Renault R4 Motor
    Member martook's Avatar
    Jul 2012
    Coomba Park NSW
    90
    Default Renault R4 Motor
    Dismantled the 850 gordini motor from my 60's floride & found it's completely stuffed, a 750 R4 motor came with it so i dismantled it to see if anything could be used & found the R4 motor 680-02 which is in great condition runs backwards ie anticlockwise, does anyone know the reason as the R4 motor is mounted in the same configuration as the floride.
    does anyone have a R4 workshop manual & can look up the combustion chamber volume, the floride's volume is 27.3cc & if the R4's head volume is smaller I am considering fitting it to the 850 motor ( after porting the
    head out to gordini specs)
    Brian
    2008 ford Mondeo 2ltr turbo diesel + 6 speed alsin g/box
    1979 cx c-matic
    1977 cx 5 speed
    2000 peugeot 306 convertable
    1978 peugeot 604 sl
    2005 c5 (wrecking)
    2003 c5 auto (wrecking)
    2001 c5 5 speed
    1960 Renault floride under restoration
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,765
    Brian,
    The main differences of the 2 motors are:
    The camshaft turns the opposite way
    The starter turns the opposite way
    The crankshaft slinger at the rear main works the opposite way.
    And if I am not mistaken the 680-XX is a chain drive cam.
    And if it is a 750cc bores in the liners are different.
    The motor runs the opposite way, as the crank handle was then on the nose of the gearbox.
    Ray
    Ray geckoeng
    Think Old, But Run Modern !!
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    561
    There was a large ride on lawn mower , often used by golf courses , that used what was a R4 motor that ran backwards.
    When in the business I reconditioned two of these for St Ives Golf Club, piston and sleeve kit supplied by Yong at Auto France.
    As Geckoeng has already noted there are a number of differences between the lawn mower and the R4 motors.
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    Newcastle
    2,797
    Quote Originally Posted by Rally View Post
    Hi
    Yes those mowers were a Toro Groundsmaster 72. Quite a few of them around in the ol' days. The courses I worked at moved on to the same model with a diesel engine so I had little experience actually doing much to the Renno engine models. The Renault engines were sold in the USA by Contenential.
    Here is a link to a slightly later model, I think.
    https://www.youtube.com/watch?v=_TSxqFN_eQ0
    Jaahn
    Jul 2012
    Coomba Park NSW
    90
    Hi, Ray, you are correct, nothing will fit the floride, i was hoping to use the 680-02 block as the 670-02 floride block has too much wear in the camshaft bearing surface & the 680-02 is like new, I will check if the 850 liners will fit the 680-02 block tomorrow. if not I will have to try find another 850 floride or dauphine motor. FYI the cam drive is by gearsthat are almost double the width of the 670-02 motor's
    Brian
    1979 cx c-matic
    1977 cx 5 speed
    1978 peugeot 604 sl
    2005 c5 (wrecking)
    2001 c5 5 speed
