WTB: R12 rear shocks - Koni maybe?
Results 1 to 12 of 12
Like Tree3Likes
  • 1 Post By nauli
  • 1 Post By 3006882
  • 1 Post By driven
Thread: WTB: R12 rear shocks - Koni maybe?
    Nov 2005
    Geraldton
    1,624
    Default WTB: R12 rear shocks - Koni maybe?
    Does anyone know where I might source a pair of these shocks? They are not currently listed in Koni's online catelogues.
    In the Shed(s):
    In the Past:
    9,233
    Try ebay.
    I found a full set of NOS Konis in Florida of all places. It was an ebay shop well decked with a lot of R12 stuff.
    Can't remember anymore detail, sorry.
    ACHTUNG ALLES LOOKENPEEPERS
    Fellow Frogger! nauli's Avatar
    Oct 2017
    Perth, WA
    405
    Try these guys...https://www.rtec.ws/en_US/
    Gil van den Heuvel is very helpful
    Shoji likes this.
    1969 Alpine A110
    Jun 2004
    407
    I just fitted a pair of adjustable shocks from AVO in the UK. I think I purchased them through EuroPerformance in the UK.
    They took a long time to arrive because they are made to order and there was some manufacturing/tooling breakdown issues at AVO. All up they were about $300-400 landed.
    I can't comment on their performance yet other than that they were an actual bolt in and no modifications or massaging was required.
    bowie likes this.
    Nov 2005
    Geraldton
    1,624
    Thanks all.
    I’m thinking there’s nothing special about them. Pointy at one end, round at the other. Something else must fit so I’m looking for cross references, again with little success.
    In the Shed(s):
    In the Past:
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,281
    Renault Fuego shocks fit, I have them in the back of my R12 wagon at present.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,509
    They what now!
    So I suppose coil-overs designed for a Fuego would work too.
    9,233
    In principle you are right, in reality you aren't.
    Shocks are valved to provide the amount of damping prescribed by the manufacturer (Renault).
    Changing the shocks to whatever equates to changing the mass of the car, the spring rate, suspension travel and the lever length of the suspension arm.
    Most of these combinations if randomly chosen are crap (overdamped, underdamped, resonant, who knows what else?) with just a narrow window of perfect matches.
    What is the probability that you're going to get it right?
    The beauty of (at least old) Konis is they are rebuildable, so even if you get your hands on an old set you can have them rebuilt. Some even allow for a bit of adjustment.
    Bowie has that set from me, why don't you ask him for the part numbers?
    1000+ Posts driven's Avatar
    Apr 2005
    1,537
    Search for "dampers" as well. Different terminology in other parts of world
    Brand new R12 rear dampers from UK
    https://www.dcperformance.co.uk/chea.../av-te390.html
    Exfrogger likes this.
    Nov 2005
    Geraldton
    1,624
    But if they’re adjustable surely that means you can alter damping rates. And if they’re rebuildable all I needs is a shock that fits and I can have it built to specs.
    Not sure how a shock can alter the mass of a car, other than if its heavier or lighter than the original shocks.
    In the Shed(s):
    In the Past:
    11,186
    https://www.autodoc.co.uk/car-parts/...r%5B0%5D=sachs
    These folk list the Estate rears....
    Not Koni but new....
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    9,233
    The shock doesn't alter the mass of the car. What I said was that the effect of changing the damping is equal to changing the mass etc, etc, if keeping the damper the same. The point is all those things work together hence are designed that way. You can't change one and hope it will all be good.
    The adjustability of Konis is over that very narrow window I mentioned, can't compensate for the wrong choice of damper.
    Hmm. The "specs" are again a combination of factors. The fluid inside counts (viscosity), the piston mass, shock cross section, aperture openings in the valves, shock volume, etc. What you are saying is that someone can recalculate everything given a new shock body. Yes, it can be done, but who would do it for you and how much would it cost? Would you trust the corner shop to do it?
    Plus, if you have the wrong length you have the wrong travel, and that can't be changed that easily.
