Modified R16TS Engine Power output? - Page 3
Page 3 of 3 First 123
Results 51 to 60 of 60
Like Tree23Likes
Thread: Modified R16TS Engine Power output?
  1. #51
    Feb 2018
    Australia
    314
    Hi,
    I think someone may have mentioned this already but I have found the 807 motor difficult to build oil pressure after an oil change, but removing the filter and pouring oil down to the pump with a tube allows pressure to build very quickly when turning the motor over afterward
    Andy
  2. #52
    Feb 2012
    Vista SA
    983
    OK, thanks for that Andy.
    Phil
    Quote Originally Posted by 1972Ren View Post
    Hi,
    Andy
  3. #53
    Feb 2012
    Vista SA
    983
    Very interesting Col. I really never measured the distance all I know that rear R8 shelf support is directly above the No.1 spark plug tube hole in the cross flow head and I tried all the extensions I had and in the end said stuff it and pulled the head off.
    I just don't want to put the engine in and go through all that again. One plug in it won't stop me giving it a couple of revs to build up oil pressure before trying to fire up the engine. Every thing will be primed including the carbies so BARNIE should burst into life a
    after a couple of revolutions.
    I'll do some more measurements tomorrow, maybe with the right size extension it might work.
    Thanks again for your help.
    Phil
    Hi Phil
    How much clearance do you have between the top of the rocker cover and the bottom of the shelf support?
    I use a 3/8" plug socket, a small extension and a universal to access the number 1 plug on my alpine, actually need it for all of the except number 4.
  4. #54
    Feb 2012
    Vista SA
    983
    Yes John. I did consider cutting a hole through the back shelf support but guess what is right under it..The Shelf Support right where the Engine Cover retention spring sits !!! Ahhhh Phil
    Here is my good luck wish Phil. Can't you cut a hole somewhere to get plug access for #1?
    I also recall Frans talking about 4000 rpm to bed in the cam. He said it sounds like a terrible idea but works. He should know.....
  5. #55
    10,259
    Arrgghhh indeed!
    Re-engineer the support? You do need plug access without pulling off the head after all.... Good luck.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
  6. #56
    Ipswich, Queensland.
    1,829
    On my 16 powered R8, I used a cut down standard R16 spark plug tube spanner, left about 14mm longer than the tube in the head, with a hole drilled across it to utilise a screwdriver to turn the spanner. Once fully loosened the plug was removed via the H/Volt extension on the plug. I could change all of them OK.
  7. #57
    Feb 2012
    Vista SA
    983
    Thanks for that Alan. Yes I fiddled around today with measurements and I can do it that way or using a 4" extension with universal joint on long spark plug spanner.
    Thanks again
    Phil
  8. #58
    Feb 2012
    Vista SA
    983
    Thanks Col. Yes tried it today and should work for mine also.
    Phil
    Hi Phil
    COL likes this.
  9. #59
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,527
    Phil,
    You need a "double articulated" plug spanner, alla for the Alpine 1600S......
    And the appropriate piece of Blue rubber hose.
    Ray
    Ray geckoeng
    Think Old, But Run Modern !!
  10. #60
    Feb 2012
    Vista SA
    983
    Thanks Ray.
    Reckon I have this now.
    Phil
    Phil,
    Ray
