Renault 16 manual 2 New or VGC drive flanges needed?
Results 1 to 15 of 15
Thread: Renault 16 manual 2 New or VGC drive flanges needed?
    Fellow Frogger! Artificer's Avatar
    Mar 2018
    Robina
    148
    Default Renault 16 manual 2 New or VGC drive flanges needed?
    Any help sourcing, please? Have extensively searched the internet with 0 results
    1000+ Posts Shoji's Avatar
    Jan 2012
    Mandurah WA
    1,193
    Not sure if this helps..(two pages)
    Flanges?
    https://www.renault16shop.com/Webwin...ront-axle.html
    Mar 2018
    Robina
    148
    Thanks found that one earlier nothing on transmission to half shaft flanges....that i can see.
    Apr 2014
    kilsyth (lower montrose) vic,
    223
    may be a little confusion regarding flanges terminology as all r16 vehicles had drive shaft inner joint splines over axle which was different side gear outer end section. diff side seal nuts surrounded inner shaft joint these adjusted bearing pre-load and backlash between crown wheel and pinion. cannot recall a flange at this area. ..
    Apr 2003
    249
    If we can confirm Dacia's definition, I can get you 2. The alloy rings that need a fancy spanner to turn, and have a clamp to stop them loosening
    Sent from my HTC 2PST1 using aussiefrogs mobile app
    1000+ Posts driven's Avatar
    Apr 2005
    1,564
    R12 /R17/R16 should all be the same
    Apr 2003
    249
    On that same site try gearbox gaskets and seals. Called a diff adjusting nut. Is this it? Well one of three examples
    Jan 2012
    Mandurah WA
    1,193
    Mar 2018
    Robina
    148
    Thanks for the replies so far but to explain better what I need....
    I have a Slough Light 15 that has bits & pieces of just about everything on it including a Renault 1600 Engine & 4 speed transmission.
    The transmission is hooked up to the front wheel drive with Austin 1800? 1/2 shafts old solid disc Holden brakes & MG wheels/hubs.
    For the purists I have a vehicle that has been highly modified in the past so I am not spoiling or destroying a restorable vehicle.
    I am rationalising all this stuff out board of the transmission to be all late model Holden Astra & it will have ventilated discs & solid steel Citroen type wheels, again. Same is being done to the rear with Astra rear disc hubs & handbrake.
    Steering will be Astra electric power rack & pinion.
    Currently the flanges I am after are the drive from the transmission differential that have been welded to the 1800 half shafts.
    The centre 2 pictures may give a better understanding of the two 'flanges' [one each side] I am looking for. I need these to connect to the modified to length Astra drive shafts
    These 'flanges' shown in the middle pics may or may not be original to this transmission but I'm sure someone or other can identify & assist me. Thanks JG.
    Renault 16 manual 2 New or VGC drive flanges needed?-nick8.jpgRenault 16 manual 2 New or VGC drive flanges needed?-20180704_155914.jpgRenault 16 manual 2 New or VGC drive flanges needed?-20180704_155923_001.jpgRenault 16 manual 2 New or VGC drive flanges needed?-20180704_155937.jpgRenault 16 manual 2 New or VGC drive flanges needed?-20180704_155957.jpg
    11,294
    Brings new meaning to "hybrid", that is for sure! Good grief. So much work...
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Citroën CX Pallas 1980 (moved on to new custodian)
    Apr 2005
    1,564
    The parts you are after seem to be just cut off drive shaft stubs and welded.
    Get any Renault drive shaft machine off then weld to what you want
    Easy
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,765
    What JG wants is this part of the drive shaft. As I have cleared a lot of junk I do not have spline couplings available at present. The UJ yoke to the side is reslpined R10 for big box.
    Ray
    Ray geckoeng
    Think Old, But Run Modern !!
    Jul 2013
    Southampton Ontario Canada
    63
    Just to add to what Driven has mentioned I have removed the splined potion of 2 front wheel drive shafts of a R16. the spline portion was actually welded on originally from the factory ! I am planning on opening up the 330 splined unit and weld the larger splined units into the 330 yoke ends so I can run the big box internals .
    In this case if you are just after the splined yoke and there is no restrictions on size I know that the lotus Europa runs a similar unit on their half shafts ,however the ones I seen from the Europa where to large to work on my 330 swing axles .
    Manic gt
    Easy
    Mar 2018
    Robina
    148
    Thanks for the input guys, I'll get it done.
    Ipswich, Queensland.
    1,958
    The very earliest’68 model R16 had universal joints in the driveshafts, rather than the later CV joints. Don’t know what is left, but at the sellout of the French Wrecker at Drayton at Toowoomba there were some there. I picked up 2 complete ones for a friend, but I am sure there were more, but may all be dumped by now.
