Renault Fuego timing
    MELB
    33
    Default Renault Fuego timing
    Has anyone worked out a way to adjust the timing on a Fuego. My sons is running very poorly with all the signs pointing to ignition timing. I changed the gearbox. The one I installed in his car is out of a very early model and his is a late one with power steering. I suspect the mounting for the top deed centre pick up is slightly different.
    Any suggestions would be greatly appreciated as I have an 18 year old P plater itching to drive his car but at the moment it is not safe for a new driver.
    Peter.
    8,413
    You can move the tdc sensor as much as you want but it won’t make a profound difference.
    Bad running is 99.9% likely to be the crapy carby or the octopus that is connected to it.
    You can time the dizzy by sight. It will need to be way out of sync to be wrong.
    On a non powered steering engine it cant be set wrong but on a lower dizzi version you could get it wrong.
    MELB
    33
    Thanks Jo. It's not running the original Darby. It has been converted to a none emission Corby. The dizzy is mounted down low on the block and does not adjust. The problem only appears to happen after change of gearbox so something has happened in the process of removing the engine and changing the gearbox. Maybe a wiring issue?
    Oct 2005
    vic
    848
    Running poorly how?
    8,413
    Edited my previous post…now in front of a computer not a phone.
    During the gearbox swap did you in any way touch any components of the ignition apart from the TDC sensor???
    Jo
