Change alternator position 807-10 engine
Results 1 to 11 of 11
Like Tree7Likes
  • 2 Post By R8RX
  • 3 Post By geckoeng
  • 1 Post By alan moore
  • 1 Post By JohnW
Thread: Change alternator position 807-10 engine
    Jun 2018
    Norway
    127
    Default Change alternator position 807-10 engine
    I am currently restauring an old Renault 8 racecar. I am going to use a Renault 807-10 engine. But I don't want to cut a hole in the body so the alternator will fit in it's original position. Are there any "off the shelf" parts so I can move the alternator to the rear (timing chain side) of the engine and use the crankshaft pulley to drive it?
    And are there anyone who has a suggestion on a starting point for jetting a pair of Dellorto dhla45 on this engine?
    JohnW and Sunroof like this.
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,689
    "R8RX"
    You need to get a R18 or Fuego turbo timing chain cover and pulley. Throw away the harmonic balancer, and fit it. You need to make some dowel pins for 2 of the locating positions they would just be shoulder bolts without heads. And then a bracket to hold the alternator. Not sure of the mount lugs on an 807 block, this is an 841. I used to mount my alternators on the starter motor bolt before I started doing the crankshaft pulley. A few spacers and an adjustment bar and it is done. (No pictures)
    Change alternator position 807-10 engine-dscn0141.jpgChange alternator position 807-10 engine-dscn0142.jpgChange alternator position 807-10 engine-dscn0147.jpgChange alternator position 807-10 engine-dscn0148.jpg
    Ray
    bowie, Sunroof and J-man like this.
    Ray geckoeng
    Think Old, But Run Modern !!
    Ipswich, Queensland.
    1,905
    Renault 15/17 also had a pulley for a fan at the timing chain end. The crank is the same as I remember, just the cover and fan pulley needed. Plenty of bosses at that end of the engine to make an alternator bracket fit in.
    driven likes this.
    10,888
    Quote Originally Posted by R8RX View Post
    And welcome to Aussiefrogs!!
    We'd love to see some photos please.
    Regards
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    10,888
    "R8RX"
    You need to get a R18 or Fuego turbo timing chain cover and pulley. Throw away the harmonic balancer, and fit it. You need to make some dowel pins for 2 of the locating positions they would just be shoulder bolts without heads. And then a bracket to hold the alternator. Not sure of the mount lugs on an 807 block, this is an 841. I used to mount my alternators on the starter motor bolt before I started doing the crankshaft pulley. A few spacers and an adjustment bar and it is done. (No pictures) Ray
    Both you and Frans should publish books with the photographic solutions to everyones' questions I reckon. You must have the whole suite between you. Alan Moore too, although I haven't seen his photos....
    bowie likes this.
    Renault 4CV 1951
    Renault R8 1965
    Jun 2018
    Norway
    127
    Thank you for your answer! Yes, i have a fan pulley at the timing chain side of the crankshaft. Is this useable or do I have to go for geckoeng's solution?
    I will try to get some photo's out here
    Boonah Qld
    2,543
    Love the photos and the engine geckoeng. Welcome to R8RX.
    1000+ Posts Shoji's Avatar
    Jan 2012
    Mandurah WA
    1,112
    If you have thermo fans, I guess yes, use the front pulley for the alternator.
    ďListen very carefully, I shall say this only once.Ē Cheers. John
    Perth, WA
    1,689
    "R8RX"
    as for Dellorto tuning try Shoji's starting point reference,
    Daves home page
    Ray
    Ray geckoeng
    1,905
    The pulley was good enough to drive a fan,(although a bit flimsy) and given the alternator is likely to use less horsepower to drive than a fan, I think all would be fine. The original crank pulley diameter would work OK with a standard alternator pulley. It is generally around a 2.5 to 1 ratio.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    Ď02 and Ď03 Renault Clios 1.4L
    Jun 2018
    Norway
    127
    "Geckoeng" Thanks for the advice regarding the Dellorto's.
    I guess I have to get hold of an alternator and bracket then and see how it fits
