Speedo cables - R17
  • 1 Post By REN TIN TIN
Thread: Speedo cables - R17
    Mar 2005
    318
    Default Speedo cables - R17
    Hi all,
    What speedo cables will fit into a ('77) R17?
    And...
    Where can one be sourced from?
    1000+ Posts driven's Avatar
    Apr 2005
    1,445
    You can get them made up if you have the two end fittings.
    The fittings are the same as a R12 that may be easier to find.
    The cable is longer in a R17 so need to measure
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,071
    Also remember there is two types of speedo cable for the R12 (1) VDO speedo (2) Jeager speedo
    You will most likely need the Jeager type
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    1000+ Posts Shoji's Avatar
    Jan 2012
    Mandurah WA
    1,106
    Brisbane/Australia
    2,067
    Yes it will be the Jaeger and you obviously need the cable for RHD.
    The RHD cable is longer the the LHD version.
    Shoji likes this.
    Mar 2005
    318
    Cheers all. Shot old mate an email to see if he'll do the cable for RHD cars, if not will get the old one rebuilt by an instrument specialist. It has Jaeger gauges yes.
