Renault 16 ..how to open a locked petrol cap?
Results 1 to 25 of 25
Like Tree12Likes
  • 1 Post By Shoji
  • 1 Post By Simon
  • 4 Post By 4cvg
  • 2 Post By philipjh
  • 2 Post By dogboy
  • 1 Post By REN TIN TIN
  • 1 Post By Kenfuego
Thread: Renault 16 ..how to open a locked petrol cap?
    1000+ Posts dogboy's Avatar
    melbourne,victoria,australia
    1,331
    Default Renault 16 ..how to open a locked petrol cap?
    aaarrrggghh
    When I recently got this 16 the key for glovebox,hatch and petrol cap were missing..
    the petrol cap thankfully wasn't locked and I filled up with petrol but on going to fill her up today I couldn't as somehow the cap has locked...how could that be?
    anyway..it is booked in for a RWC on Monday so I need to be able to get some fuel in or I will have to cancel
    any ideas folks?
    Rev. Dogboy
    1969 DS21 Pallas BVH with leather
    1970 Renault 16TS
    1967 Honda S800 cabrio
    Citroen 1970 DS21 Cabrio replica
    Citroen 1966 ID Safari (with 23 running gear)
    Citroen 1975 DS23 Safari
    1975 VW Kombi poptop
    1987 2CV
    Porsche Boxster S manual
    1988 Vespa PX200E
    Boonah Qld
    2,473
    A locksmith tried to use lock picks to unlock my 17 petrol cap without any success, he ended up drilling it out. Then I had to find a replacement cap. I was worried about sparks from the drill but he wasn't.
    Simon's Avatar
    6,105
    Which cap is it? The PJ Journee caps sometimes have similar keys.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,874
    Short of being lucky and finding a key that will open the fuel cap, drilling out the barrel is the only option I can think of.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    18,191
    And be careful of the hot swarf becoming an ignition source.
    1,331
    what I don't get is how did it manage to lock? it was open when I got the car...very strange
    Is the barrel keyed the same as the glovebox? if so I have the lock out of the glovebox ready to have a key cut
    Rev. Dogboy
    1970 Renault 16TS
    1987 2CV
    1988 Vespa PX200E
    1000+ Posts Shoji's Avatar
    Jan 2012
    Mandurah WA
    1,032
    Had the same problem once. Work a screwdriver with a driver shank and usevan adjustable spanner to turn it. Worked for me. But brutal
    Sent from my Moto G Play using aussiefrogs mobile app
    dogboy likes this.
    Listen very carefully, I shall say this only once. Cheers. John
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,874
    You are only drilling the barrel, do not go all the way through. If you are worried squirt some water on the drill bit to keep it cool.
    Most petrol caps of that era are made of die cast metal, the tumblers are also pretty soft.
    Also a sharp drill bit will create less heat than one not so sharp.
    Regards Col
    1973 Alpine A110
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,874
    Quote Originally Posted by dogboy View Post
    All the petrol caps that I have here, the keys are symmetrical.
    Your cap looks after market.
    I have the types that require the key to lock the cap into position, and also the type that require the key to open and then spring return to the lock position and you just push them into the filler neck and they lock automatically.
    Regards Col
    1973 Alpine A110
    18,191
    Just thinking outside the square.
    Could you remove the filler neck assembly completely and work on the bench ?
    May be easier and allow the use of other tools.
    Fellow Frogger! CXVingtCinq's Avatar
    Jun 2015
    Narrabri, NSW
    930
    Definitely not the same as the one on my 16 either. Sorry. The only thing I can think of is drilling it out as has already been suggested.
    Cheers, Peter J
    Current -
    1976 16TS
    Previous - 1984 CX 25 IE : 1976 16TS : 1979 12 Virage
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,874
    Unfortunately not Rob the filler neck is part of the tank just like on the R12 sedans.
    Regards Col
    1973 Alpine A110
    18,191
    Ah. I was hoping it was similar to a 404 with a neoprene hose connection.
    1,331
    The petrol cap is an original lockable option available from Renault...purchased as an option on the car..
    I'll put a photo up of the sales receipt when I find my camera..
    Rev. Dogboy
    1970 Renault 16TS
    1987 2CV
    1988 Vespa PX200E
    Simon's Avatar
    6,105
    That looks like a very common UK manufactured 1960's era locking petrol cap, it's not pieces d'origine Renault. Used by many manufacturers as an accessory (I've got one with the EnFo (English Ford) mark, and also one on my R4). It uses a single sided key that should be able to be picked by any competent locksmith, who should be able to cut a new key once the barrel is extracted. I'm surprised it has locked itself, as normally they can be used unlocked, as they require a key to lock them again.
    dogboy likes this.
    1963 Renault R4 Van
    1964 Renault R4
    1,331
    ah ha... better add to my wish list of an original 16TS petrol cap...non lockable!!
    still the mystery of the self locking cap remains..the deceased previous owner perhaps....not wanting the car to leave
    Rev. Dogboy
    1970 Renault 16TS
    1987 2CV
    1988 Vespa PX200E
    Feb 2005
    rosevale/tasmania
    2,689
    All that one has to do is break the pins. Screwdriver in slot & quick whack with hammer. (Or, at least, that is the advice which a daughter gave me after working with juvenile offenders.)
    Shoji is closest to this.
    jaahn, dogboy, Shoji and 1 others like this.
    Newcastle
    2,543
    Hi
    Years ago I had the problem of a locking cap on a car I purchased cheap. I took it to a locksmith, recommended, in a country town and he just cut a key for it by hand outside his shop, then took it in and cut a second one and I went off with a working locking cap and two keys for a very reasonable price. Took him about 10 minutes start to finish.
    So find an old fashioned locksmith. And use the fuel suction hose to get some petrol into the tank for the moment, by pumping it in that way.
    Jaahn
    298
    Default Remove the fuel sender unit.
    If you want to add a quantity of fuel it might be just as easy to remove the fuel gauge sender unit on top of the tank.
    You can then drive it comfortably to your choice of 'old fashioned' lock smith.
    JohnW and Wildebeest like this.
    1,331
    JOY...I used this method and it has worked well after only a minute or so...no damage apart from internal pins but if I file off the locking tab I can still use the cap until I locate an original type non locking one!!!! anyone?
    Shoji and CXVingtCinq like this.
    Rev. Dogboy
    1970 Renault 16TS
    1987 2CV
    1988 Vespa PX200E
    Brisbane/Australia
    1,999
    With the price of petrol these days a locking cap is a good idea.
    Petrol was over $1.50/ltr here today, and that's for E10.
    I've got one of the spring types on the 12 at the moment so you only need the key to unlock and it locks when you push it on.
    I find it does gunk up making it hard to open. A spray of WD40 occasionally frees it up and it's good for another 6 - 12 months.
    An aftermarket cap shouldn't be too hard to find unless you really want a Pieces d' origine which might be a struggle.
    Or at least a good working one might be a struggle.
    Kenfuego likes this.
    1,331
    Quote Originally Posted by REN TIN TIN View Post
    The one I have is the original after market cap ordered when car was new (its listed on sales receipt)
    Now I have it off I have cut off the locking tab so now I can use it without fear of locking..
    Im happy to use this cap but still hope to locate an original cap at some point....
    cheers
    PS she is in getting her RWC with Gary ar Renno workshop so she's in good hands as Gary did his apprenticeship on 16's....fingers crossed she is in good mechanical shape
    Rev. Dogboy
    1970 Renault 16TS
    1987 2CV
    1988 Vespa PX200E
    Oct 2002
    Melbourne Victoria
    11,392
    Glad you got the cap off to resolve the problem.
    Most of the simple key locks can be manipulated with a bent up heavy paper clip to apply pressure on the internal segments, but they do clag up with use and a spray of either graphite or liquid WD 40 can free that up and then wiggle the paper clip to spring the internals while you gently apply opening pressure to the cap.
    Moot point now of course, sorry I didn't see your original post. I do have lots of old keys that might fit or come close enough, left over from another life...
    Ken
    dogboy likes this.
    18,191
    Confiscated from those who use them as tools of trade ?
    1,331
    the little 16 has some rust...one bit where two bung holes are that should have been pulled out on pre delivery
    the 2nd hole is on a chassis rail near wishbone...$600 for rectification
    mechanically it is a strong engine but with oil leaks at seal on dipstick tube..gary says seal n/a but he will pull it up and seal
    there seems to be another leak which could be rocker cover or head gasket? to be investigated further but hoping head doesn't have to come off as Gary was talking $2k to do head...plus.. l/h steering eye,rack end bush,rotors undersize,rack end bush,rear muffler,l/h rear brake pipe rusty,brake fluid needs changing...steering wheel is loose.. plus the other stuff...heater valve,,faded headlights
    this little 16 will be back in the health she should enjoy
    Rev. Dogboy
    1970 Renault 16TS
    1987 2CV
    1988 Vespa PX200E
