
    Ex
    In the Shed(s):
    In the Past:
    377
    Thanks everyone including COL for the info.
    A bit more searching today and I found a photo showing the inertia reel seatbelts in a 17 (albeit a phase 2... those seats!).
    https://c1.staticflickr.com/9/8177/8...9d9c028b_b.jpg
    Turns out the rear door cards in the later cars are differnet. They donít have an arm rest (which would otherwise interfere with the seat belt path) and the mounting hole on the pillar is closer to the front.
    I remembered I had put some earlier door cards in mine with the arm rests. I just removed one and can confirm there were both threaded holes in position to fit the inertia belts, and threaded holes to mount non-retractable belts.
    Iíll have a read of the seat belt thread to inform which way I progress.
    Feb 2005
    rosevale/tasmania
    2,754
    Ex
    I have no idea where it is; I simply responded to your remark.
    So-called hijacking of a thread can also be viewed as a conversational enlargement & enrichment, a long-standing AF tradition of some merit. It is easy to scroll past entries which are irrelevant to one's interest.
    cheers! Peter
    Sunroof and Exfrogger like this.
    Boonah Qld
    2,532
    cheers! Peter
    I agree Peter. No normal conversation with a group of people continues with the same theme. It may start with the weather then what is the latest with your kids because their football match was rained out, and then move some where else. One subject leads to the next. I scroll on if a thread moves in a direction that doesn't interest me but usually they continue to do so even through a development into a variation of the main subject occurs. Obviously a major change should be a new thread but a slow development in the same vein is acceptable to me.
    Exfrogger likes this.
    377
    I for one have appreciated the thread deviation! I now think Iíll just get some new non-retractable belts.
    Safer, but mainly saves me drilling new holes/reupholstering my doorcards!
    Shoji likes this.
