R17/Virage Master Cylinder Conundrum
Results 1 to 19 of 19
Like Tree5Likes
  • 2 Post By Simon
  • 1 Post By COL
  • 1 Post By robmac
  • 1 Post By 3006882
Thread: R17/Virage Master Cylinder Conundrum
    Jun 2004
    398
    Default R17/Virage Master Cylinder Conundrum
    I'm trying to replace the master cylinder on my virage and I'm having trouble finding the correct item.
    I think my problem is that I'm trying to upgrade to the 20.6mm cylinder size from the standard 19mm, as per the 17G, because I'm running 17G brakes on it, and the virage appears to use a master cylinder similar to the R20 rather than the R17. Can anyone confirm this?
    I have what I thought was the correct master cylinder as the outlets were correct and the piston was 20.6mm, but the bolt holes to mount it to the booster are 70mm apart whereas the current master has mounting holes of 58mm, so I'm a bit stuck.
    Is there a master with 58mm mounting holes, a 20.6mm piston with the bank of 4 outlet pipes?
    Am I best to swap to an R20 booster as well, and will this bolt straight onto an R12 pedal assembly?
    Or should I be doing some careful work with a pillar drill to make it fit? *not the preferred option*
    Boonah Qld
    2,538
    The 17 G has a dual vacuum unit so may be different to a Virage. They are much larger both in diameter and depth. The brakes on a 17 G will stop with very light pedal pressure equel to any modern car. Not sure about the bolt spacing.
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,396
    Yes the Virage dual and the 17 master are different. Didn't realize the bold pattern for the booster changed however.
    The more you know.
    I'm yet to rebuilt / replace my (what I believe is a 17ts master cylinder), I suggest I'd probably buy that of you assuming it will fit the booster I have if it is no good for you
    Jun 2004
    398
    I've got the standard original 17G booster and master cylinder still so I will check that. Though from memory the master cylinder is very different and has an external shuttle valve bolted to the side of the master cylinder.
    I thought I may have had some strange braking combo due to my virage being a 78. For reference, my master looks like this:
    R17/Virage Master Cylinder Conundrum-s-l1600.jpg
    Aug 2002
    3,396
    Like this? (The 17ts booster and cylinder I think I have..)
    R17/Virage Master Cylinder Conundrum-img_20180103_190510695.jpg
    Boonah Qld
    2,538
    Yes Bowies looks about right.
    Aug 2002
    3,396
    3006882, your current Virage booster looks like that one you posted?
    Cue Simon to tell us if that was common or not.
    Simon's Avatar
    6,174
    That one looks like the single 15TS/17TL booster, rather than the double 17TS/G unit.
    The 17TS master cylinder has Lockheed 311409 cast into the body, with the pistons retained by roll pins rather than a bolt.
    Bustamif and Sunroof like this.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    1000+ Posts Shoji's Avatar
    Jan 2012
    Mandurah WA
    1,106
    Yep TL. I just had all mine recond. And I know the look of TL type straight up. Not TS or G. Still Bowie no problem though. Good units if not shagged like mine was. Some pics of the master and booster would help maybe 3006882?
    Aug 2002
    3,396
    <thread hijack> Cheers for clarifying all. </thread hijack>
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,071
    You are also going to run into another problem putting an R17 master cylinder onto a virage.
    The R17 master cylinder has UNF threads and the Virage master cylinder has metric threads, also the flares are different on the brake lines.
    You are going to have to source a complete set of brake lines as well to do this upgrade.
    Sunroof likes this.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Boonah Qld
    2,538
    May be the phase two R17G had later master cylinders with the correct Virage style bits but the caliper end would also need to be changed. Phase 2 never came to Australia but perhaps available on ebay etc. Simon what about the very last Phase 1's that came here? What did they have? They had later fuel fillers and upholstery, so what else?
    8,914
    That is easily solved. UNF threaded fittings seem a lot easier to source around, and any brake shop will cut and re-flare your pipes after they replaced the fittings.
    ACHTUNG ALLES LOOKENPEEPERS
    Nov 2005
    Geraldton
    1,574
    Sorry for the attempted hijack here.
    I'm have a few issues here, too.
    I bought a master cylinder for my R17TL but its not the same as the one in there now.
    Note that the new one has a threaded hole that accepts a bolt - it does not have a hole at the bottom through to the bore. It looks very much like the example shown in Bowie's pics above. In his image a bolt using this hole secures the distribution block.
    Note from the pictures below of my vehicle that in the same position as the bolt hole a brake line enters the cylinder.
    Any thoughts?
    R17/Virage Master Cylinder Conundrum-img_3849.jpgR17/Virage Master Cylinder Conundrum-img_3853.jpg
    R17/Virage Master Cylinder Conundrum-img_3854.jpgR17/Virage Master Cylinder Conundrum-img_3855.jpg
    (Last photo auto rotates, I cant do much about this.)
    Attached Thumbnails Attached Thumbnails R17/Virage Master Cylinder Conundrum-img_3855-2-.jpg
    In the Shed(s):
    In the Past:
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,071
    Yes it is easily fixed, was just pointing out that it is not just a quick easy swap over.
    Regards Col
    1973 Alpine A110
    19,103
    Brakquip make a huge range of adapters, and finding something ex stock should not be an issue.
    So cutting the tube, replacing the nut, and re-flaring should be unnecessary .
    Sunroof likes this.
    Jun 2004
    398
    I was hoping to find a bolt in solution, so I'm thinking an R20 booster may be the solution, but they're appearing hard to come by.
    Having to weld and re-drill the mounting holes on the column strikes me as far less work than re-running and flaring all the lines, but that's my opinion before I attempt either option.
    bowie likes this.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,071
    Quote Originally Posted by 3006882 View Post
    If you can get hold of an earlier R12 (pre 1978) you can then remove all the brake lines and have your bolt/clip in solution.
    Regards Col
    1973 Alpine A110
    Fellow Frogger! 21571's Avatar
    Apr 2013
    Geelong
    168
    Here are the master cylinder part numbers from the1972 R17 parts catalogue. Hope the resolution is high enough.
    Attached Thumbnails Attached Thumbnails R17/Virage Master Cylinder Conundrum-1525952485262.jpg
